Originally posted by spacecase0
Thanks, I was just trying to cover all the bases, but you're right, the evidence does say that a rotating magnetic field is a part of the over-all enabling design. I'm in agreement with you there.
we have seen others build devices to spin the magnetic field, and we know from them that they do alter gravity.
here is the test setup that wilbert smith made
Gravity Control Apparatus
and here it the text of him talking about what he did and tried to get stronger results.
Gravity Control
edit:
also, forgot to say earlier,
you can get the cool air effect around an ionic breeze air purifier as well.
edit again:
here is more info on the spinning magnetic field that someone else has done
William J. Hooper: New Horizons In Electric, Magnetic And Gravitational Field TheoryLast edited by spacecase0; 01-23-2019, 09:51 PM.
Both the Alexey and the ARV appear to be using a rotating magnetic field, though this is not as obvious in the case of the ARV, hence the previous illustration depicting how this may be done. *Notice I'm making the assumption that the ARV's magnetic field actually rotates as it may not. It could be that an anti~ferromagnetic ring is instead used to simply flex the magnetic field as part of the primary control system, or it could do both, we just don't know enough yet to be able to know for sure.
This simplified illustration should help to see how the rotating magnets in the Alexey are working in a similar fashion to the ARV. Unlike this illustration, the real interactions between the rotating magnetic fields in the Alexey are considerably more complex, and which I think it is difficult to imagine work to the benefit of the machine. Again, I repeat, the only way you can make sense of these machines by way of understanding they are accessing/producing a counter-spacial energy field. The machines alter their immediate local medium, placing themselves in a counter-spacial energy field, and then by way of forming a false mass the medium in which the machine resides can move towards the false mass at the speed of counter-space, or instantaneously, which is finely controllable to a high degree.
Now, the reason I'm almost positive that the above illustration is at least somewhat right is that we have one vital and perplexing clue that was told to Mark McCandlish by the viewer of the ARV.
That clue came from the statement that the immediate surrounding air around the ARV was significantly cooler than the rest of the air in the hanger.
Counter-space, or Zero Point, is very cold. This anomalous feature of an un-explained atmospheric temperature variation is a strong indicator that the medium in which the ARV resides is a counter-spacial energy cloud. Further, as stated by Wheeler, one way to change/alter the relative graviational weight of a mass is by altering the medium surrounding the mass. It seems pretty clear to me that the ARV and probably all other UFO's are in reality altering their local medium.
" he said that the coil section and capacitor plate sections are both embedded in a type of optically clear Herkimer Quartz diamond. The capacitor plates, he said, are a foil lamination made of a Dow Chemical alloy (AZ31-X) that is 95% magnesium and 5% zinc, bonded with molten bismuth, then skinned in a thin copper cladding."
Dow AZ31-B is a common magnesium alloy.
"I agree with Mark McCandlish that the vehicles are electrogravitic in nature and that the capacitor plates at the bottom of the vehicle, which are divided in 24 sections, function as electrogravitic thrusters similar to the gravitater capacitors developed by T. Townsend Brown. There is also a coil of many turns of thick copper wire positioned near the top of the frustrated cone hull."
It's not that I actually disagree with Dr. Paul LaViolette, it is that I disagree with the notions as to what these "electrogravitic thrusters/gravitators are producing/accessing/tunneling in to, and so in the supposed explanations of what is transpiring with conventional explanations the entire understanding of the aether is being missed as the driving force. It's like it is invisible to these guys, and it probably is because the whole notion of what it is, where it is, what it does has been almost completely scrubbed from the collective memory of living beings.
Ultimately, the ARV cannot actually be working as described as an electro~gravitic space craft because space is almost entirely a vacuum and there is nothing for such a propulsion system to work off of. Space is not a lattice work of points but rather a void. The only way an electro-gravitic drive can work is if it is actually doing something which is inducing an interaction with the Aether by way of perturbance: Wheeler has accurately described the Aether as a hyper-velocity dielectric energy field and gravitational weight as a variable.Last edited by Gambeir; 01-18-2019, 02:17 PM.
Hmm...well unfortunately I've never spent any time studying science history, but I do know that just as the Nazi's came to power some people whom one would think would be natural icons for the so-called occult science of the Nazi's were instead persecuted, and so the only way I can make sense of this is this signals the beginning of a project to hide real science.Originally posted by spacecase0 View Postthe models that work show it has to be a viscous and non frictional aether. The books by Carl Frederick Krafft go into this in detail.
so it looks like all the aether theories were gotten rid of because a few of them modeled it wrong.
Hmm....I must have somehow missed that one. If you find or remember where that's brought up drop me a message or whatever.Originally posted by spacecase0 View Postwe do have one clue were,
remember they were annoyed that the craft worked well, and could be made larger or smaller, but they said if you changed the design at all, it no longer worked.
and that means that every part of it is doing something that is needed.
Well maybe he will but he is a son~of~a ****Originally posted by spacecase0 View PostKen Wheeler liked Carl Frederick Krafft because he was an inspiration for Tesla. So I now suggest the same thing that Ken Wheeler did: Read the books that inspired. If you want to understand Ken Wheeler better, read Carl Frederick Krafft. It will be worth your time to read. And because Ken pulled them from his website, and I have no where to host them, I can email the best one to anyone that wants it. and I know Gambeir has a copy as well, so he might email it if asked as well.
Yea, I know...you're right of course but I think I need another lifetime to do this halfway right as opposed to almost completely wrong.Last edited by Gambeir; 01-18-2019, 01:32 PM.
Originally posted by Gambeir View PostYou cannot understand the ARV or any other UFO until you understand the basic ideas which underpin the Aether theory and there is certainly no better expert on this than Ken Wheeler at the present time.
This is the real science, the hidden science of the the breakaway civilization, it's the true physics which Henry Stevens wrote about, and it is the true science which was marked for death and denial with the rise of the military industrial oligarchy.
Scientists Are Planning a New Particle Collider That Absolutely Dwarfs the LHC
The proposed accelerator has been given the name Future Circular Collider, and if it ever gets built it will dwarf the already gigantic LHC. The FCC is a gigantic ring more than 60 miles in circumference, around four larger than the LHC.
Al
you really got me thinking here.Originally posted by Gambeir View PostYou cannot understand the ARV or any other UFO until you understand the basic ideas which underpin the Aether theory and there is certainly no better expert on this than Ken Wheeler at the present time.
I have several notebooks filled with hours of research notes and drawings I've made over the course of a number of years. I even purchased blue prints of the ARV direct from Mark McCandlish. I've been on this for a while. Above all else, there is no logical way to explain the ARV with conventional methods, and here I'm just talking about explaining how it floats above ground in a protected hanger, never mind the fact that it's also supposedly super~luminal.
There is no connection here to electret technology which should be in it's own thread.
Ken Wheeler liked Carl Frederick Krafft because he was inspiration for Tesla.
so I now suggest the same thing that Ken Wheeler did. Read the books that inspired.
if you want to understand Ken Wheeler better, read Carl Frederick Krafft.
it will be worth your time to read.
and because Ken pulled them from his website, and I have no where to host them, I can email the best one to anyone that wants it. and I know Gambeir has a copy as well, so he might email it if asked as well.
we do have one clue were,Originally posted by Gambeir View PostA short list of hypothetical space drives I tried to make work in the ARV design which fall under conventional physics.
Intertial Force Space Drive
Magnetic Worm Hole Generator
Monopole magnetic generator
MAGVID Hyper Ionzied Air Propulsion Types.
Open Field Gravito~Magnetic Ionized Plasma
Closed Contained Field Gravito~Magnetic Ionized Plasma
Light Speed Altering rotating magnetic fields
Now take any one of these possible explanations and then try to fit them inside the ARV design while making sense of the design itself. For example, the huge so-called capacitors in the base of the ARV have to be explained logically. One possible conclusion is that these so-called capacitors actually produced a magneto~electrical effect, and here an possible answer might seem to exist, as shown by this statement taken from one of my notebooks;
In some Anti-ferromagnetic materials when their crystals are placed in a moving field, either magnetic or electrical, these crystals will produce a proportional equivalent moment to the moving field. *I. Dzyalushinsky; A thermodynamic theory of "weak" ferromagnetism of antiferromagnetics. Journal of Physics and Chemistry of Solids (1958)
However, the problem with all these notions is that you really can't explain the machine, not the totality, and so it's cobble here and there but ultimately there really are no sensible logical explanations, especially if one were to then follow up by asking yourself how is it that anyone would dream of designing such a machine if these were the only tools in the box? That is to say, that if you only have the tools allowed under conventional physics then the design of the ARV is very hard to come to terms with.
Originally posted by Gambeir View PostAnti-gravity begins with having some idea where gravity comes from. Now, if one did not know any better than there is only one theory for gravity according to the ever helpful Wikipedia.
Never mind that this theory is demolished with the application of common good sense.
Fallacy of Gravity & Weight. Everything is electrical
Explaining what SPACE is rationally: Tesla denied Relativity & nonsense about SPACE
Gravity & Anti-Gravity. Fundamental principles via Platonic Logic
https://www.youtube.com/watch?v=vYpl...H2tE4mt_K&t=0sthe models that work show it has to be a viscous and non frictional aether. The books by Carl Frederick Krafft go into this in detail.However, those models were overthrown because most of them lead to an unacceptable amount of drag, which is not observed. Other models are violating the energy conservation law and are incompatible with modern thermodynamics.
However, the problem with all these notions is that you really can't explain the machine, not the totality, and so it's cobble here and there but ultimately there really are no sensible logical explanations, especially if one were to then follow up by asking yourself how is it that anyone would dream of designing such a machine if these were the only tools in the box? That is to say, that if you only have the tools allowed under conventional physics then the design of the ARV is very hard to come to terms with.Last edited by Gambeir; 01-17-2019, 07:34 PM.
