Here's another great video. Be sure to look at his other video's as well. Something might speak to you personally. This guy only has 443 subscribers if you can believe that. Really great job he has done with these videos.
* Just a note here that some serious corrections were made to illogical statements as well as making some minor additions. Therefore if it made no sense before then it might make more sense now.
I've been studying the patent linked below, and among other things there's a connection here which I think goes back to the late Joe Parr and his pyramid research, and which also seems to be somewhat connected to what's going on with ReGenX Coils.
http://www.energeticforum.com/forum/...witching/page2
Craft using an inertial mass reduction device
A craft using an inertial mass reduction device comprises of an inner resonant cavity wall, an outer resonant cavity, and microwave emitters. The electrically charged outer resonant cavity wall and the electrically insulated inner resonant cavity wall form a resonant cavity. The microwave emitters create high frequency electromagnetic waves throughout the resonant cavity causing the resonant cavity to vibrate in an accelerated mode and create a local polarized vacuum outside the outer resonant cavity wall.
What is described in the patent purportedly explains how the operation works, but you have to realize it's doing this only in so far as it has to be correct to meet the requirements of officially approved science, and in order that the patent office shall issue a patent, and so whatever else may be happening is not described or contained in the patent.
A patent is above all else a story, and in this instance it a story about how to go about creating a vacuum which connects the outside hull of the ship to the imaginary quantum field, and the claim is it's doing so by purportedly creating a connection to the imaginary quantum field via microwaves and V shaped forms using a high frequency vibration, and apparently between the double hulled vehicle, and that vibration is then transmitted to the exterior skin of the vehicle and which then results in that part of the outer hull to connect with the quantum field which is further alleged to be a vacuum. This seems to be the basic whole explanation given for how this vehicle supposedly works.
The question is; does it make sense? I suppose that if you think the Quantum Field is real and that it is also a vacuum it could be true, but if on the other hand you think that a vacuum is the result of physical interactions then that explanation is pretty suspect, because the explanation given actually does say that there's a vacuum energy field all around us, which is substantially different from saying there's a hyperspatial inertial fluid all around us, and which can be coaxed into producing what could be interpreted as giving rise to a vacuum.
We have already established by reasoned logic how the Aether moving through matter would rationally create a chaotic high frequency state in the local environment, and so this conclusion stated in the patent that the surrounding field, claimed to be the quantum field, is one of a high frequency vibration produces no surprises, but examine the stated cause and effect in more detail and there questions as to how this takes place to produce movement in the machine arise.
In the patent it makes a couple of of other interesting claims to keep in mind while digesting; such as the directional control is induced by vibrating the exterior skin by location, to induce a direction of travel or movement, but then it states that the vehicle has or may have a rotating nose cone and it does this without any explanation. That information is simply inserted.
Further, it is unexplained how producing a vibration on the exterior skin of this vehicle doesn't also produce what one might otherwise assume to be a self canceling vibration throughout the whole of the vehicle. You would assume that the purpose of a double hull involves isolating the interior from the exterior, after all, is a double hull necessary to produce a high frequency vibration to make this imaginary connection to the imaginary quantum field? So among other things, this leaves the question whether or not the whole vehicle is itself involved, as opposed to that one stated in the patent, and which seems to imply that the high frequency vibration is only transmitted to the exterior skin. If that's the case then how so?
Never mind the absurdity of the whole notion that the vehicle is supposedly accessing a vacuum, after all we aren't in outerspace, we are here on planet earth with an atmosphere, yet the called for explanation of the quantum field says that this supposed field is itself a vacuum which can be accessed by inducing a high frequency vibration. That's not logical or even remotely sensible.
Nevertheless, to continue with this idea that a vibration is carried to the outside hull, without somehow isolating the interior hull, and by no explained means other than the depiction of V forms inserted between the hulls begs logic, because In reality critical thinking tells us that vibrations are by nature conductive, and so how then is this connection to the imaginary quantum field produced by the creation of high frequency vibrations on the outer hull, and when no explanation is given for that without explaining why the whole machine isn't itself vibrating. IMOP the patent really doesn't explain how this machine works. Nevertheless, one last key point which is included is that through these means the net effect is to produce a vacuum. So it looks like there is at least one word of truth in the description.
So now if there's any truth whatsoever to this, and that it works at all, it's to be found in the concept of how to produce a vacuum. Normally I would dismiss the whole thing as complete drivel except for the startling fact that I've seen one for real, so I know that somehow, by some means, that something that looks starkly similar can work and does exist, and therefore some explanation must exist, but I seriously doubt whether the explanation given is the right one.
Now it is true that a high frequency vibration is conductive and so what is it conducting? We already understand that turbulence can produce a vacuum; such as a V shape in a moving stream produces turbulence: It produces vortices specifically. It is also true that a high frequency vibration will allow a melding with the hyperspatial dielectric field, a field which was already conjectured to exist in a hyperspatial state of chaotic flux, and this is the same field that has erroneously been conjectured to be one of so called quasi-particles.
This has taken place since it was not recognized previously that the dielectric substrate which forms a magnetic field, and which is now at least partial visible as a coherent field does prove the existence of the Aether, and does indicate an unknown substance is the Aether.
So another reading of this patent might go a bit like this: A vehicle consisting of a double hull, partitioned by means of paramagnetic and other materials, and which are formed in to V shapes, to include pyramids and which are to be understood as constructs of tetrahedrons, and arranged so that their bases face inwards, and when immersed in a high frequency field, such as to include microwaves and other high frequencies, become by consequence of their natural form the transducers of a dielectric counterspatial plane of a hypervelocity materium, assumed to be something akin to a fluid but intrinsically one of inertia, and here taking notice that this plane of inertial energy is what underpins our reality, otherwise more commonly known as the materium.
The arrangement described in the patent actually produces a de facto a macro scale synthetic crystal, and which when vibrated produces a sustained vacuum, resulting in a vacuum polarization, and creating a polarized pressure which is linear, as is typical of a stressed quartz; whereas a static dielectric field is demonstrated by a magnet as a self cycling dielectric field passing through a focal point and thence cycling through that point in a static manner.
This is accomplished because the surrounding materium is in an agitated state of fluxing vibrations, such that when a like nearby high velocity vibration is induced by a high frequency EM wave, then, the vibrated matter facilitates the transfer of the motional inertial force surrounding the object through it's walls, and in so doing this inertia containing substrate flows against the forms of the tetrahedronal and or V shaped constructs. In so doing, this materium is transferring inertia to matter as the materium itself follows the crystal form, and it is apparently further producing on exiting these forms a vacuum as a consequence of turbulence, known as vortex's, and which forms behind the geometric shaped patterns, whether they are tetrahedron shaped, folded V shapes, or pyramidal, and these forms are capable of producing the creation of a vacuum by producing turbulent vortexs in their wake.
Since V shaped patterns and or other constructs of tetrahedron are arranged coherently they then produce a coherent action, which here is a vacuum, and which makes a directional control model possible, bearing in mind that this explanation describes only part of the possible consequences which can result from this action.
Ken Wheeler says, in effect, that compression of the magnetic field results in a loss of weight, which is logically correct since this compression effectively reduces the scale of mass of the object, but in doing so the compression is pushing the inducted dielectric field from our side of counterspace back towards, hence, in to counterspace itself. In other words, a pole flip produces a pop~ with pop being somewhere's else mainly.
Compressing the magnetic is effectively squeezing the object down in size (though not really) till it goes "pop!" and it (whatever it may be) is suddenly on the other side in and in counterspace. This pop (is similar to) what happens when quartz and PZT materials become so pressurized that that they explode with a sudden discharge creating in the wake of this discharge a vacuum, or what is then called vacuum polarization: Sudden discharge with polarity. Compression to pop is what is shown in Starwars when the space ships make the quote; "jump to hyperspace." Worth noting that Lucas uses that term because hyperspace is counterspace.
Joe Parr was involved in experimenting with how a magnetic field interacted with a pyramid form to produce a propulsive force, but I also think he was doing a great deal more while trying to decipher how magnetic fields and pyramid shapes could then result in this magical like progression that could result in a vehicle seemingly vanishing into thin air.
Here is a super video showing the inwards compression in action. Dark banding is in my opinion key to grasping the inwards compression.
When an object pop's to the other side it leaves behind an artifact, a ring which looks like a smoke ring, but it's not smoke. The ring is the outline of where light is void; a black hole as shown by Ken Wheeler using a ferrocell lens. The image of Dealy Plaza with it's smoke ring hanging over Dallas Texas may explain why UFO's were classified higher than the H-Bomb.
Notice the so called mysterious smoke ring in the upper right corner. Then google mysterious smoke rings. See what ya get. * Finally, this photo was recovered after, and only after an anonymous phone call alerted a local new station to a pile of photo's left under an overpass in Texas. This is not accidental. I said this at the beginning of this thread and it bears repeating; people have tried to tell us and they have continued to try to tell us in the only ways they can.
Lost_Dealy-Plaza-enhancedA2.jpgLast edited by Gambeir; 04-20-2020, 07:36 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
* Red Alert* The Book Burnings have begun. Rex Research now joins Keely Net as destroyed/blackballed information. It's gone people.
In the previous post some serious errors were corrected where the logic left the rails due to simply not seeing the errors; most specifically and importantly involving vacuum polarization. So it appears that in order to compress the magnetic field you have to create a vacuum, as opposed to supposedly accessing one which doesn't exist in the first place, and the vacuum is created by induced vortex's by geometric shapes interacting with the counterspatial dielectric field passing through those forms. The vacuum is not outside the walls of the vehicle, it is inside the walls of the vehicle, and which allows then the pressure of our space to compress inwards towards that of counterspace. This is what seems most logical to me right now.Last edited by Gambeir; 04-20-2020, 01:32 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
Originally posted by Gambeir View Post* Red Alert* The Book Burnings have begun. Rex Research now joins Keely Net as destroyed/blackballed information. It's gone people.
Are Milky-Way and Andromeda on collision course?
Al
- Likes 1
It should now be apparent that these patents contain explanations which are almost exclusivey artificial constructs. An artificial construct being a purpose driven designed lie. Like all lies there is an element of truth involved in the construct, which in the aforementioned involves a seemingly logical explanation as to how and by what means a device operates. However, subjecting the explanation to critical reasoning in a destructive format reveals possible incongruity with the stated cause and effect.
The alternative hypothesis offered is fundamentally superior since, among other things and by extrapolation of cause and effect, this intake of the hyperspatial dielectric field produces a void, which then provides an explanation for the overall dark appearance of triangular vehicles.
This darkness (Black Triangles on my fridge) is produced by the induced dielectric field being inducted across the whole body and resulting in a voidance of dielectric substrate around the body.
Further, the explanation is also in keeping with the explanation which is necessary to explain spherical and disk objects which are either completely immersed in a boiling cloud of dark smoke like substance, or which have bands of darkness which obscure their overall appearance, and this boiling smoke like effect is the result of a voidance of the incoherent dielectic substrate which surrounds us and which we herto have recognized in condensed form as magnetism. This intake results in a voidance of the hyperspatial material in the immediate area as it is drawn out of the materium by a vacuum, with that vacuum then creating a potential to lead back to it's origins in counterspace.
It should be realized that the design offered in the aforementioned patent is a testable design within reach of existing off the shelf hardware. The biggest issue is safety while working with a high energy system such as a microwave and then what type of materials are best suited to experiment with.
Last edited by Gambeir; 04-20-2020, 08:50 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
I have an archive copy of them.Originally posted by Gambeir View Post* Red Alert* The Book Burnings have begun. Rex Research now joins Keely Net as destroyed/blackballed information. It's gone people.
but then archive dot org as it all as well
- Likes 1
Yea, but are the CD's from Rex Research still available? The archive has some stuff but..but..the way this is shaping up I'm wondering about the coming future.
They are buying up sites and burning the information right now (see the far right fresco). Pushing another button to delete the archive is even easier. Who will have that
information in another generation?
Check out the thread at stolen history on the Bank of America Fresco's for more Spacecase, but as you and I know, these fresco's seem to speak of information we both were aware of a long time ago. https://www.stolenhistory.org/thread...he-reset.2080/
https://www.stolenhistory.org/attach...cos-jpg.36136/
Seattle's West Seattle Bridge closed till 2021 and maybe forever. This is a very big deal and indicates the mantel is flexing.
Also this follows another previous major failure https://en.wikipedia.org/wiki/I-5_Sk...ridge_collapse
These failures speak towards on~going earth changes. Possibly a mud flood lies in the future or something similar?
Second, these greedy idiots ruling over us just cannot help but to try to push it till until the golden goose dies. Anyone with even half a brain could see that if this Covid 19 situation goes on till August, which is likely IMOP, the ridiculous sized monetary stimulus won't be nearly enough and what comes from that will be rioting and a breakdown. Anyone with a brain who wasn't a complete sociopath would have implemented emergency war measures. They would have provided stimulus that people need. Suspend mortgage payments, suspend taxes, freeze and suspend rent for renters across the board, suspend all state and federal taxes, ect.
So what that if these thieving crooks won't have money as usual looted from the rest of us for a year. Screw them for once. Those are the measure which anyone who isn't a complete and total sociopath would see is necessary to weather this situation. However it's not about us any longer, remember the space ships, the breakaway civilization, that's what it's all about and we are their slaves now and the military, the military...who are they kidding, whom are the really working for? National security? Really? What blood oath have our military leaders taken? One that resembles the one taken when the German Army swore allegiance to Adolf Hitler? I mean seriously give me a break from the fake patriotism bleeding us dry to build another civilization light years more advanced and to then to allow these monsters to rule, let alone live, and all the while claiming to be patriots?
https://www.stolenhistory.org/thread...e-3#post-48683
So if you're following the predicatable, the looting of, terrorization of, and abuse of the population leads to another by their own hand because what comes from this is a cry for another Hitler, another Stalin, to right the wrongs as it were, and that's what I'm afraid of the most, and that too is depicted in those bankers fresco's, and guess what? They already have their man picked, just like they had their other men picked out before the revolutions that brought them to power, but it's all the same story, over and over, with subtle twisting and it is a planned history which awaits all of us.
$1,000 dollars is not going to be nearly enough, especially for people whom aren't receiving benefits like the children of so many elect and other chosen ones normally and routinely do. I don' think this so called stimulus even remotely begins to cover the needs of average everyday Americans, not without doing what any rational and sensitive person would have already done on top of any and all possible financial help, and which is to do at least those other things previously mentioned. There is just no possible way that a thousand dollars is going to save these people and whom make up the golden goose, so this is a predicatable coming economic disaster: Starving families and then banks and land lords moving to evict? Like yea, a $1000 dollars is going to save them huh? These idiots, complete idiots ruling over us, they have so much that they have no clue how desperate and miserable the lives are for tens of millions because of who they are and what they have done to this nation: Should all be rounded up wholesale like they were in Russia after the fall of the Czar right, and yes that's right alright, but who will be rounding up whom and under what pretexts? See they know and they advertise that they know, only they don't call it advertising, they call it Art instead:Got bullets?
Liars on the news spewing filthly lies instead of the truth's they themselves probably suspect but are forbidden to speak. There's a whole laundry list of out of control organized crime politics which is leading the US right down a highway that leads to a broken bridge, a disconnect between these jackasses in politics and the everyday lives of people struggling to make sense of our world while trying to survive, and all the while being lied to, robbed, raped, and in some instances murdered and all for a plotted political end goal. We are being lead down a highway to destruction.
It's no surprise 33 million Germans elected Hitler after having been reduced to mobs chasing pick up trucks tossing bags of potatoes thrown out of the back. After that experience anything would seem an improvement and don't ya think the bankers know that already. They can read history just as well as I can.Last edited by Gambeir; 04-21-2020, 09:00 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
I have some thoughts on that post.
first is that anyone can use the 1000 $ to set up for what is likely getting ready to happen,
and rent is not the best way to spend that....
you know what is about to happen
there is a reason "they" are giving up on most people is that the earth has a catastrophic cycle
go learn if you have not seen any of this before
so,
"they" leaked ideas of how to build things to get you off the planet
they can't save everyone,
and I know from trying that most people get very upset when you tell them what is likely going to happen in the future.
so I am not really that upset at the people that are in control.
I suppose that I have likely known what "they" know for a long time now.
yet people I share this with keep asking me the same question
how much money will it cost to build this
they don't want to spend 25 cents more than they have to
it would have taken gas money to the nearest town to even get a quote a year ago...
I did not have that money then...
I find the entire thing funny now.
greed is one of the 7 deadly sins.
I truly don't care about money,
I do value some of what it can get,
this disconnect with potential funding is deeply amusing to me.
the people with the ability to fund research have no motivation to fund such research
they already have enough money to stay warm in the winter.
they already have enough money to have food.
but they have no idea what is possible,
and what they could have done.
it is clearly fate or clearly created karma...
not my job to figure this out
but would seem as if I am here to show them to themselves just how broken they really are.
at this point I think it is funny
I see 3 ways to deal with what is in the future
the popular option will be to die.
another option is to go high tech and flee the planet
the other option is to set yourself up to not need much from the outside world.
homesteading is hard, homesteading with super high UV on your garden is lots harder.
it use to be that people only lived where there was water.
now people have technology to get them that water.
anyway, getting ready is going to be hard.
securing a water supply is not easy for most people,
growing your own food is harder for most people
setting up for odd sun activity is harder.
but very possible for many people on a 1K$ budget.
remember that money will not be a thing when things get bad, so money is not the thing here, use what you have now wisely and you can put yourself way past most people.
right now most people don't have checkpoints to stop them from driving out of a city.
things are not that bad yet.
so, in the grand view point of things,
we are not at the best of times,
but we are far from the worst (yet)
anyway,
we have all the information now.
however you use it and what you can manage to do with it is going to solidify the future.
I am reminded of the text "ready player one" that I have seen so many times.
there is no save game here,
there is no reset.
go
good luck
- Likes 1
Observe the rational beauty in the simplicity in Aljhoa's logical deduction.
Al
So now do we finally realize how much we are being lied too?Originally posted by aljhoa View PostMilky Way is "flying" in aether, so is everything else, thus where else can useful gradient can be created if not internally?
Patents involving the science of Einstein and Quantum Physics simply cannot be right, they cannot be telling you the real physics behind something, and on top of that those whom invent them don't even understand that their own explanation isn't even correct, such is the state of unqualified proofs, and yet quantum physics and Einstein are the only religions accepted.
The whole reason why approval is no longer based on a physical working model and demonstrated facts is because these models don't work~
The change from demonstrated fact to fantasy land fiction was made to facilitate the hijack; so that instead of demonstrated facts we now have approval based on an officially approved lie. Nothing criminal going on there huh?
What this translates to is that no patent along these lines is worth a wooden nickle, but that's not all because this so called theory of quantum physics was designed so that what is revealed in the thoughts of one person, and whom is using Quantum Einsteinian Physics to explain an operation, can then be crossed back over to be applied to the true physics of the Aether, but only if you realize that the explanation given is false.
You pay them to tell them how it works.
That's what this actually means. This shows that the system operates under a criminal control model, or organized criminal network, and which has manifestly constructed false models for the purposes of exploitation, and which of course begins with becoming educated. So first you pay them to become brainwashed and then you pay them to hand over any inventive creations, which probably won't work because you don't really understand what's actually transpiring, and any that may happen to work won't actually be operating due to the described cause and effect.Last edited by Gambeir; 05-22-2020, 04:08 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
https://www.youtube.com/user/Suspici...able_polymer=1
so,
anyway,
there is no reset.
go
good luck
Not all of it, part of it, not all of it: Enough for a bit perhaps and for some it may be all.
As always thanks and I do not disagree which I'm sure you know as well."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
Look at the Tesla Double Cone Bipolar Coil in the link and recall that the Tesla Saucer has this same design as the artifact.
https://tesla-coil-builder.com/antig...lar-tesla-coil
Vortices are logically explained as a result of turbulence produced by the Aethers' interactions with matter, and those vortices are symmetrical with opposed spin. Simply look at the vortexs produced from the wing tips of heavy aircraft to see an example. Now you would think that when polarity is applied to a winding the result must be that the applied polarity has a rotational spin, or vortex, and which as a by product produces a vacuum that acts upon the Aether. Logic would seem to suggest the result is that the inducted vacuum of the applied charge acts on those vortices in the surrounding Aether with a like rotational spin. This is simply to say that a vacuum will move towards a vacuum and that the directional rotational spin state of a vacuum will combine with one which has the same rotation.
It's not enough to know that a vacuum is what you're after. One has to see the vacuum as gravitational force which creates mutual mass attraction. After that you have to figure out how to do this.
Last edited by Gambeir; 04-25-2020, 06:59 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
This idea of Shaw's that the Aether isn't moving at the hypervelocity, and which I have previously conjectured, even insisted it moves at, might be more correct than I was willing to imagine possible. It appears that I'm in error and that Shaw may be right about this.Originally posted by aljhoa View PostThe author’s article, The Cause of Gravity: A Concept [Phys. Essays 25
Al
Reconsidering this issue the logical conclusion is that the Aether doesn't even actually have to move at all, even though it does, and that is because it's a dielectric and so anything inside of it can and should be propelled by the dielectric field, which simplified can be seen as being a magnetic field, so the velocity of magnetism is what the dielectric medium is capable of producing, which means it is then capable of instantaneous transport and through interaction with all matter.Last edited by Gambeir; 04-27-2020, 11:14 PM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
If you're out there some~where's and fooling around with ideas, then I think we have to revist Dr. Desalvo's site and take another look at Joe Parr's work, and then consider it in light of what we now understand, and this is because we can see that, despite his certification as an electronics engineer working for some undisclosed private contractor in Greenland and in Antarctica, what Joe appears to have been working with in his experiments was Aether Physics. Certainly doesn't look very conventional and I think this is related to the tetrahedron/black triangles. Notice that Joe Parr called this his gravity wheel.
Joe must have either understood or theorized that surrounding space is made up of an incoherent reverberating dielectric field. We can now see that's clearly depicted in his experimental test rigs.
The idea here is that Joe probably knew and saw some things we have only caught glimpses of, or at least some of us have, and so then if we consider that the patents previously examined are falsifications which are not actually describing the methodology of the machines true operation, then perhaps we can glean another insight by revisiting what little we have of Joe Parr's work.
The world's largest research association and leading website for information on the Great Pyramid of Giza, with an International Advisory Board of prominent researchers.
Last edited by Gambeir; 04-30-2020, 12:49 AM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
- Likes 1
Good for Alexey, this gives me a lot of joy quite frankly. Glad to see Alexey basically tell his critics to piss off.
I have to laugh though about the seeming need to submit this to a vacuum chamber. Not sure how much that's going to prove but the whole idea that ions could lift 20lbs of scrap metal is laughable given the design, but what do I know right?
Based off of these latest realizations I now think that the magnets, spinning as they are in a smaller orbital circumference than the charged aluminum plate, and having increased potential since they are in accelerated condition, and which Wheeler shows in video one of his series that the dielectric inertial accretion disk is accelerated and spun up with accelearation of a magnet, and as the magnets plane of dielectric inertial accretion is parallel to the HV AC charged plate that the whole of the rotation and acceleration acts upon the surrounding incoherent dielectric counterspatial field, with the result that the aluminum disk is assuming the function of an accretion disk, primarily because the aluminum is paramagnetic and so it too now also has a rotational magnetic field, one which is also coherent and which then acts as a driver acting upon the incoherent dielectric field which is comprised of the charges in the aluminum disk and that field is comprised of a HF AC field held in a charged air aluminum capacitor.
Remember that this paramagnetic aluminum material has accquired a rotational magnetic field and so it too has an accretion disk (which migh be artifically expanded via the aluminum disk), and evidently the end result is acting as an inwards compressor to accumulate an incoherent dielectric AC field and compressing the dielectric inwards. I surmise that then may be causing a vacuum pulling in the surrounding counterspatial dielectric field and allowing the pressure of our space to act then upon the whole device.
She runs out of juice once the HF AC field is deplented as that's the incoherent dielectric accumulator ....apparently. Seems so damned simple really but could be quite accidental given that there must be a cross correlation between the whole such that the power of the magnets, ect and so forth have an end result. Hopefully it's not extremely critical. Can't see how it could be highly critical. I think the main thing is to have a working theory and then with that you've got a fighting change rather than flying blind without instruments.
What do you think? I think this is what's transpiring and it fit's the model. Surrounding space is being taken in, compressed and that allows the spatial pressure to act upon the mass so as to make it massless as it's all being compressed back into counterspace: Something like that just as a seat of the pants flying theory.Last edited by Gambeir; 05-01-2020, 03:01 AM."The past is now part of my future, the present is well out of hand." Joy Divison "Heart and Soul LP."
