Tesla's Special Tri-Metal Generator
  • Vinyasi
    Describing my schematic redraw of attempting to replicate the B&L Electron Captor.
    Describing my schematic redraw of attempting to replicate the Electron Captor of Barbosa and Leal using Eric Dollard's Analog Computer in LMD (Longitudinal Magneto-Dielectric) mode (in which he bench tests a transmission line) to serve as my circuit's archetype and using my body (at least) in the initial stages of development.
    tinyurl.com/barbosa-leal -- An attempt to understand how to replicate the Earth Electron Captor of Barbosa and Leal -- a playlist on YouTube.
  • Vinyasi
    Speed of rotation regardless of which method is used to spin the disk?
    Originally posted by String Theory
    Hi Vinyasi :
    Here is a link to info from the book Aliens From Pentagon :
    Pentagon Aliens - 08
    So, it's all a question of speed of rotation regardless of which method is used to spin the disk?
    It took a few readings of your post for me to think that I understood what you're saying if I assume the Searle Effect? Not the magnetic explanation of his effect described by Searle himself presently on his website/s, but the earlier version described by Joseph Cater in his book, The Awesome Life Force, in quoting Searle's earlier description that spin speed alone gathered enough electrostatic force to overcome gravity and self-accelerate his aluminum disks set into motion by a simple gas fired engine.
    Which implies that removal of the braking magnet (the permanent C-shaped magnet whose north and south poles surround a spot on the aluminum disk) could fulfill the disk's purpose described in my copy of the "Meterman's Handbook" edition from 1912? That is, to self-accelerate to an infinite spin rate once set into initial motion at some minimal rate of spin? And thus have unimpeded opportunity for the generation of power within the context of an electromechanical watt-hour meter?
  • Vinyasi
    Thanks for trying...
    Theory :
    Extracting Energy Using Helix Coil +
    Ferrite Ring Magnet (Iron/Carbon).
    Copper Wire = Positive Polarity
    Aluminium Wire = Negative Polarity
    Outcome Of Experiment Was No Energy.
    I will have to rethink my theories !!
    Sincerly - Kai Anders Wold
    I'm still clueless after two years of groping.
  • Vinyasi
    Transposing Mark McKay's analysis of the EV Gray motor chassis to Barbosa and Leal.
    Transposing Mark McKay's analysis of the chassis of the EV Gray motor over to Barbosa & Leal Captor.
    Mark-McKay-analysis-of-EV-Gray-motor.zip - Google Drive
    tinyurl.com/evgray
  • Vinyasi
    The power - utility - company's lie is fueled by our own incompetent misunderstanding
    The power - utility - company's lie {that we need to be billed at all} is fueled by our own incompetent misunderstanding.
    Amperage is what we use; voltage is what we need. To be billed for watt-hours ignores what we actually need: volts! Since the Barbosa and Leal device exhibits an indeterminable capacitance for voltage within our Earth, then it stands to reason that we are not being billed properly. For if we were to be billed in an honest manner, than we would only be billed for what we actually need: volts! Which of course, we can't be billed for exclusive of amps lest we first suffer a black out and become impossible to be billed at all. Which makes the current scheme of billing us for watt-hours an outright lie hidden in plain sight.
    Our use of amps depletes our manmade source for volts, but who said we should cater to the status quo of not making use of Nature's voltage? No one. Just as I thought. We're not asking smart questions of ourselves. Until now...
  • Vinyasi
    Electrostatic, or capacitant voltage, collection from the Earth - not amperes.
    I'm no electrician, so I'm going to describe it as I see it....
    The Barbosa and Leal device is creating a dipole between its input and Earth ground in a manner which does not kill the maintenance of its dipole since the two are only loosely coupled and the Earth's capacitance for contributing a voltage reference of its own is indeterminably larger by comparison to the battery/inverter setup of Clarence's replication described on a thread at ...
  • Vinyasi
    Barbosa and Leal Captor, Nathan Stubblefield's Earth Battery, Tesla 3Metal Generator.
    Barbosa and Leal Captor, Nathan Stubblefield's Earth Battery, EV Gray Motor and Tesla's Tri-Metal Generator analogues.
    The stability of the electrostatic reserve surrounding our circuitries is relevant for serving as a voltage reference for adding a gainful benefit since electrostatics can be very fragile by comparison to electromagnetics. Thus, do I like to stretch nomenclature a bit by referring to this as another form of battery since a battery acts as a reserve unlike a capacitor which functions more like the backboard to bounce bank shots off of through a basketball hoop - no reserve to speak of, in other words, by comparison to a battery.
    Whether or not the Hutchison Effect has anything additional to do with this? I don't know...
    Barbosa & Leal device Captor Energy in 20W out 400W
    Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
    COP - Coefficient of Performance = ~300:1 aka EV Gray motor or Nathan Stubblefield's Earth Battery.
  • Vinyasi
    Could electrostatic batteries replace electrolytic batteries in Tesla switch circuit?
    Ronald Brandt's vaporizing transistors.
    Could electrostatic batteries replace electrolytic batteries in a Tesla switching circuit?
    Could this be the purpose of an electrostatic field within the context of Tesla's Special Tri-Metal Generator? Not the Hutchison Effect, but a different kind of battery. Not an electrolytic battery, but an electrostatic battery filled with ions of a different sort: gaseous ions flushed out with compressed air - like the Richard Hackenberger version of the EV Gray motor or the Nazi electro-u-boat - rather than fluidic ions of a normal type of battery? This may explain Bedini's extensive use of batteries in many of his circuit designs? Replaceable - not with capacitors, but - with electrostatic fields surrounding an air mass? It's a possibility.
  • Vinyasi
    Could Bedini's version of Tesla's switching circuit be the core interface of TTSG?
    Could Bedini's version of Tesla's switching circuit be the core interface of his special generator? ; replacing William Lyne's description (from 33rd Parallel interview) of the reciprocating piston of the Nazi Electro-U-Boats?
    Energy from the Vacuum, series - Disc 38, parts 1 & 2 - Tesla Switch
  • Vinyasi
    The importance of a dead short in any attempt to replicate Tesla's Special Generator?
    Could an important ingredient -- which is missing in our design of replicating Tesla's Special Generator -- be a dead short between the source and load branches of a circuit?
    [John Bedini pointing to...] Tom Bearden, "Don't kill the (voltage) dipole".
  • Vinyasi
    Toward a more accurate definition of the Hutchison Effect.
    Definition - A consonant or dissonant interference between a transverse wave and a compression field. The compression field may be composed of matter or electrostatic energy.
  • Vinyasi
    Does the FCC regulate the radio interference contribution to the power grid?
  • Vinyasi
    Tesla's Special Generator may be a replacement for Nathan Stubblefield Earth Battery.
    Tesla's Special Generator may be a work around replacement for Nathan Stubblefield's Earth Battery....
    ....in today's world, such as it is, polluted with AC noise in the very ground beneath our feet.
    Mark McKay's EV Gray motor analysis indicates Hutchison Effect in Tesla's Tri-Metal Generator.
    Nathan Stubblefield's Earth Batteries -- A natural alternative to Tesla's artificial Special TriMetal Generator?
    New Page 2
    William Lyne's description of the AC power station may be providing nothing more than "seed power" augmented from another source (William claims it's the watt-hour meter) to power our loads as is quoted from his interview by Paul Scarzo in the 33rd Parallel series although I would prefer to call it a "carrier wave" upon which rides: the voltage varying signals emanating from our load and the current provided by our electrostatic environment.
    Tesla's Tri-Metal Generator - William Lyne and Paul Scarzo - 33rd Parallel, excerpt.
  • Vinyasi
    One more example of the Hutchison Effect: quiet murder within our homes.
    The murder of John Bedini and his brother Gary Bedini via the Hutchison Effect using the power grid.
    We are bred to believe in Hollywood's version of assassination: a hit man is hired by the mafia to "take someone out". So melodramatic and so suspenseful. But what about a more quiet method so transparent that we're led to believe that the victim died of natural causes?
    One classic example is that of a soldier who dies just before battle of mere fright alone. Who killed him? Himself while under the influence of fear and the sight of the opposing army facing him.
    But the link to the video, above, is about the very human tendency to overly personalize our problems to the point of their becoming so potentially lethal that no face-to-face assailant is needed to remove us from among the living, because our own life, or death, is always in our mind's eye whether or not we choose to periodically, or at times of high danger, manage our conscious attention to promote our general well-being at the expense of trying to solve all of our problems instead of merely some of them (the smaller ones whose solutions won't kill us).
    This tendency is our vulnerability - and if magnified by the use of the Hutchison Effect via the power grid entering into our homes and buildings - substitutes Hollywood's version of murder with another one of equal merit effectively evolving the ancient "magical spell, or hex" into its technological modernization.
    The solution is to periodically depersonalize our problems by turning our attention to the impersonal aspect of existence using whatever tricks at our disposal to encourage this approach.
  • Vinyasi
    Analysis of the Hutchison Effect in a pole transformer.
    How a pole transformer is put together...
