RE-EMF Charger
  • #16
    Hi all, Hi wistiti, the efficiency when using leds on the base, results were not as good for my setup, 94% and 114%.
    I am re-testing the original setup, to make sure of results again.
    Then i am going to try it without the capacitor.
    Then i will try with two, 1.5 farad capacitors in parallel, to lower even further, the impedance of spike collecting capacitors.
    Since, i am aware that the radiant spikes like lower impedance, for better accumulation.
    peace love light
    Ok sorry for that.
    I have never mesure the efficiency of these leed config... Thank's to you for taking the time for doing that!
    • #17
      Hi all, i think i am mistaken about the 150% efficiency.
      Somehow, my battery was plateauing at one spot and after i changed my discharge load to a couple yard bulbs in parallel, it revealed that voltage spot of battery hanging for a bit and not reflecting a true discharge of inputted energy.
      At least that's what it seems like, unless i find something that proves that wrong.
      I can say for sure, the capacitor increases the charge efficiency of this circuit.
      Sorry for jumping the gun.
      peace love light
      Yep! i also be many time fool by Batteries... no offence.
      With that said i continue to think that the re-emf charger is a really efficient one. My experiment with it show me that more you charge a batt with this circuit the more the batt charge rapidelly... Mabe something like people call conditionning...??
      Thank you again for sharing your experiment!
      • #18
        Hi mike, thanks for all the information, yes i have been looking at the advanced bedini sg handbook.
        Hi wistiti, about using the leds on base, i said my setup, it may boost efficiency in another setup, using different voltages, etc.
        So far, the corrected highest efficiency i have gotten with two capacitors in parallel, is 90%, with a non conditioned battery.
        Without the capacitors, i only got around 60%.
        Though it must be said, the bifilar coil, magnet wire gauge, may be too thin for efficient transfer.
        Still, i'm learning more things, as i make these experiments.
        Though in future, i need to hold back coming to conclusions, until i'm more sure about the results.
        One thing i learned from these tests, the flooded tractor battery, is not efficiently absorbing the spikes, compared to these low impedance super capacitors.
        Perhaps if the battery is conditioned as they say, it may absorb equal or better, the spikes.
        peace love light
