Roto Verter
  • #16
    RE: Video you looked at...
    Originally posted by Solace View Post
    Interesting design.
    You could easily fix the audio with some dubbing.
    I'd like to see what the waveform across the collector looks like.
    Seems like it could be spinning faster.
    The one at this link seems to be humming right along though.
    YouTube - SSG adding a generator Video 18
    Ya.... I was debating between getting a scope, and getting an Rotoverter, the roto-verter won out. I see alot more possibilities if I can get the Rotoverter working.
    I switched magents from the first video, and I have been so impressed with the charging rate of the big Neo magnets that I did not mind the slow speed.
    See my experiments here...
    • #17
      I was getting ready to do an experiment to determine whether or not Neo's would charge the battery better than ceramics.
      The guys at one of the Yahoo groups advised against using neo's since the only job of the magnets is for switching. One thing I am noticing though is that the rotor charges better than the solid state version which leads me to believe that the magnets are doing more than just swithching the tranny on and off.
      • #18
        RE: Neos
        The trick with Neos I believe is to get the right distance away from them with your coils. You want to get max power from them, but then again you don't want to saturate your coil.
        I think also the right size of Neo makes a difference as well. ( as the shape of
        the magnetic field would be a factor.
        I am finding I am getting more power out of SSG by adding another power coil in series with the primary. You have to position it just right on the wheel, but it has given me much more punch for the same amount of voltage.
        I hope that I can get some input from the EVgray group tonight about my choice of capactiors for the RV I do hope to get this motor spinning soon.
        • #19
          Did you find some oil filled caps?
          I should be able to at least get my prime mover working in the next few days as soon as I get time.
          I read about the RV/Muller generator. It looks pretty good but I'm not sure why he can't get overunity out it.
          • #20
            Oil caps found, and ordered! HURRAY!
            Next I am going to work on getting the box to contain the capacitors, and resistors to bleed the capacitors.
            • #21
              theremart i would consider doing them in a binary cap bank arrangement for easier tuning, here is ours we did.
              Directory:Rotoverter:Replications:Panacea - PESWiki
              Ash
              • #22
                RE: battery bank
                Ash
                Capacitors arrived today. I will start reading the site you listed to know how to hook them up. I am a bit nervous, as these are some hefty caps never worked with this much power before.
                Mart
                • #23
                  Roto verter Neon Test
                  • #24
                    Rotoverter
                    IT runs It RUNS IT RUNS
                    Got it going today, I am so happy I have not taken the vitals yet, like RPM or voltage, but so very happy that I have gotten this far.
                    Capacitor bank fully operational.
                    Mart
                    • #25
                      Those are some great news, mart
                      Please keep us updated of your success
                      Jetijs
                      • #26
                        Double success
                        YouTube - Double feature. Roto Verter / SSG on steriods
                        My SSG generator is doing wonderful too.... as you will see.
                        Next I need to get the rotoverter charging batteries, powering the rotoverter, and many other projects.
                        the EVAY Gray group on Yahoo has been most helpful, and THANK YOU ASH!!
                        MART
                        • #27
                          Congradulation Mart!!!!
                          Pretty cool to see you happy like that in you're vid!!
                          Good stuff coming out of you're work so far..
                          You show us what immagination can lead to and hard working too.
                          Again,CONGRADULATION !!!!!!
                          peper10
                          Hope die last!!!
                          • #28
                            great vid
                            Very cool Mart!
                            Were those coreless coils above the SSG picking up the charge from spinning rotor?
                            • #29
                              RE: coils
                              Very cool Mart!
                              Correct. I have talked with the guys from the auxil Flux group ( windmill gurus ) and most of the use neos and empty cores. Also metal backing for the neos to channel the flux.
                              I have learned sooooo much on a wild idea to get energy from the SSG mechanical.
                              Also KTservices gave me the inspiration to keep on, by making his system before me work with his SSG.
                              • #30
                                Mart I am looking to build a windmill style generator to be powered by the sg. I too noted that Piggot and others have strong neos rotating on both sides of air coils. Cant wait to see how well they go.
