Flynn Parallel Path Device
  • Flynn Parallel Path Device
    I was doing some research on magnetic flux and discovered for myself the Flynn Parallel Path concept.
    YouTube Video: Flynn Parallel Path Device
    Please share your comments on this device.
    VIDBID
    VIDBID
    Improved Version
    VIDBID
    ..found another video..
    improved flynn model 2
    VIDBID
    VIDBID
      US Patent #6,246,561
      A permanent magnet device includes a permanent magnet having north and south pole faces with a first pole piece positioned adjacent one pole face thereof and a second pole piece positioned adjacent the other pole face thereof so as to create at least two potential magnetic flux paths. A first control coil is positioned along one flux path and a second control coil is positioned along the other flux path, each coil being connected to a control circuit for controlling the energization thereof. The control coils may be energized in a variety of ways to achieved desirable motive and static devices, including linear reciprocating devices, linear motion devices, rotary motion devices and power conversion.
      VIDBID
      VIDBID
        William Reed
            Electrically Switchable Magnet System - US Patent #6229422
            Originally posted by rosehillworks View Post
            Originally posted by Robert Murray-Smith
            Uploaded on Feb 15, 2012
            After spending some time on Femm4.2 modelling the Flynn device and playing around with various permutations I began looking for ways that could replicate the switching effect but be easier and cheaper to build. Then I came across US Patent 6229422. The result you see in the video. The little device is made from two magnets a neodymium magnet and an alnico magnet both 2cm by 0.5cm rods with similar magnetic strength. The alnico - however - has a much lower coercivity - this mean it will magnetize and demagnetize relatively easily while the N42 will not. So, subjecting the two magnets tot he same field will swap the magnetic poles of the alnico but leave the poles of the N42 unaffected. To do this is this simple set up takes a microsecond pulse at 12v - the pulse passes 10amps through the coil - this sounds like a lot but the same effect could be achieved by discharging a 20 microFarad 12v capacitor through the coil - so - really it isn't much - about 13 millijoules.
            Bravo! rosehillworks
            ..making a magnet seem to on or off with a small and very brief input voltage..
            VIDBID
            VIDBID
              Interesting. Thanks for posting your ideas.
              VIDBID
              VIDBID
                Vidbid Mod
                VIDBID
                PS: Reference YouTube video: https://www.youtube.com/watch?v=MZzosuvfvE4
                VIDBID
                  I like that switchable magnet setup
                  We all look to making the magnets do work as in generating the current in a secondary coil, but what if we made them do mechanical work at the same time?
                  This means that the magnet must move something and so necessitates an air gap, and of course we may see a loss with that, but would the mechanical work be additional to the electrical work done?
                  If we placed an iron rotor in the air gap so that it is not perfectly aligned and briefly switched on the magnet, the flux would pass through the rotor and apply a torque to it causing it to turn towards perfect alignment. Momentum would then allow the rotor to continue to spin until it reaches the same position again where the cycle could be repeated ie an attraction motor.
                  As the motor is is attraction the flux remains within the iron so the generation in the secondary should remain fairly good despite small air gaps. Now the question is will the sum of the mechanical power and the generation caused by the switching on and off of the flux be greater than just the generation alone?
                  yes, It is true we get a loss across the air gap causing a small reduction in efficiency of generation but is the mechanical power greater than this loss?
                  Note that the Flynn motor does have this misaligned attraction motor setup but does not show any generation/recovery coils. Maybe the motor patent is only showing part of the picture. Ill be honest, I would never put the whole thing in just one patent if I were the inventor as it would be too easy to copy.
                    I just modified the Flynn drawing to how I see it. I apologise for the poor drawing.
                    Coil A A is the switching coil
                    Coil B B is the recovery/generator coil
                    The orange line is the flux path in the off state
                    The green line is the flux path in the energised state
                    Coil B B goes from no flux to 2 units of flux and back again thus generating with the flux of both magnets.
                    Coil A A may or may not have some inductive kickback
                    The rotor turns with the torque provided by both magnets
                    Now the question is, will the generated output in coil B B and mechanical power be more than the electrical input in coil A A?
                      Motionless Flux Lock (MFL)
                      My inspiration for this design is from a number of sources.
                      1. https://www.google.com/patents/US6246561
                      2. https://www.google.com/patents/US6229422
                      3. http://www.free-energy-info.co.uk/Chapt3.html
                      4. http://www.energeticforum.com/renewa...th-device.html
                      I release my drawing of the MFL into the public domain.
                      VIDBID
                      I created a thread to deal with this idea.
                      I also recommend this video: https://www.youtube.com/watch?v=MZzosuvfvE4
                      VIDBID
                      VIDBID
                        OK understood
                        As a locking mechanism I think it is excelent, I assumed you were looking at energy production. I apologise for my tunnel vision
                          Lock
                          Originally posted by mbrownn View Post
                          OK understood
                          The name: MFL.
                          Lock.
                          I was sort of paying homage to the idea of turning ON or turning OFF the flux with a short pulse.
                          VIDBID
                          VIDBID
                          • #14
                            Energy Recovery
                            VIDBID
                            VIDBID
                            • #15
                              Previous discussion
                              Most of this has been explored before. The one thing that it does remind me of is Beardon's statements about the conditioning of virgin magnets. You can see the original Beardon article here:\The Tom Bearden Website or run your own google search on Radus boots.
                              Anyone who is looking into the parallel path research should take the time to review this as well as some of the documentation they include on the web site. It will help.
