The bistander thread
  • ron48
    Thank you for that thread link appreciated as haven't read till today.
  • ron48
    Please read where Brad says cifta is wrong many posts later. If you build to his instructions exactly you will have a self running torque motor.
  • ron48
    Apologies he told me he would never post there. I guess I should have checked as I don't frequent there any more. Only our
  • bistander
    Originally posted by ron48 View Post
    As usual you are wrong Brad hasn't been near overunity .com for 4yrs as had to many dramas there as well as at overunity research after his good friend there passed away.
    Hi ron48,
    Isn't this the tinman of whom you speak posting 02Feb2022?
    Click image for larger version  Name:	Screenshot_20220217-220935-549.png Views:	0 Size:	508.6 KB ID:	509363
  • ron48
  • bistander
    Please explain where tinman is wrong with his torque force magnetic motor and he proved overunity.
    with all the brains at overunity research trying to prove him wrong and most are top grade electrical engineers or higher educated people. but couldn't with all the tests they asked that he did and proved them wrong.
    ​BRAD WILL SOON RELEASE IT TO AUSTRALIAN OPEN MARKET AND THEN WHAT WILL YOU SAY. YOU WILL NEED TO LEARN ON THE BENCH LIKE BRAD HAS DONE with scopes and testing equipment SAME AS DAVID BOWLING HERE.
    Hi ron48, I took some time and read most of the OUdotcom thread which I hadn't read before and watched several of tinman's videos. I saw no evidence of free energy nor did I hear him claim it. He, along with others, have been developing torque curves for magnets and cores, much like the article shows which I posted last week. I'll paste a copy and link at the end for easy reference. The point being is that they are measuring and plotting cogging torque.
    I wonder how the torque from their 2 magnets with torque plate compares to the conventional arrangement using a closed iron magnetic path like shown in the article figures. Or, as citfta mentions, coils on cores replacing the PMs, making it essentially a Switched Reluctance Motor, SRD. SRDs are noted, even notorious, for very high torque density. High torque appears to be their goal.
    They seem to be getting on quite well without me butting in. Here's that previous post.
    COGGING
    Hello Turion and all,
    I have been on the lookout for a authoritative paper, text or presentation giving a technical understandable definition of cogging in Permanent Magnet Synchronous Machines (PMSM). I have found such. I will supply the link. But first:
    Turion has recently again expressed his contention that cogging includes or is caused by the axial force of attraction between magnet and core at TDC (Top Dead Center), a position the paper calls Stable Detent Position. Here is a copy of that section:
    QUOTE] Cogging torque is produced, in a brushless PM machine, by the magnetic attraction between the rotor
    mounted permanent magnets and the stator teeth. It is the circumferential component of attractive force
    that attempts to maintain the alignment between the stator teeth and the permanent magnets.
    Figure 1 displays two positions of a permanent magnet in relation to three stator teeth. The permanent
    magnet in figure 1 represents a single pole of a multi-pole machine. In figure 1a, the permanent magnet is
    aligned with the maximum amount of stator teeth. In this position, the circumferential components of
    force produced by the magnetic flux entering the stator teeth cancel. Thus, no net cogging torque is produced.
    /QUOTE]
    quote from:
    Study of Cogging Torque in Permanent Magnet Machines
    C. Studer, Student Member A. Keyhani, SM
    Department of Electrical Engineering
    The Ohio State University
    Columbus, OH 43210
    T. Sebastian, Member S. K. Murthy, Member
    Saginaw Steering Systems
    Delphi
    Saginaw, MI 48601
    https://www2.ece.ohio-state.edu/ems/...20Machines.pdf
    The quoted section with diagrams are right at the beginning of the document.
    Turion, these authors fully confirm what I've been telling you about cogging and axial force. A few of the terms are different like circumferential where I used tangential, and Stable Detent Position vs TDC, but the meaning is clear. They say "no net cogging torque is produced" at TDC.
    Click image for larger version Name:	Screenshot_20220206-152756-513.png Views:	21 Size:	411.3 KB ID:	509189
  • Turion
    bi,
    Did you notice that every time you mention me or my work on this thread the response is going to be the same from now until the end of time, or at least until I am too old to post here anymore? I can copy and paste all day long. Just takes a few seconds of my time
    YOU ARE AN IDIOT. SIMPLE. YOU TWIST EVERY STATEMENT I MAKE. YOU TAKE THINGS OUT OF CONTEXT. YOU NITPICK MY WORD CHOICE. YOU WHITEWASH THE MISTAKES YOU MAKE OR OUTRIGHT IGNORE THEM. I’VE HAD MY FILL OF IT.
    YOU HIDE IN THE DARK AND DISCREDIT THE WORK OF OTHERS, WHILE CONTRIBUTING ABSOLUTELY NOTHING TO THIS WORK. SO I HAVE NO RESPECT FOR YOU WHATSOEVER. NOT EVEN A TINY BIT.
    IN MY BOOK, SOMEONE WHO HIDES IN THE DARK LIKE YOU DO IS A PATHETIC LOSER. AND DON ’T GIVE ME THAT B.S. ABOUT WHO YOU ARE NOT BEING IMPORTANT. WHEN YOU CALL SOMEONE A LIAR, A FRAUD AND A CON MAN WITHOUT REVEALING WHO YOU ARE, YOU ARE THE LOWEST SCUM ON THE PLANET.
    AND FROM NOW ON, THESE ARE THE ONLY KINDS OF STATEMENTS YOU ARE GOING TO GET FROM ME. AND EVERY TIME YOU MENTION ME OR MY WORK ON THIS THREAD, YOU WILL GET A REPEAT OF EVERYTHING I HAVE SAID HERE JUST TO REMIND EVERYONE OF THE KIND OF PERSON. YOU ARE. IN FACT, I WILL PROBABLY JUST CUT AND PASTE MOST OF IT TO SAVE MYSELF TIME. AND MAYBE I WILL DO IT ALL IN CAPS AND / OR GIANT SIZED TYPE TO MAKE MY POSITION CLEAR..
    TOO BAD YOUR HUEVOS AREN’T AS BIG AS YOUR MOUTH, OTHERWISE YOU MIGHT COME OUT OF THE DARK AND ACT LIKE A MAN. OOPS, I FORGOT. NO TIENES HUEVOS, SENOR EUNUCO. QUE LASTIMA, POBRECITO!
    If you want your thread cluttered with this crap, just keep it up. As Captain America said multiple times in the movies. “I can do this all day.”
  • BroMikey
    Hi Turion,
    You'll notice that not once since this statement of yours have I been uncivil, called you any name or insulted you.
    Hi bye except you are a known antagonist. A person who actively opposes or is hostile to someone or something; an adversary. Your actions are stamped on all of your twisted posts
  • bistander
    ... ​​​​​​ I will respond. I am always happy to be civil when I am not being called a liar, fraud and con man. ..
    Hi Turion,
    bi,
    SOMEONE ..LIKE YOU .. IS A PATHETIC LOSER.
  • Turion
    bi,
  • bistander
    Hi Turion,
  • Turion
    Did bi mention my name AGAIN? REALLY?
    bi,
  • ron48
    He was on there for years proving point99 wrong on every measurement of input and output that point99 asked him to do and has since moved on from his rotary transformer. Do some research. He now is on a private forum.
  • bistander
    Hello ron48,
    What will I say? Same thing as I've been saying to Turion for 6 years or so. "Prove your claim". Can tinman do that?
    Actually, I hope this tinman guy or somebody does do it. I know Turion is not the real thing, nor is Thane H. I doubt tinman is, but I have seen some good debunking demonstrations by him. I have viewed a couple recent videos by him doing torque measurements but have not seen an output/input proof, although I suspect that he can fool me on video. And yes, I agree, some good brains and benchwork at OURdotcom. It's premature for me to decide on that one. Let's see how it shakes out. At least tinman doesn't act like a child and answers members questions.
    The world could use a nice compact free energy machine, and so could I.
    So are you replicating tinman, or Turion?
    Edit:
    The tinman thread is on OUdot com, not OURdot com, right?
  • BroMikey
    He is alright I guess. Tinman knows way more about lectronix
