For what it's worth, something I posted on another forum taken from online comments by NZ Maori, John Myatt. Myatt was among the Maoris who hosted Stan Meyer, when he gave them the plans for his WFC technology. I make no claims, but offer it for your consideration below.
Bob
Bob
Quote
The key to the Stanley Meyer fuel cell lies in the "Tesla Choke" that uses "Tesla's Regenerative Effect" to effectively recycle charge by recycling the Back EMF of each + pulse to add to the next + pulse. This regenerative effect in resonance essentially cascades the input charges to 1000's of volts greater than what you actually input into the water capacitor.
I use a Torroidal Core 1.50 inch in diameter, 0.25 inch thick, 200 turns of 24 gauge wire, 600 turns of 36 gauge wire with a blocking diode to isolate the impulses. I feed this torroid with a rectified 260 Volt Variac transformer switched using a circuit and only use about 110 Volts of this. I use a Stanley Meyer Capacitance calculator (WFC v1.0) and then use an online Tesla Inductance and Capacitance equations calculator to determine the resonant frequency of my fuel cells.
The 1 amp is restricted on the Tesla Choke, consumed by a light bulb before entering the Fuel cell and lastly is annihilated within the fuel cell itself because the input signal is 180 degree's out of phase in resonance. What your left with is PURE + & - charge without the magnetic (Amperage) stream. This pure charge without amperage is what rips apart the molecular structure of water gravitationally into its Hydrogen and Oxygen components.
The method of operation of a Fuel Cell is similar to Tesla's anti-gravity field theory that uses an EM gravitational field transmitted 180 degree's out of phase with the Earth's gravitational field creating a Standing-Wave that cancels out the effects of Earths-gravity on the craft allowing the craft to be magnetically repelled from the Earths magnetic field. In the case of a Fuel Cell the covalent bond that binds matter together is cancelled out within the fuel cell by using a resonant signal 180 degree's out of phase which simply switches off this covalent connection allowing the attraction of Pure + & - Charge without its magnetic-(current) losses to rip apart the water.
To cancel out:
Magnetism- the Hot electricity with its magnetic component passes itself at a 90 degree angle leaving only (Cold) pure charge without its radiating magnetic field component. Cold Electricity is also known as negative resistance.
Covalent Bond of matter- a pure charge Cold resonant signal is transmitted 180 degree's out of phase so that the signal passes each other at a 90 degree angle, pure charge can then rip apart matter into its elements.
Gravity- the EM gravity field with its hot magnetic component is transmitted 180 degree's out of phase with the earths gravity field so that the signal passes each other at a 90 angle leaving the magnetic field of the craft to be repelled just like a magnet from the earths own magnetic field.
I haven't upped the voltage in this demo because I know people will just kiss my ass to no end. This video only demo's negative resistance to show that it is possible to have a amperage restricted reaction... I don't give a Poo if anyone understands this simple tech.
The HOT magnetic component of electricity is what enslaves mankind. The only reason we have the magnetic component in our electricity grid is because it can be measured as it radiates a magnetic field. This radiated field is measured and this is how the power companies bill us. When you buy electricity you're actually paying for is its magnetic field losses to surrounding space- this was designed into the system more than 100 years ago so that our energy expenditure can be metered. There is a secondary function of radiating a magnetic field in that as we consume power we are radiating more losses to surrounding space, so we have to buy more power. For example the Pentium chip in your computer, as this heats up it actually becomes less efficient and consumes more electricity as it radiates more losses in the form of heat to surrounding space.
John Myatt
Source: VIC "Tesla Choke" "Tesla's Regenerative Effect"
To cancel out:
John Myatt
