Regenerative Acceleration in Use with Rotary Charging Systems
  • Gestalt
    Debunked? - Thane Heins, ReGenX, delayed lenz, shorted coil, acceleration effect - Revolution-Green
    Not sure about this.
    For the debunker, I would say run the experiment without a coil attached first, so that you have a base line.
    I am the debunker, and yea I did that. The results are the same as with a standard coil as shown in my video.
    The Regen acceleration is REAL and gives the illusion of increasing performance
    My theory as to what is occurring is as follows. The high voltage (~1.2kV) on the open bifilar config causes an electro-static current to flow between the windings causing a substantial open circuit back-EMF. Then when shorting the coil the high voltage goes to zero and the artificially induced electrostatic back-emf goes away. As load is added regular back-EMF from actual current in the windings occurs demonstrated by the increasing Pin.
    The novelty here is that an OPEN coil can cause unusual amounts of back-emf under HIGH VOLTAGE circumstances. This is clearly seen when doing a comparison of power input numbers when the coil is NOT bifilar, and there is no bifilar in proximity to the rotor. This is something Thane has never shown and why he is in error.
  • vidbid
    Why are you thanking Thane, Do you even understand what he is showing you.
    Show US, in a practical build what you have learned from all this reposting of you tube videos..
    I'm not interested in you or what you have to say. In fact, I couldn't care less.
  • Matthew Jones
    My thanks to Thane.
  • vidbid
    ReGenX Generator Operating without Armature Reaction at Infinite Efficiency
    [VIDEO]https://www.youtube.com/watch?v=6MPdylI0Ec4[/VIDEO]
    ReGenX Generator Operating without Armature Reaction at Infinite Efficiency - YouTube
    Code:
    Published on Jan 21, 2015
    The ReGenX Generator Coil by Potential Difference Inc. is a new type of generator coil that has NO Armature Reaction / does not produce any electromagnetic resistance when a load is applied and delivers 600% more output power than a conventional generator coil that does produce on-load induced electromagnetic resistance.
    Conventional Generator and ReGenX Generator Efficiency Calculations - Reaction to Creation:
    1) An electric generator is a machine that converts Mechanical Drive Shaft Power to Electrical Power
    2) Mechanical Drive Shaft Power = Torque x Speed
    3) Any drive shaft that is at Equilibrium has zero power in it and can do no work.
    4) Power is the rate of doing work.
    5) Equilibrium occurs at any Steady State such as a standstill or at any steady state rotating speed (no acceleration or deceleration).
    6) A drive shaft that is accelerating has a Positive Net Torque.
    7) A drive shaft that is decelerating has a Negative Net Torque.
    8) A drive shaft that is rotating at a steady state speed is at Equilibrium and can do no work (apparently ;-)
    9) A drive shaft that is rotating at a steady state speed when used with a conventional electric generator can only produce electric power if the mechanical input to the generator is increased when the generator is placed on-load.
    10) A generator that delivers 9 Watts of electric power to a load with a 10 Watt mechanical input power increase is converting mechanical to electrical power at a 90 % conversion efficiency.
    Conventional Generator Efficiency = Output / Input x 100
    = 9 / 10 x 100 = 90 %
    10a) A conventional generator requires this extra mechanical input power when placed on-load to counteract the conventional generator's conversion of the magnetic field energy that is created around every current bearing wire inside the generator to a counter-electromotive-torque which does work opposing and decelerating the drive shaft's rotation.
    This magnetic field Energy that is created, creates Torque and does Work according to the Work Energy Principle is sadly ignored by science and every physicist and engineering student in history simply because it is going in the wrong direction.
    11) The ReGenX Generator delivers 60 Watts of electric power to a load with a 0 Watt mechanical input power increase and is converting 0 Watts of mechanical input power to electric power at an infinite % conversion efficiency.
    ReGenX Generator Efficiency = 60 / 0 x 100 = Infinite %
    11a) The ReGenX Generator requires no extra mechanical input power when placed on-load and the magnetic field energy that is created around every current bearing wire inside the generator creates a complementary-electromotive-torque which does work accelerating the drive shaft's rotation. This magnetic field Energy that is created, creates Torque and does Work is still sadly ignored by science because it proves that energy CAN be created.
    Kind regards
    Thane
    Thane C. Heins
    President & CEO
    Potential +/- Difference Inc. R & D
    "We generate solutions"
    Email: [email protected]
    Cell: 613.314.9653
    Linkedin Sign Up | LinkedIn...
    slideshare Thane Heins presentations | SlideShare
    My thanks to Thane.
  • vidbid
    For or Against
  • vidbid
    Coil Configurations (ReGen-X)
    Originally posted by Patent Application US 20140111054 A1
    The ReGen-X coil has more than six different modes of operation which can be employed at any time and in any combination with a plurality of coils via electronic or manual switching of the coil configurations such as:
    i. Parallel wound, parallel connected bi-filar wound motor coil.
    ii. Parallel wound, series connected bi-filar wound motor coil.
    iii. Parallel wound, parallel connected bi-filar wound conventional (system decelerating) coil.
    iv. Parallel wound, series connected bi-filar wound ReGen-X (system accelerating) coil.
    v. High Impedance ReGen-X coil.
    vi. Any of the above employed in concert with a step up or step down transformer.
    Interesting..
  • vidbid
    Thane Heins
    Potential Difference, Inc.
    [VIDEO]https://www.youtube.com/watch?v=1l0GwiIUE5c[/VIDEO]
    Thane Hein P1 Bi toroid Transformer and Generator. The future of his device and company. - YouTube
    Code:
    [VIDEO]https://www.youtube.com/watch?v=ai1-Y5WnEhM[/VIDEO]
    Thane Hein P2 Bi toroid Transformer and Generator. The future of his device and company. - YouTube
    Code:
    [VIDEO]https://www.youtube.com/watch?v=6udcWyGFH7Y[/VIDEO]
    Thane Hein P3 Bi toroid Transformer and Generator. The future of his device and company. - YouTube
    Code:
  • vidbid
    Regenerative Acceleration Generator : FLUX HARVESTING TEST
    [VIDEO]https://www.youtube.com/watch?v=G0Q0jq0enYU[/VIDEO]
    Regenerative Acceleration Generator : FLUX HARVESTING TEST - YouTube
    Code:
    Published on Mar 13, 2013
    Here a video of a "Flux Harvesting" test conducted on the RAG v1.4 (Regenerative Acceleration Generator) based on the ReGenX from Thane C. Heins (PDI).
    When the 1st Regen coils is loaded the OUTPUT CURRENT on the 2nd Regen coil INCREASES while the RPM INCREASE and the POWER INPUT DECREASE. This is the "Flux Harvesting" feature...
    From his patent application:
    Originally posted by Under the Claims Section of the Patent
    11. The coil of claim 1 further comprising Flux Harvesting wherein, when operated as a plurality of salient or independent coils, subject to particular positioning of the coils, the discharging flux from said coil is collected into adjacent generator coils resulting in net additive flux in the coils, including the rotor flux plus the induced flux from other coils
    FIG. 16: Shows the relative positioning between ReGenX generator coils to maximize Flux Harvesting.
    Originally posted by ReGenX Coil Flux Harvesting
    2. In a further embodiment, when operated as a plurality of salient or independent coils, subject to particular positioning of the coils, (as described in greater detail below) the discharging flux from the ReGen-X coil can be collected into the adjacent coils operating as ReGen-X coils or conventional coils and the net flux in the coils is additive, including the rotor flux plus the induced flux from other coils, comprising a mode hereinafter referred to as flux harvesting.
    3. In yet another embodiment of the present invention, flux harvesting as described above also applies in a ReGen-X coil adjacent to a motor coil such that the discharging magnetic field form the motor coil can be collected in the ReGen-X coil and the net power consumption by the motor coil reduced significantly. Information in the appendix attached hereto provides an explanation of why an inductor behaves as a capacitor at certain frequencies.
    [VIDEO]https://www.youtube.com/watch?v=WxGPUZudVh8[/VIDEO]
    ReGen-X MOTOR COIL FLUX HARVESTING - YouTube
    Code:
  • vidbid
    OTTAWA UNIVERSITY CONVENTIONAL vs REGENERATIVE ACCELERATION GENERATOR
    Published on Feb 9, 2013
    [VIDEO]https://www.youtube.com/watch?v=YXEYEomvlsQ[/VIDEO]
    OTTAWA UNIVERSITY CONVENTIONAL vs REGENERATIVE ACCELERATION GENERATOR - YouTube
    Code:
    Shows engaged high voltage coils causing acceleration.
  • vidbid
    ReGen-X Performance
    @Bro: Thx
    [VIDEO]https://www.youtube.com/watch?v=qh2YnHelZSs[/VIDEO]
    ReGen-X Performance - YouTube
    Code:
    Interesting video on ReGen-X performance.
    Thx, Thane.
  • BroMikey
    Thanks Vidbid
    Somehow I missed these demo's. It was so good to hear Thanes
    voice again as he shows his device operating. Also when we look
    at his coils on the regenX side we see two spools of wire side by side
    like his Bi-toroidal transformer works. I am convinced more than
    ever now that the same effect Thane has discovered is used in
    both of his devices. Good to see you back ready to take it
    on the chin
  • vidbid
    Kinetic Energy Generating System
    Thane Heins has been involved in the free energy field since Sept. 11, 2001 (9/11). His company, Potential Difference Inc, has been developing multiple magnetic free energy technologies. One of these technologies is the "Regenerative Acceleration Generator." Another is the bi-toroid transformer or "BiTT." They all offer the possibility of manipulating magnetism and back EMF (Lenz Law) to produce overunity gains of energy. Now, Thane wants to take this research one step further and has begun constructing a "Kinetic Energy Generating System" that could propel a bicycle without any input from the rider (once the bicycle is up to speed). It is estimated $7,000 dollars worth of funding would allow for the "Kinetic Energy Generating system" to be completed in six months.
    The "Kinetic Energy Generating System" would utilize his "Regenerative Acceleration Generator Technology." This technology utilizes special coils that, when loaded, do not cause a wheel or rotor to slow down, but actually are claimed to cause it to accelerate. This is the opposite of the regenerative breaking technology used in some vehicles. Instead of using coils to generate electricity while the vehicle is breaking, coils can be used to *accelerate* the wheels of a vehicle while producing electricity at the same time.
    He says that the regenerative acceleration effect is possible, because the magnetic field induced in the coil is delayed until the rotor magnet is at top dead center. Until the rotor magnet is directly at top dead center, the coil acts as a capacitor and does not produce a magnetic field. Once the rotor magnet is at top dead center, the coil changes from acting like a capacitor to behaving like an inductor. He says "an inductor stores [energy] in the external magnetic field of the coil; but when it acts like a capacitor, [the energy] is stored in the internal, electrostatic field." After switching to being an inductor, the magnetic field produced pushes the rotor magnet at top dead center away, and attracts the next rotor magnet. Basically, this is a way to get around Lenz' Law, which is what prevents typical electric motor and generator from being overunity.
    Thane Heins' Regenerative Acceleration Generator Goes Instead of Stopping
    Directory:Perepiteia Generator by Potential Difference Inc - PESWiki
  • vidbid
    ETS Demo for Regenerative Acceleration
    ETS Demo
    [VIDEO]https://www.youtube.com/watch?v=FqWSV2Nd7tM[/VIDEO]
    ETS Demo - YouTube
    Code:
    ETS Demo Video #1
    [VIDEO]https://www.youtube.com/watch?v=wh8xbyxAhMA[/VIDEO]
    ETS Prototype Demo 1 - YouTube
    Code:
    ETS Demo Video #2
    [VIDEO]https://www.youtube.com/watch?v=FLUVQN2L3lo[/VIDEO]
    ETS Prototype Demo 2 - YouTube
    Code:
    It appears that while a patent application has been submitted and accepted, from what I can tell, no patent has been issued at this time to Thane Heins.
    Unbelievable.
  • vidbid
    Regenerative Acceleration (ReGenX) IP Patent Disclosure
    ZPEnergy.com - Regenerative Acceleration (ReGenX) IP Patent Disclosure
    Dear Colleague,
    Please find enclosed a Regenerative Acceleration (ReGenX) IP Patent Disclosure, full replication and independent tests from JLN Labs France.
    The innovation is now being licensed worldwide with no upfront costs and is available equally to all.
    This initiative is meant to provide an alternative solution to the toxic and extremely dangerous (to all of us and all life on planet Earth), Geo Engineering/ChemTrail agenda which is currently underway even though it was banned by the UN in 2010.
    Kind Regards
    Thane
  • vidbid
    Woopy Replication
    [VIDEO]https://www.youtube.com/watch?v=zrbEtXCsXiw[/VIDEO]
    accelerating rotor under load 1.wmv - YouTube
    Code:
    Source: Successful replication by WOOPY of the Heins' Regenerative Acceleration Effect
