Originally posted by robur
If Law Enforcement worked the same way we would still be burning people for witchcraft. OK, just because you encounter phenomena does not mean it's a result of demon worshiping. Christ sake's grow a pair is what I say, and so let me be clear about this: I'm in the camp of Wheeler, Tesla, Farnsworth, and Edward Leedskalnin.
Written by a person with a 4th grade education and you'd be significantly challenged to find anything this clearly written, this insightful and thoughtful in science blogs today. What was obvious to a man with a 4th grade education was equally obvious to Philo Farnsworth. Yet today what do have?
There are no black holes, there is no dark matter, and space is a void analogous to a shadow. There are no such thing as particles, electrons, or quantum thingy's. It's complete idiocy and anyone who thinks otherwise is being played for a fool. However, it would be a mistake to think that while misinterpreted cause and effect exist as our so-called science it is not entirely incorrect. They are, after all, based upon something, however ill conceived, and in the end, in our day, these misshapen stone tools are what we must use. Therefore this explanation, which is a conjecture, cannot be accurate but may be "scientific." In conventional terms the reason the Alexey works is because of "Anti-ferromagnetism." Yet aluminum, platinum, and manganese are paramagnetic materials. That's as simply as I can put it which makes no sense so let me try to put some sense to the Alexey. Paramagnetic materials such as aluminum, platinum, and manganese can experience an overall magnetization effect; an increase in their magnetization.
*Paraphrased from cited source material.
The distinction between the materials in terms of magnetism lies in the interaction of the micro-magnetic moment of the electron orbital motion and electron spin, causing a rearrangement of moments resulting from an applied magnetic field.* Notice the use of the term "applied." Applied does not say spinning or moving magnetic field. It just say's applied. Something to notice when reading along so that you don't get tunnel vision.
The magnetic moments introduced from electron spins and orbital increase the overall magnetization when a so-called "Spin Flop" state occurs.
Antiferromagnetic materials with small magnetic anisotropy may, at a certain field value which usually is not very high, exhibit a so-called spin–flop transition in which the collinear antiparallel magnetic moments rotate to a direction perpendicular to the applied field.
Anistropy;
The phenomena electrical resistivity, such as in selenium, is high in one direction but low in the other, but when an alternating current is applied to this and other materials it is transmitted in only one direction. We say it becomes rectified by becoming a direct current.
Black Triangles; (from my notes, sorry I don't have a link to the author whom I am paraphrasing from). Might be Peter Grandics but if you do know then please post a link for others.
Unlike ferromagnetism, anti-ferromagnetism can lead to multiple optimal ground sates of minimal energy in one directional dimension: Consisting of alternating series of spins moving up and down, which in two dimensions, or multiples, forms a ground state.
Now consider an equilateral triangle with three spins, one at each vertex of the triangle; if each spin can take only two values, either up or down, then there are 2x2x2= *8 possible states to the total system. Six of which are going to be ground states. Of the six ground states two will be favorable and one will be unfavorable. The two situations which are not ground states is when all three vertex's are all up or all down.
