Imhotep's Radiant Oscillator Video
Efficiency of the circuit
Originally posted by Aromaz View PostI got back today and was resetting all on my fq generator when last 555 smoked; replacement 157 km far! Thus I tried something different, anyway not too happy with weak 555 circuits. Then I got some strange actions and readings, so I started unplugging and pulling out from breadboard until only this relevant things were left.
Now this I can not explain, except maybe somehow the coil has gone into self-oscillation. I would love to see if someone else can duplicate this and really be happy to understand the why! I broke all up, used other parts and still got the same results.
See attached circuit.
Parts: 1x 2N2222A, 4x 2N3055, 1x12Vdc battery, 1xHitachi ignition coil, 1x Philips CFG gas tube (all controll board removed) and earth(ground/dirt) wire.
Stats: Battery disconected: 12.24 v, Running 12.16V
Running: Amp from Battery + terminal 0.86 Amp (sometimes up to 1.16A)
Volt at 2N2222A Emitter - 3.03V
Volt at Master 2N3055 Emitter - 2.59V
Volt at coil + 1.87V
Amp at coil + 1.18A
Frequency - connected at + of coil: 5.962k Hz
Same reading without (electrionic) Hz meter connected for distance of up to 42 cm from coil/light - Horizontal. By accident and strange thing: Vertical above the coil the frequency is only 263 Hz and reading up to 220 cm from coil - meter not connected.
Coil does have VERY faint resonance 'whisper'.
All components cold.
No condensor (capacitor) anywhere, no resistor, no diode.
Spark at light about 1.5 to 2.0 mm, blue purple colour.
No feeling anywhere - neither schock on any component.
Touching the 2222 transistor E seems to lighten the bulb a few points.
The light is nearly (85% ??) same is the same light in my roof which is 18W 220V AC.
Oscilloscope shows a strange hoop like wave - similar to Australian Kangaroo! or like standard coil symbol.
PS. Afterthought and went to check: Adding second light INCREASED glow in both lamps to be more than one lamp alone - that is the first light went more bright and second also same bright. With one light a barely noticeable flikker, with two tubes both are very smooth light. Third light seems to keep same brightess as with two - i.o.w. More 'light' in total.
DESCRIPTION:
12v Battery, positive terminal our to parallel supply all 5 transistors connect to Comuter.
Negative terminal got to negative of coil and one point of light bulb.
1st Transistor 2N2222 Base not connected anywhere, but remove and system fails!?
2N2222 Emitter connects to Master 2N3055 Base.
Master 3055 emitter connects to 3x 2N3055 transistors at Base - in parallel.
Earth wire (dirt/land/soil) connects to Emitter of 2N2222
Sorry for drawing on MS-Word 2003. Seems my Rhino 3D can not do PDF or JPEG. Will sort out soon.
Hi Aromaz
How much ampere is consumed Will you plz let us know
