Regenerative Acceleration in Use with Rotary Charging Systems
  • #61
    Just reporting on a Video.
    Electric OU: Coil Shorting Shunt Motor 2: Effect of Diode - YouTube
    Code:
    https://www.youtube.com/watch?v=SkV1RMtlJnk
    Okay, people, what is your explanation for this effect?
    DasVIDaniya!
    Bistander is totally correct in his answers about the two videos. If you want to understand better what is going on in the videos you can read some posts I made a while back about how shunt wound motors work. You can start with this post: http://www.energeticforum.com/275402-post456.html
    I think there are maybe a couple of more posts after that which answer some questions from other posters and further explain how these type motors work.
    Carroll
    • #62
      Coil Shorting Demo with Diode
      Just reporting on a video...
      Link to explanation: http://www.energeticforum.com/279209-post59.html
      VIDBID
      • #63
        Well Turion, I guess baselines can be useful for seeing differences that
        changes have made to a setup and so forth, but the overall efficiency is
        always the output divided by the input or the total input compared to the
        utilized output.
        A "baseline" has no place in an efficiency determination.
        Honestly we could use baselines to show improvements with anything.
        I can show and have shown speed up under short circuit or heavy loads with
        various setups, therefore it is nothing special and has a perfectly valid
        explanation in conventional "electro-magnetics".
        It's a very simple setup to test.
        Set up a rotor with magnets spun by a Prime mover of some description.
        Determine the frequency of the magnets rotation at a prime mover speed
        about 1/2 to 3/4 the maximum speed under load.
        Calculate or determine by trial and error the inductance needed to obtain a
        harmonic of or a resonant frequency the same as the magnet rotation speed.
        Set up a generator coil with a bit less than the inductance determined in the
        previous step so that when a capacitor of 1 to a few uF is added across the
        gen coil resonance or a harmonic is approached before the prime mover is at
        full power.
        Basically if you scope the gen coil and run the setup at say 1/2 of the
        maximum speed it is easy to find a capacitor size that causes the voltage
        wave form to increase dramatically when the cap is connected, or to fine
        tune the speed to where the effect is got.
        The currents caused to flow in the coil and cap should make the prime mover
        slow or use more input power.
        Short or load the gen coil to cause the rotor to speed up again.
        Trial and error can get the speed just right so that the effect is best seen or
        not as I did in the first video I posted.
        I think I used in one case about 7 mH and about 14 uF or something to get a
        few hundred Hz.
        In no case does the speed up under short circuit or load cause the rotor to
        rotate faster than without the coils there.
        And in no case does the effect cause the output to become more than the
        input. Which is the important measure.
        Obviously the thing to be learned here by us is that generator coils wound to
        have a lot of capacitance will likely be very inefficient due to the effect in
        question.
        When a generator coil exhibits the acceleration under load effect at resonance the output
        of that coil is limited to much less than if the coil was used at a lesser
        frequency due to frequency induced impedance.
        Basically the effect is inefficient.
        If Thanes setup is OU then why is mine not OU as well ?
        Answer is simple Thanes setup is not OU never was.
        • #64
          Misunderstanding
          I never said Thaine's setup was OU. I don't have much faith that ANY device can deliver COP>1 until I see it working on my bench. I have never seen a single coil device capable of delivering COP>1, but then I haven't seen everything out there either. Perhaps it IS possible. But I'll believe it when I can put my scope on it.
          • #65
            Well Turion
            Thane has only shown one or two coils operating at a time.
            The main thing we all need to take note of is the fact that
            the business man standing there in Thane's demo represents
            a company that spends X amount on electric daily.
            Thane showed the man how he could go from conventional
            mode to the RegenX MODE and back again. Many have contested
            that under a load THANES effect goes away. This has been proven
            not to be the case.
            Even under a load the rotors will increase energy.
            Now let's look at the cost saving. Let's say the man standing
            at the demo spent $100,000 per month to run a machine or
            machines. With Thane's setup the man would get $30,000 back
            and he could buy a lot of THANE hardware
            What I don't understand is why people don't realize that if 30
            percent can be saved by recycling, something that the universities
            say is a taboo discussion, why can't they figure out that 60 percent
            is possible?????? Why not 160 percent???????????????
            Anyway just a thought for those who think.
            • #66
              • #67
                utilized output.
                full power.
                few hundred Hz.
                question.
                this link
                • #68
                  Dynamic braking
                  What puzzles me is that I have always found that when I short the armature or a phase (coil(s)) on a permanent magnet machine (motor or generator), it comes to a screeching stop. And is impossible to rotate by hand at more than an RPM or two. So what gives with these demonstrations of "regenerative acceleration"? Two things come to mind. One is the coil impedance is ridiculously high. And two, that the magnetic circuit is ridiculously loose or leaky. In other words, the machine is useless as far as doing any real work. It is just an academic exercise showing an anomaly caused by armature reaction.
                  • #69
                    It doesn't have to be leaky for sure, high impedance is good way to go about it but primarily used to counteract the attraction caused in a normal gen coil. Its a pretty great thing to be able to load a gen up and it doesn't slow down or require more power to turn then when the generator was open. I have never understood the delusion that says thats not useful. And its really simple to implement.
                    Matt
                    • #70
                      Well people can decide for themselves and do whatever they like. I've given my opinion and will do it again if I feel like it.
                      Everyone should show their setups and their input and output so we can see who has the most efficient setup. My guess is none are OU. Go figure.
                      • #71
                        I agree the machines are useless as far as doing a reasonable amount of real
                        work for the cost and as with Thanes setup they are very inefficient when
                        the total input is compared to the useful output.
                        That is also true for the transformer version of the effect where the input
                        drops when the transformer is loaded. I also demonstrated a transformer
                        performing the effect.
                        Search for a thread by OverunityGuide about it.
                        If a setup is using 180 Watts so that 20 Watts can be drawn without slowing
                        the machine or even speeding it up a bit then that is about 11 % efficient.
                        So no, doing that is not useful it's wasteful.
                        • #72
                          Seeing is believing
                          Here is what I have seen
                          I threaded a 12" rotor onto the shaft of my razor scooter motor and spin it up to 1850 RPM. I recorded the amps, volts and RPM's of the motor. Then I introduced an air core coil to the rotor. (Howdy! Glad to meet ya.) I saw no increase in amp draw, no increase in voltage and no decrease in RPM's. This indicated to me that the air core coil in and of itself has no effect either positive nor negative on the prime mover. When I put a load across the coil, I got no increase in RPM and no increase in amp draw.
                          So I stepped it up.
                          I did the exact SAME experiment with my three rotor generator. I recorded amp draw, voltage and RPM prior to introducing coils, and then introduced 12 coils to the rotors. (This took a while as there was a lot of shaking of hands and meaningless greetings.) Again there was little or NO change in amp draw or voltage nor was there a decrease in RPM's. I will say that the needle on the amp meter did wiggle, but did not change substantially. When I loaded one coil I got a decrease in amp draw and an increase in RPM. Not much, but measurable.
                          That is what I saw. Make of it what you will. Ignore it if you choose.
                          I should say that the FIRST coil I used is NOT the same coil as what is in my generator. When I took a single coil out of my generator and ran the same test without by itself, I got a speed up under load of 12 RPM. Again, nothing exciting, but I am happy with just maintaining speed under load and producing the most power possible.
                          • #73
                            Hey Dave
                            Good to hear SOMEBODY speak with an analytical mind. I can't
                            stress enough what it means to me personally. It is like we are
                            drowning in a sea of mindlessness for some of these so called
                            experimenters. Men who have the wooden wheel with all of the
                            spools but have little power to reason it out. What you have
                            stated is exactly what Thane has stated. One reactive input
                            and then keep adding coils for no appreciable input power
                            change. On the other hand those 12 coils are raking it in
                            big time. It is posts like this that make these threads worth
                            something. And all of that other Big Chezz Wiz boasting
                            is nothing but whale butter.
                            You are leading the way because you are not motivated by ego.
                            It is your turn now, you are the oldest and wisest.The
                            younger guys know how to make it work also but like most young
                            men they must shake their poor behavior patterns.
                            The more I hear YOU talk the more I am apt to do some experimenting
                            because I can see that those large wafer magnets flying around at
                            break neck speeds have good potential. Great for adding more coils.
                            All of the Bi-Toroid researchers have stated that the current is 90
                            degrees out of phase with the voltage and this ReGenX mode also
                            works on the similar principle.
                            This of course is my amateur opinion.
                            • #74
                              Any beginner can get closer than 11 percent. I can see you are less
                              than a beginner. The power to reason is a gift. Attacks without
                              experiments show nothing. If you have done the experiments then you
                              know that anyone just starting out can take one input and collect
                              most of the energy by simply connecting a conventional generator
                              to the other end. We are not talking about 11 percent here.
                              This discussion is for someone who has passed their test by
                              conventional means. I can take an off the shelf motor and couple
                              it up to a car alternator and do better than your 11 percent.
                              Until you can build a rotor and coil set that is not wasting
                              90 percent of it's own power you can never see what this thread
                              deals with.
                              For pete sakes don't post that 11 percent figure again, it make you
                              look bad. With all of those magnets and you can't do as good
                              as a conventional generator with no magnets? Something is seriously
                              wrong there. Get it up to the 80-90 degree mark such as we see
                              is standard university level thinking. If you can't do that then you
                              don't qualifiy for going over 90 percent with THAT rig, whatever
                              it is. If you have a 1/2" gap between magnets and coils then you
                              need to read a school book. If your coils are a twisted up mess
                              again back to conventional. Also loading and matching loads can
                              set back your efficiency.
                              This thread is for people who can acheive a conventional standard
                              then proceed to go beyond. Get it up to 90 then we will talk 95.
                              If all you have is 11 percent then I have to say you are not trying
                              because a school boy beginner tops that the first day.
                              No you are not really trying. Delayed Lenz and Thane is a master
                              at teaching, he is worthy of front row students.
                              PDi Regenerative Acceleration and BiTT Principles
                              [VIDEO]https://www.youtube.com/watch?v=5osYN5f35Bc[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=7y89nMe7AGE[/VIDEO]
                              [VIDEO]https://www.youtube.com/watch?v=5MzHWJc1gSc[/VIDEO]
                              • #75
                                Efficiency
                                I didn't see anything from OverunityGuide which was interesting, but I did run across this. It is actually a well done test and results are plotted like this:
                                From this link: DLE-TEST07 : Full measurements on the Regenerative Acceleration Generator from Thane C. Heins
                                The plot uses generator RPM as the abscissas (x-axis) and shows delta RPM and delta input power in percentage. That is input power from the power supply driving the motor turning the generator. So there is no measure of generator output power. So there is no means to determine the efficiency of the generator. However, the generator load is 0.1Ω and the coil resistance is 23Ω. So from those two parameters, a best case efficiency for the generator regardless of load or speed is 0.43%. Not 43%, but 0.0043 or 0.43%. Less than 1 percent. But this is near a short circuit output where this "regenerative acceleration" is observed. And efficiency at short circuit is zero. So it make sense to me and is why I question the usefulness of such generators.
                                Has anything similar to this "regenerative acceleration" been observed and recorded at a useful generator output? Like maybe 200 to 300 Watts for a device that size? How about taking a commercially available generator and rewinding it to improve efficiency from 80% to 85%? Then do a side by side comparison test under load measuring inputs and outputs? Is that too much to ask?
