Motor Generators
  • Here is your pep talk for today, nevermind the scary wizard behind the curtain. I am the great and powerful.
    • So you admit you lied about the output of the Lindemann Attraction Motor. Glad you finally fessed up.
        yup i'm a liar, happy now? Dave you are a mess dude
          hey dave go to minute 2:10min to 2:20min you will see the math breakdown cop 8.6 so I lied when I said cop 8. The video lags poorly
          Do you agree? or is this all a fake equation? I guess Dr Lindemann lied also? So everybody is suddenly a liar cause dave can't do the math. Maybe we should build one first before all the name calling startsYou got to get rid of the brain farts.
          • Here is your math paper for the day stoney
            • This analysis of energy produced is NOT the electrical energy that comes out of the device that can be used to charge a battery or run your home, as you CLAIMED. It is a COMBINATION of the energy gained from the collapsed spike PLUS the mechanical energy supplied by the shaft. So VERY LITTLE of it is actual ELECTRICAL energy and MOST of it is MECHANICAL energy. How about YOU learn to analyze the data before you make claims.
                Yes that is true but my goal is to come up with a motor to drive the generator head with better than COP>1
                Let's dispense with the theater. I was thinking up ways to make 2 "S" rotors when I thought of bee bee's and magnetite pressed together by resin. I have these "C" shapes for the coils so my question is would the bee bee's and magnetic sand hold together at high speeds and would that get hot? probably should add some micro fibers to the mix.
                8 COP motor could raise the over all eff. and from what Peter said these motors have huge torque so that might over come a ton of cogging losses. COP 8 for the motor that generated power to boot. Not bad. So you finally watched the video?
                See what you put me thru to get you to watch this 17 year old video? Maybe the generated output won't run your house instead say all the electronics with generator lighting?
                What do you think about the "S" rotor? I don't have a stamping plant for stacking laminates and I need a solution.
                Also having an 8 COP motor means you can connect a conventional scooter motor to it to generate 8X the power you put in. With generator losses 6X. IT'S A GOOD GIFT LIKE THE ZERO FORCE MOTOR.
                The Murray ellipse could be cut with chop saw, maybe it's the same thing?
                The modified motor didn't even come close to this.
                • Belmont Powdered Metals featuring Holtite Alsil Grit, Iron Powder, High Grade Zinc, Tin, and Copper-Aluminum Applications.
                  Cast iron powder for 3D printers have silicon right in the mix
                  https://www.ebay.com/itm/13199961863...r=431346058913
                  Silicon steels are ferritic alloys of iron and silicon that have magnetic properties which make them useful in motors and transformers. The silicon additions improve magnetic softness and increase the electrical resistivity.
                  • 3D printed motor rotors
                    • Attached Files
                      • How 3D metal printing works $160,000
                        Soft magnetic composites (SMCs) were prepared from three different ferromagnetic powder particles: iron powder ASC 100.29, spherical FeSi particles and vitroperm (Fe73Cu1Nb3Si16B7) flakes. Two types of hybride organic-inorganic phenolic resins modified with either silica nanoparticles or boron were used to design a thin insulating layer perfectly covering the ferromagnetic particles. Fourier transform infrared (FTIR) spectrometry confirmed an incorporation of silica or boron into the polymer matrix, which manifested itself through an improved thermal stability of the hybrid resins verified by Thermogravimetric-differential scanning calorimetry (TG-DSC) analysis. The core-shell particles prepared from the ferromagnetic powder particles and the modified hybrid resins were further compacted to the cylindrical and toroidal shapes for the mechanical, electrical and magnetic testing. A uniform distribution of the resin between the ferromagnetic particles was evidenced by scanning electron microscope (SEM) analysis, which was also reflected in a rather high value of the electrical resistivity. A low porosity and extraordinary high values of mechanical hardness and flexural strength were found in SMC consisting of the iron powder and phenolic resin modified with boron. The coercive fields of the prepared samples were comparable with the commercial SMCs.
                        • matt motor is a reject, I like cop8 the newman motor is a reject. A window motor is fine
                          • making powder parts then go into a forge heating till red
                            • Story time. A 50 ton bottle jack cost $100 bucks and a propane forge is cheaper.
                              • Tesla switch? Nope
