Motor Generators
Update on the brick.
Got all five BMS's welded on this evening. Used hot glue gun to hold them in place. Will solder lead wires on tomorrow after Bible study.
Will try different experiments with the 5 batteries in the brick. Not sure which one experiment to do first since only have one working boost module right now. Can't wait to see how the BMS will work with the ideas presented here!
I am sure your work will pay offOriginally posted by wantomake View PostUpdate on the brick.
This is how to get a gas motor generator to produce extra energy or free energy. I did it with propane by heating the gas up using the muffler. I ran a 2 cylinder Wisconsin skid loader engine connected to a big alternator 7 days night and day for $25 bucks
Here is Zeek
I put it on a 72 F150 in 1981. I achieved 75 mpg. The unit I used is in the long video called one simple trick to 100 mph
100 Miles Per Gallon, Here's How
Board talk
One Simple Trick to get 100 miles per gallon with less pollution!
...........Last edited by BroMikey; 08-07-2022, 06:53 AM.
Happy Sunday everyone. Here is the data on the over night run on the 30v drive pack charging a 11.1v pack. Bigger batteries Wednesday. It looks good as this has run for 20 hrs and still lots of power to burn. 2 nine volt packs are actually 8v each one is 1800mah plus 1 pack at 2000mah 11.1v
Check to the run voltage after many hours of burning the light.
Originally posted by Matthew Jones View PostLOL, I told you the "Bowel Movement" can't have thread of nothing but coherent info no.... he has to interrupt.. An agent and his mindless puppy.
HI Matt glad you are back with earth shattering revelations about a bowel movement.
isn't he a genius?
Anyway back to the slam. Ending pack voltage 1st run charge up picture and 2nd run start up voltage.
.............................................Last edited by BroMikey; 08-08-2022, 05:59 AM.
Getting the brick connected to lead wires and hopefully get done today.
There's five 12.42 volt batteries in the brick. May try the simple 3BGS setup to see if the BMS system can handle being connected backwards as one battery is negative to negative. Don't know if these BMS only connect with correct polarity or not. But will see. Having rain storms so will continue on afterwards.
Correction on last post. Will try the 4 battery switch setup since I have 5 batteries. I need a 20 amp fuse for the Boost module. So will head to Wallyworld later as I get supper for the family. Will post any results I get later. Hopefully will be good results.
Well I found out my Drok is bad after connecting the brick up as a 4 battery setup. Matt motor connected. Ready to see results. But, nothing.
Getting weary of these frying Droks!!!
Wednesday the 2 new smaller boost converters are coming in.
So BroMikey, you're using a 3s 3p battery setup? Or how do you have yours connected? Fully charged at 4.2 volts each x 3 = 12.6 volts. I've learned you can't run them below 3 volts each or 9 volts in that configuration. But you know that already. How many mah per battery? That will determine your watt hours.
There's a math formula to find that but my notes are in the shop.
But good video. I'm headed to shop to connect new boosters that arrived.
Turion must be busy these days. Lol!!
Yes I am charging to 12.2v and discharging to 10.4v this gives me 14wh for 3 batteries 2000mah rating. My new ones are 2700mah and each pack of nine is 7800mah but the real rating is much less if I want 2000 cycles. And I do.Originally posted by wantomake View PostSo BroMikey, you're using a 3s 3p battery setup? Or how do you have yours connected? Fully charged at 4.2 volts each x 3 = 12.6 volts. I've learned you can't run them below 3 volts each or 9 volts in that configuration. But you know that already. How many mah per battery? That will determine your watt hours.
3/4 Amp 750 ma and that is it maybe intermittent 1000ma.
Look back in the posts for my connection
Email or PM?Originally posted by Turion View PostSent you a link. Working on 100 watts.
Don't see anything.
Ok BroMikey so we are on same page and chapter.
I found out that the BMS I'm using will not allow series wiring. No idea on the why. Of course parallels is ok. Therefore I can't use the brick with the BMS setup to experiment the 3BGS or 4 battery switch setup.
I will build a non BMS set of lithium battery packs to experiment with. More to think about.
