Originally posted by robur
In a Nut Shell what I understand is that gravity is the result of a vibrating incoherent magnetic field. When a magnetic, or DC field is crossed perpendicularly by a high frequency AC field, the product is an alternating or vibrating DC/magnetic field. There must be enough oscillation applied to enough DC or magnetism to result in an effective gravitational field change.
Essentially what I take from this is that you're making an incoherent dipole field and keeping it in an incoherent state through the application of an alternating current. This is likely related to the Alexey Device in how it operates and it's seems likely to me that the Woodward Effect might be taking place in the Alexey Device.
In conventional physics the Woodward/Mach Effect involves a high frequency alternating change taking place. This requires some interesting timing to make happen.
Woodward said his hypothesis is based on Mach's principle. Now understanding this takes some repetitive reading. At least for me it did.
"Thus, if the mass of a given object can be varied while being oscillated (*up and down) in a linear or orbital path, such that the mass is high while the mass is moving in one direction and low while moving back, then the net effect should be acceleration in one direction as the inertial drag of the universe upon the object varies as its mass varies."
https://en.wikipedia.org/wiki/James_...oodward_effect
The mass must be higher going one direction while returning in a lower plane going the opposite direction.
Question is: Does this, or can this hypothesis explain the Alexey Device?
Probably. Think about it.
