why more replicators ?
when doing some experiments the gained power increased when changing the L2 connections... L1 also has an optimal value, the high voltage power source will play a critical job in this system, the diodes also need a lots of attention ..
in a simple words this system must be tuned to the best value to give the intended power ... until now i burned about 26 diodes, a lots of work is needed, one person can't do it alone, even Tesla has some helpers ...
with a ferrite as a core you will achieve around 1000 more feedback inside your primary ... in other hands greater current will be induced in the secondary, the only problem is the reduced frequency, for sure there's an optimal values we have to work with but it's great if you test this and tell us the results.. so we could compare our works and see the weak point and the strong points also !
