Your Basic Coil
  • Turion
    I'm sure millions have been spent on this kind of research, but the average guy working to build a COP>1 device has little access to it. I have been doing what research I can on the internet, and some information is available there, but there is far too much we do not have available to us.
  • dR-Green
    I would think that some of those questions are already answered and well studied in the field of power grid generators/alternators. Whether that data is public or not is another matter, seeing as it would give them a commercial/performance advantage over competing manufacturers, and ensuring that no costs are wasted on unnecessary or impeding materials and what not.
  • Turion
    started a topic Your Basic Coil
    Your Basic Coil
    I have often thought that the building of ANY device to produce COP>1 that involves the use of a coil should begin with RESEARCH into the physical makeup of the coil itself.
    When a magnet passes across the end of a coil of wire, how big can the coil be and still be saturated by the magnet? How saturated does it have to be to produce power? How do we know it is producing the most power it is capable of producing? Does it depend on the amount of wire? The size of the magnet? The diameter of the magnet? The diameter of the coil? The length of the coil? Whether or not there is a rotor at both ends of the coil?
    If the magnet is too close, energy is WASTED because of the attraction of the magnet to the core. If the magnet is too far away, the coil isn't saturated to its full potential.
    What should be the relationship between the diameter of the magnet and the diameter of the coil? Of the core? Should the magnet be as big as the core? Should it be as big as the whole coil? Should it be X times the diameter of the core?
    Is the attraction of the magnet affected by multiple strands of wire as opposed to only one strand?
    Should coils be made with multiple strands so that some strands can be shorted on purpose while other strands produce power, or that some strands can be pulse connected to achieve certain results while other strands simply produce power. Should ALL the wires on a multiple wire coil be shorted until a specific time, when they are suddenly made open circuit, or is the opposite the case?
    Is copper the BEST material for winding cores or perhaps iron wire with NO cores? Leedskalnin said he produced more electricity with iron than he ever did with copper.
    Is there an advantage to rotors on BOTH ends of the coil, or is it a waste of magnets and materials as well as an engineering pain in the ass?
    Can multiple air cores with close tolerances produce as much power as coils with cores when you do comparisons of power in vs power out?
    What materials comprise the best cores, and what should the physical relationship be between the wire and the core material? Should you have a solid core, or would a layer of wire, alternating with a layer of core material produce coils that output more energy with less wire and less core material?
    Can a coil be made so that when loaded, causes less amp draw on the motor turning the rotor, thus causing a speed up under load? What are the characteristics of such a coil? Does it require a specific RPM of the rotor? A specific size core? Magnet? Number of wires? Length of wire?
    I set up a coil testing stand that I am continuing to work on and improve. It has rotors at both ends of the coil that can be adjusted to different sized coils. It has different rotors with different sized magnets. It was NOT cheap to build. My goal has been to test some of these ideas for my own projects, and I have come to some conclusions, but I guarantee that if we had a hundred people testing and sharing the data we would develop some working hypotheses fairly quickly. As it is now, I have MY ideas. YOU may have insights I do not.
    I run a razor scooter motor with a power supply, which allows me to set the input and amperage supplied to the motor. I know what the RPM's of the motor are with NO COIL mounted between the rotors. I can then mount a coil and see if just the placement of the coil affects the AMP draw or the speed of rotation. Then I can attach loads and see how that affects the amp draw, or make connections between multiple strands of wire on the coils and see how that affects power production and amp draw.
    I posed a lot of questions here, and gave no answers. I honestly doubt I will get any. I think there are very few builders here now. Mostly folks who find videos on YouTube and post them rather than building something and posting their own, but I thought there might be a couple interested in the thought process behind all this and in moving in the right direction.
