Magnetic Diode
  • #16
    AC
    Originally posted by seaad View Post
    1 My own snippet from your sources/ pics above. Pls correct me if I'm wrong.
    And W. Paint.
    2 Yes agree, but not exact. A moving rotating conductor and at the same time a short "coil"?, rim to the origo axel.
    But again no flux linking. Only one coil! AND DC!
    Idea: And DC! Why not AC? Lets chop, chop the DC and make AC. Now we can link the flux to another coil.
    Regards Arne
    Hi Arne,
    They've been using AC for this. Tests were done at 9, 30 & 65 Hz using a signal generator to the primary coil.
    Go to the link gyula provide and chick on the pdf download, it's in the upper right side of the screen. It gives you the article plus several additional documents containing calculations, graphs and test data. Cool stuff.
    Lorentz reciprocity establishes a stringent relation between electromagnetic fields and their sources. For static magnetic fields, a relation between magnetic sources and fields can be drawn in analogy to the Green's reciprocity principle for electrostatics. Here we theoretically and experimentally show that a linear and isotropic electrically conductive material moving with constant velocity is able to circumvent the magnetic reciprocity principle and realize a diode for magnetic fields. This result is demonstrated by measuring an extremely asymmetric magnetic coupling between two coils that are located near a moving conductor. The possibility to generate controlled unidirectional magnetic couplings breaks down one of the most deeply-established relations in classical electromagnetism, namely that mutual inductances are symmetric. This result might provide novel possibilities for applications and technologies based on magnetically coupled elements.
    • #17
      Thanks bi.
      Catched it. Now to the hard part. To grasp it.
      PS : A quote from that doc.
      "Note that this mechanism is intrinsically lossy; one
      needs to add energy to the system in order to keep the
      conductor moving at constant velocity and overcome the
      magnetic friction originating from the induced eddy currents"
      • #18
        Hello bi,
        What I have highlighted is what Dave has been trying to tell you in his own way. If you wind the coils properly and get the rotor up to the proper speed then you can induce power into the coils that does not load the motor. His tests conducted over the last several years have proven this to him. I don't have the financial resources to wind the large multistrand coils that Dave found it was necessary to make in order to see the effect. So I can't confirm this for myself, but this article sure seems to do just that. You really need to read his posts again where he describes how to wind those coils and how he thinks they work. The scientific evidence in the article you posted is probably a more accurate way of describing the effect, but Dave has tried many times in his own way to describe the same effect.
        Respectfully,
        Carroll
        • #19
          Mistake
          Hello bi,
          Respectfully,
          Carroll
          citfta,
          I see what you're saying and a first impression of the article which I posted, but upon further investigation, I realize my first impression, and probably yours, is mistaken. The phenomena explored (discovered?) by these researchers is quite different than what Turion thinks he's done. I believe there is a long way to go before this new research is verified, validated, accepted or proven. But at least these guys, unlike Turion, present all the data and analysis for review. Short of proving their claim, they at least support their claim with evidence, not just tell the world to build it to see for themselves, because they disassembled the apparatus and have it packed away.
          As far as Turion's tests proving things to himself and his explanations, in my opinion, it mean nothing. If Mr. Turion would do similar analysis and data presentation as we see from these researchers, I could then take him seriously.
          Thanks for your interest,
          • #20
            No room!
            When you consider the new definition of a kilo sort of involves the
            principles of a generator there's absolutely no room for cheating
            nature.
            The kilogram, ampere, kelvin, and mole will then be defined by setting exact numerical values for the Planck constant (h), the elementary electric charge (e), the Boltzmann constant (k), and the Avogadro constant (NA), respectively. The metre and candela are already defined by physical constants, subject to correction to their present definitions. The new definitions aim to improve the SI without changing the size of any units, thus ensuring continuity with existing measurements.
            Please put me right if my assumption is wrong.
            John.
            • #21
              "properly placed" hmm where did I heard about it ?
              • #22
                Not a thing.
                Speeding up under load is meaningless........ unless you are exceeding
                100% efficiency!
                Unfortunately you can't do anything about the constants..
                John.
                • #23
                  Proof?
                  Originally posted by Turion
                  bi,
                  Myself and OTHERS have posted videos of coils speeding up under load when they are properly wound and the rotor is at the correct rpm. What more "PROOF" can we give you until you build it and see for yourself.
                  Please provide evidence that your "speeding up under load" is at all relevant to this discussion, or that it has ever been shown to affect the machine's loaded performance at rated speed.
                  • #24
                    What would that prove?
                    AGAIN, I am in the process of moving my shop. Once I get things set up at the new house I will be more than happy to prove this point, even to YOU. It is simple. Run the motor turning a rotor with magnets on it WITHOUT any coils in place and measure the voltage, AMP DRAW, and rpm of the motor. Run the motor turning the rotor WITH coils in place and compare the amp draw, voltage, and rpm to the previous test. Then run the motor with those same coils UNDER LOAD and measure the amp draw, voltage and rpm of the motor. THEN tell me this is unimportant.
                    You have no baseline. What does a standard "well designed" generator pull at the same load and speed?
                    What about your reason why what you're talking about relates to the subject of this thread, namely M12 is not equal to M21?
                    • #25
                      Thank you
                      Now you want to compare generators? I thought the question was whether or not a coil under load can accelerate the motor that is used to turn the generator. My mistake. I'm out of here.
                      I have said a number of times that I didn't care about that claim as I see it being irrelevant. I don't know what the eventual ramifications of this new research will be, if any. And I have not read all the material which I have downloaded, yet. But from what I can tell, there is no connection between anything you've shown and this new research.
