John,
John Bedini was clear on the orientation of winding the coil. His suggestion was what some call the right hand rule: If you hold the coil in your right hand, start winding at the bottom and go in the direction that your fingers are pointing. Starting at the bottom is not important, but then his drawings generally showed the bottom wire being the inside starting end.
But...he also said that if your coil was wound in the opposite direction that you could simply turn it upside down so that the poles would be right for his machines. It was about the correct pole attracting in the next magnet that really counted. But the specified winding was supposed to work a little better. I've always wondered if that would be the opposite is we were below the equator, like the way water spins in the opposite direction below the equator. (?)
Bob
Bob
