Motor Generators
  • Dave told us at that time that one of the 3 sets of coils Dave sent or they wound got shorted out and was not working the proper way. One time he was loading a single coil instead of the set. It was working like a conventional coil set which we do not want. You were told at the time and slipped you mind like everything else in your quest to demean, degrade and dirty up with your unclean personality. You can not sucker other people while I am here. Connections get crossed up or fail, there are many.
      Dave told us at that time that one of the 3 sets of coils Dave sent or they wound got shorted out and was not working the proper way. It was working like a conventional coil set which we do not want. You were told at the time and slipped you mind like everything else in your quest to demean, degrade and dirty up with your unclean personality. You can not sucker other people while I am here.
      So show where he said that. Odd. There's 6 bulbs, 6 switches, when all six are on, only one significantly different (dim). So maybe one of six coils (or coil pairs) is different. The sound of loading is quite unmistakable for each of the six. It's the telling test which he refused to mount a killawatt meter to the input at my request.
        So show where he said that. So maybe one of six coils (or coil pairs) is different. .
        You may leave. Sick f#ck. Your uncleanness has ended our conversation. Go look up the many talks. We are done.
          Hmm. Changed your lie with that 6:32AM edit, didn't you?
          • Debunking the debunker. You guys need the voice of reason. What a mind. Find the RegenX wave and ride it high.
            Posted on July 25, 2021 by tilankak
            Regenerative Acceleration Generator
            Today, I am going to explain you about a specialized Generator Model, which can be fixed to an Electric Vehicle by which we are given a good opportunity to recharge the Vehicle Battery , while giving an acceleration to the vehicle speed. This is a new invention of Mr. Thane Heins from Canada and now the Scientists are involved in continuous experiments to fix this Generator to the Electric Vehicles and start commercialized mass production of such Electric Vehicles for which very less recharge plugins are required when running the car.
            • I would like to do a little explanation about a special and awesome effect of the Electromagnetism to the concerned persons who have a keen intellect about the mechanical field. When we use a Conventional Generator Coil consisting few turns of copper wire with a Magnet Rotor spinning in front of it, the Rotor speed will get decreased when the Generator Coil is connected to a Load. This is called the Lenz law and this Lenz Law consists of two brakes and that is why the Magnet Rotor speed gets decreased. I will explain how it happens. When the N pole of the rotor magnet approaches the Core of the Generator Coil , the coil becomes magnetized as the coil is connected to the load and there is a loop circuit with a resistance caused by the load.
              In this diagram , I will explain how the Lenz Law causes 2 brakes and thus decreases the RPM of the Magnet Rotor, when the Conventional Generator coil is connected to the Load.
              When the N pole Rotor Magnet glued to the Rotor approaches the Coil Core , the Coil is very quickly magnetized , before the Rotor Magnet reaches the Top Dead Centre ( hereafter mentioned as TDC) . So then the Coil Core will also become a N pole magnet which resists and repels the rotor magnet which is also the N pole magnet and still approaching the coil core. . So this is the First break of the Lenz Law. It is caused by Magnet Repulsion.
              Then when the Rotor Magnet passes the Coil Core , the Coil is demagnetized and reverses the current induced in it, so then the coil core become a “ S” pole Magnet and it attracts the passing “N” pole magnet of the Magnet Rotor . So this is the second break of the Lenz Law. This is how the Lenz Law decreases the Rotor RPM when the Generator coil is connected to the Load.
              So now I am going to explain you, how the Lenz law becomes much delayed and how the Rotor RPM increases when we use the Special Regenerative Acceleration Coil ( hereafter mentioned as Regenx Coil ).
              In this Regenerative Acceleration Effect there are two Parameters .
              1. The Coil should have many turns of copper wire and it should be high impedance , high resistance coil.
              2. The Rotor RPM should be high .
              The following is the Coil I made which has over 8000 turns of Guage 28 copper wire and it is about 600 Grams in weight.
              • Posted on July 25, 2021 by tilankak
                But when I was experimenting with my Small Set up , I understood that there should not be a very high speed in the Rotor and if we can make the coil a high resistance one then the rotor RPM does not play any significant role in making the effect .
                My coil is a Bifilar coil and I connected the Bifilar coils in series and it has a high resistance. I used a small motor discarded from a DVD player and it is a 5V motor . When I supplied the power my magnet rotor gets about 1800 RPM and it is not too high , but I successfully achieved this effect.
                So this is how the Regenerative Acceleration Effect happens.
                As there are too many coil turns and the rotor is spinning in a very high speed, the Regenex Coil is not magnetized very quickly when the N pole rotor magnet approaches the Coil Core. But this Regenx coil gets magnetized when the N pole rotor magnet has just passed the TDC as shown in the following diagram.
                So as you can see in this configuration the Regenx coil is magnetized for “N “ pole , when the rotor magnet has just passed the TDC , so that there is a repulsion in the Magnets and the rotor magnet is pushed away by the coil core (Because it is a N pole Magnet )and this is the first Acceleration effect of this regenerative acceleration effect.
                As the rotor is in the N S N S magnet configuration , then this coil core simultaneously attracts the next S pole rotor magnet and it is the second acceleration effect.
                Actually the Lenz law is happening here , But it gets much delayed because of the new alterations and accelerates the Magnet Rotor when connected to the load.
                I also 100 percent agree with you that, we can’t add too many heavy loads to this regenex coils , but we can charge some heavy duty batteries like 12V 7A or 12V Car batteries , if we can sue some big magnets with big copper coils like Guage 20 copper wire because they will provide much ampere.
                In my small set up , I have used Guage 28 thin copper wire , but I can charge my mobile phone battery and also I can lit my lampshade and the RPM of the Magnet Rotor increases well and the current which motor takes from the drive battery gets much decreased when I connected the load.
                I have also well understood that, if we can add more regenex coils with loads the rotor RPM increases simultaneously . For me this is a very amazing phenomena and as my first small set up worked very well , I am going to make a much bigger design .
                Please note that it has been experimentally proved that , if we add more regenex coils, the RPM of the Rotor increases simultaneously, and the prime mover takes much less current from the drive battery . It is marvelous fact and this will direct me to provide many overunity motors and we have reached this overunity situation 90 percent now.
                A video of my first original small setup can be seen using the following link
                • See how the very young will just pass you by and you won't even see it. The USA is full of brainwashed tards who can't reason at this time. You will catch up. People are popping up all over the web who build, they don't sit on their hands and speculate old school.
                  • Click image for larger version
                    Reply #87.
                    Like a 40 page thread of 10 to 12 years ago hashing out (debunking) Thane Heinz Regen Acceleration BS with good accounts on efficiency and what's really happening.
                    • Bro' you silly old fool, throw away your time and money on a wild goose chase, what do I care?
                      • You are living in the past timelines. 2008- 2009 when Thane first came out with his invention. At that time no one understood the process and mostly because they don't listen carefully. Same with y'all. The only reason you are here is that you are getting something for disrupting.
                        • The only things that get disrupted are the bank balances of idiots who invest in Mr.Heins. Bro',spend your hard earned on your family and use your time wisely.
                          Yasa motors has been bought out by Mercedes Benz, they are getting up to 95% efficiency with their axial flux motors so you builders have a stiff challenge to match that, you only have 5% to play with.
                          • Oh, I thought by now I would have been accused of being wicked and dirty. Of course those terms couldn't be applied to one who's efforts were directed towards defrauding investors?
                            • Those are going to be some filthy rich investors when production goes into high gear. Don't you guys have an oil company to protest? You are all about the money? You getting a little for doing this?You should have invested in Potential Difference INC. You guys are popcorn peanut.
                              • Dave is here showing his old very dangerous coil tester as he calls it. He got hit with this one and was injured. I hope he didn't get hit again as we see he didn't learn his lesson. Anyway that is my opinion. What we do learn here is that the amp draw is unaffected for the drive motor, coil or no coil. 22.25v at 3.10 amps is way less then other rotors and he has 2 rotors here. 22.25 v X 3.10 amps = 69watts that is cheap for drive watts. Dave's coil winding efforts are a success if when the coil is shorted the drive watts do not decrease and the RPM's stay very close to the 2800 mark. This video shows a coil that is done right in Dave's book.
