  • #61
    Originally posted by theremart View Post
    Can you tell me how many amp hours is your battery? I am curious what size of battery you have. Congrates on getting this going.
    Thanks!
    mart
    YUASA - Type 12-12
    12V 12Ah sealed lead-acid
    Tomorrow measure engine on the scope.
    Engine torque is weak, but the burden charged more.
    ________
    Honda ANF125
    • #62
      Today scope is operational! !!!!!
      Attached is a picture of the fan and settings.
      looks like you have it set to channel b. Is that correct, and the division is on 1 volt per division dc, and the sweep is set to 1 or 2 millisecond. Its hard for me to tell from the angle but it might be my eyes..lol.
      Looks like EXCELLENt spikes. YAY!!!
      now everyone can hook the scopes up to the fans and see them. Is it the fan that you altered with super high rpm.
      What is the total spike voltage? Its kinda hard for me to tell but it looks large!
      Nikola Tesla
      http://www.imhotepslab.com
      • #63
        The Stator
        Hi,
        I tried disassembling the stator, but no matter how much I tried no luck! I think that I even damaged the windings, so I need to also rewind some of the windings too. Is there any easy way to get it off?
        Elias
        http://blog.hexaheart.org
        • #64
          Originally posted by elias View Post
          Hi,
          Elias
          Hi, I had the same problem with the original windings,
          for me, this winding works
          ________
          Mercedes-Benz M275 engine
          • #65
            Hi,
            Elias
            i have had a few tough ones and used a few methods with success
            use low heat(with hair drier) on stator to soften glue, if glue was used.
            be carefull not to melt plastic, if its still warm use rag or carefully use pliers to twist,(i cut the power wires going to the circuit board off so when it comes off i did not want to smash or snag the plastic supports with the dangling power wires).
            the newegg ones i got were tough and had no posts just wires running through grooves in outer perimeter to the circuit board, successfully got stator off then removed old board and striped the surface mount ics and caps and protection diode off old board ,then put old board on and soldered wires to 4 isolated pads, checked to see that no pads were shorting to other areas and i was good to go(the new egg ones i used pliers on rotor laminations carefully ) it works great.
            there are many different types of fans used in computers pwr supp., the easy ones were old ones with posts, that i got for 1 dollar for 6 of them from a computer recycler down the block from me. they had no glue and all had been in use for a long time so they came off easily. hope this help good luck experimenting.
            Nikola Tesla
            • #66
              on rewinding
              the ones i rewound ,i used two wires cw ccw cw ccw hope that helps , i no longer rewind they are easy after you do as many as i have .never give up
              Nikola Tesla
              • #67
                I appreciate your assistance.
                • #68
                  Ball bearing fans
                  Hi everyone...
                  ~Imhotep~, have you run into any ball bearing fans? The box o' fans that I got are all top-of-the-line ball bearing fans (used in a large parallel computing array)... After taking the clip off of the shaft, the fan still wouldn't budge. It felt like there was a spring in the middle somewhere. It would pull a little bit and then go back in. (It wasn't because of the magnetic attraction) I decided to "sacrifice" one and the shaft ended up breaking off where it was glued to the fan blades! The stator is really nice and the inside shafts are all metal. Any ideas on getting the center shaft with the fan blades to come out?
                  I'm going to try to press out the center shaft on this broken one to see if it will come loose.
                  Thanks...
                  • #69
                    The ones that I've gotten working are wound that way as well... As I mentioned before, I've seen different winding patterns even in the same fan brand, make, model, same packaging with the same numbers on the boxes...
                    • #70
                      Edison & Tesla would be proud!
                      Keep up the good works. The world needs inventors to provide solutions to energy problems!
                      Carry On...
                      Acts 1:8
                      • #71
                        Originally posted by InTheField View Post
                        Hi everyone...
                        Thanks...
                        yes i have done ball bearing, and they were really nice ones. I have broken the shafts off on a couple of them and I actually took the shaft after i got it out and stuck it, after i made the hole all the way through the plastic fan/magnet assembly i took the shaft and stuck it back through from the outside glued with plastic glue, didnt put the clips back on and because of the strong magnets it runs fine, and stays in there cause of the magnet attraction..lol.i never give up, is running right now.
                        Nikola Tesla
                        • #72
                          Carry On...
                          thank u for the kind words. Happy experiementing
                          Nikola Tesla
                          • #73
                            RE: size of spike
                            Well for 12V I am getting 60V spikes if I am reading this correctly The scale is 1 V I have the probe at 10X and it takes 6 segments on the screen. I am brand new with this scope stuff, ....
                            See my experiments here...
                            • #74
                              your readings are correct, thank you happy experimenting ,i will be posting any new data as i confirm them , thank you
                              Nikola Tesla
                              • #75
                                i ran into one with brass sleeve instead of clips ,it also had spring between rotor and stator . it has become my tesla pancake one that i described earlier i took hemostats and twisted the sleeve until it came off .hope that helps
                                Nikola Tesla
