Imhotep's Radiant Oscillator Video
  • Originally posted by ashtweth View Post
    Yeah Aromaz, thats right!! i am gonna run Ren's PWM/toroidal to operate a CFL and charge batteries Bedini style with our new water fuel cell.
    Just when you thought things were weird, (i blame bodkins, he is the KING of weird and cool ). We will have our VIC done soon muhar...
    That one for my graves stone
    I blame bodkins, he is the KING of weird and cool
    • Comment
      • Re brightest light at turn off
        @mylure
        Probably getting biggest brightness at turning system off because as these master transistors get 'conditioned' and respond to aether particle pulses, they go soft and stop shutting completely off. See my long winded post 2 pages ago.
        When you shut off power, you get the instant shut off, so big spike of pure voltage, no electron movement.
        That's why I'm counting the days to get vacuum tubes :-) lots of pretty lights..
        Still, expectation = disappo
          Just had some fun today. Made great blue and purple sparks using Nat's TP roll conversion tube idea. Wasn't headed that way but ended up there. Played with it all day just like a kid. It is like a little tesla coil. Have not figured out exactly how to use it yet but who cares--it was fun.
          YouTube - BIG Sparks Circuit
          Lidmotor
          @ Lid and others. I cant remember if you or others have done it yet but have you guys set up your ignition coil for a continous arc yet? With the PWM circuit I posted I can get a continous arc (with plenty of ozone) for as little as 12v 300ma. Its only 10 - 20 mm long, and is strongly related to the materials used as the gap I found. The cool thing is the PWM allows you to push as much current as you like (within reason) and adjust the frequency to see the different effects it has on the arc. Nats foil roll looks like it could be fun to play with, I might build something similar to tinker with.
          I'll make a small video if people are interested.
            Lidmotor
            Cool spark Lid
            what im trying to do is have two tubes like two caps with mircowave diodes(two)one to each, Bugger it i will do a picture.
            mistake on picture the diode go to one outside the other inside oppsite the ground
            • YouTube - TESLA'S RADIANT ENERGY WIRELESS TRANSMISSION - UPDATE 22 /EDWIN GRAY HYBRID CIRCUIT
              Couldnt help myself......60volts input.. wireless radiant energy transmission
              • @NAT
                I see why AC/DC are Australian.
                • @ren/all
                  the conversion tube is bizarre....still trying to understand exactly how it works....have been playing with it for a while...and still learning from it....it is unlike anything i have ever seen. i am convinced this is very important
                  @bodkins
                  Yes you are right they are Aussies. I believe there are quite a few aussies posting on this forum from what i gather.
                  Nat
                  • Wireless transmission
                    Bodkins, you'll like this one. Type '' Tesla Coil - - Free Energy from the Atmosphere '' into youtube. Can't post link cause I search for videos using blueapple.com on my phone web browser so they come down as small 3gp vids.
                    It's not actually free energy, he's got a transmitter hidden behind setup. Still pretty cool though, and food for thought. I want one :-)
                    • Search youtube
                      I re-found the vids I was talking about before from youtube, where a guy is picking up natural frequencies with large metal sheets. his vids are called '' Wireless Transmission of Electrical Energy, Tesla 1900 part ''
                      • you talking about box888?
                        we have talk to him already hes a top fella
                        • 2 ground wires
                          Last night I put a 30 cm copper pipe 10 cm into the ground and ran a wire into the house
                          (missus asked me if these wires are going to be permanent - in the ensuing discussion it was decided that my experiments, and possibly me as well?, will be moving under the house -with my motorbike- which is on stilts at the back.)
                          And I put the new ground wire onto base of master 2n3055. The old ground to kitchen tap (i can see the missus' point) is on the cfl that I have connected to a magnetically quenched spark gap in sealed eye dropper tube (glass melted over wires with blowtorch and squashed with pliers) which drives system to 20khz from 2nd ignition coil sec pos. 2nd ignition coil primary pos is connected to 1st ignition coil sec pos. 2nd ignition coil neg not connected to anything, else system stops oscillating (too much capacitance?)...
                          So... Maybe a video would have been easier? Oh well. My point is, the kitchen tap is being sent approx 6? Thousand volts at 300ma and 15khz (cfl damps frequency), and the wire to earth outside to base of master 2n3055 still causes system to oscillate.
                          Tried diode to earth and then from earth to base 2n3055 and then tried dual diode. All make system switch/oscillate.
                          What is making it oscillate? I thought maybe aether waves travel through transistor seeking path to ground, but diode should stop it. Perhaps aether shock waves hit earth and come up copper pipe wire, but diode other way should stop that. So maybe both. Maybe we're using earth as capacitance.
                          Any thoughts?
                          Ps, using different ground for both base master transistor and hv dump to earth, I couldn't get earth to sing back at 1.5khz like my last video. But then again, I sang to her at 1.5khz too. Maybe she didn't hear me at 20 khz.
                          What I wouldn't give for a signal generator... That would speed up my experiments but cost an arm and a leg.
                          • @bodkins
                            Boxa888, yeah. Him's the one. He should try pulsing or 'conditioning' his caps, see if they work better at catching radiant..
                            • Wireless transmission of energy, tesla 1900 part
                              Re Boxa888. I just watched his vids part 4, part 5 and part 6, he goes into detail about the .08484 second pulse to set up stationary waves that I mentioned earlier, and that the waves travel at 57% more than the speed of light...
                              Well worth watching.
                              • YouTube - Bobkins 36.AVI
                                Inquorate try putting some diode on the sink and copper see if you have a difference in potential.
                                looks like your joining me in the basement,
                                Im so crap at spelling I spelt my name wroung
                                scalar wave travel faster than the speed of light
                                Proff Merl or somethin like that hes german has the proof
                                @All What to do with contubes inductive load on the pickup
