William F. Skinner - 1939 Gravity Power
  • Elliptical mechanism
    Originally posted by eltimple View Post
    I think the expression you are looking for is "Orbital Ellipsograph"
    I think this may explain what you are trying to say ...
    this being the rotation imparted to the shafts right up at the top.. Ellipse - Wikipedia, the free encyclopedia
    now if you had one of those guiding the shaft around just imagine
    I've seen those before, I really like that - if it can be beefed up to handle our desired purpose, might work well. Here is en easy one for people to see a mechanism. https://www.youtube.com/watch?v=VQRa1hjYbfs
    • In one shot you can see the bottom of the top weight, much to my surprise it looks like it might be mostly empty, anyone see that? There is what appears to be a bar across the bottom of the empty can of a weight..
      was able to get my coaxial lever made to day, it will sit in my gimbal mech being able to transmit ellipsoid or circular paths..
      Nice drawings!
        I will have finished my very simple one in a few days , just 2 cogs..
        • tilted advantage
          I came across this patent application, it seems on the outset that the principle is very similar, here is the patent
          Patent US20130047754 - Mechanical advantage machine - Google Patents
          I have not yet fully thought about this yet (the patent), but the system for power generation of this thread is very doable, it is as of yet the most promising free energy machine if looped, and why not.
          regards
          Mike
          PS. I note at the moment on other forums as well as here, the normal people who feed on putting things down, really have stayed away, I wonder why!!! maybe they don't really have an argument against it
          I don't know how related this is but the patent drawing of the tipped wheel reminded me of some toys I'm starting to see on new playgrounds.
          Everyone knows what a plain merry go round is...perfectly level with the ground so the whole thing is balanced.
          This toy is different, the triangle platform is tilted just a couple degrees and makes all the difference in the world - I know because I played on one! lol
          Just by being tilted just a bit, gravity can contribute...of course coming up against gravity on the other side has resistance against gravity but the point is, if you sit or stand on it after jumping on and getting it spinning around, by "pumping" it by holding yourself out and pulling in at just the right moment when you're on the falling side of the tilt, it will spin pretty fast and will keep going and going and going. There really is no comparison to a level wheel.
          • looping the machine
            With this kind of gain, it looks easy to loop. The output can turn a generator to produce way more electrical than is necessary for the input motor and since it is a disconnected or isolated energy feedback, the machine still stays open. "pseudo-looped"
            • empty can
              On the original machine video? Please elaborate.
              • Murakami Elliptical Drive
                Here - one of my secrets I was testing a year ago on small scale, which essentially replaced the translation coupler with a pulley to cause the lower shaft to move in slightly elliptical orbit. The degree of the ellipse was limited to the angle that a self-centering bearing would allow for so I only was able to do a slight ellipse by tilting the input motor to drive the pulley. Ideally, it would be a pulsed motor pulsing when the shaft is at the ends of the ellipses.
                The translation coupler is best but again was just some tests I was doing.
                However, using the translation coupler and needing to move the upper part of the input lever in an ellipse, I will show what I think is the simplest method to DIRECTLY convert a circular motion in one plane to an elliptical motion in another plane. Others might be doing this concept in other applications but since I can't find it online, I'm calling it the Murakami Circular to Elliptical Converter or Murakami Elliptical Drive.
                I've never shown this before. I have gone back and forth over various ideas and tests in the last 1-2 years on all of this and I think this will make it easy for just about anyone to create the elliptical motion for the input lever in the most simple way...as long as we can get a self centering bearing or similar part that accomplishes what is in the video.
                Arto - you probably know exactly what is needed for this - it is pretty self-evident in the bicycle wheel demo that I do at the end of the video. After going back and forth through many ideas, this was actually the original concept I came up with and is why I have that pulley with the offset bearing in it because that is what I started with for testing quite a while back. The degree of elliptical-ness is determined by the tilt of the wheel...the more the tilt, the more elongated the ellipse. Do you know of a self centering bearing or something else that would give me 45 degrees tilt for example to give a serious ellipse?
                Here it is - hope you all like the concept. Murakami Elliptical Drive - https://www.youtube.com/watch?v=IbMUrY5MynA
                • Hey scumbag !
                  Thx for the idea !
                  I was thinking all day long about a curbed chain and attachment.
                  • Originally posted by Michael John Nunnerley View Post
                    regards
                    Mike
                    Interesting. It seems with this design you could eliminate the entire top half of the Skinner design.
                    • Montreal troublemaker
                      Originally posted by ARMCORTEX View Post
                      Hey scumbag !
                      Thx for the idea !
                      Back off with your mouth Lawrence!
                      • You know what, just have 3d printed an elliptical path and just motion control it with 4 elecromagnets , on the edges of the ellipse.
                        And I prefer my chain drive arrangement, I call it ARMCORTEX slotted chain drive''.
                        Encoder on the weights, 4 small motors, can bus, ARMCORTEX LPC4300 series
                        Get the party goin. Ur so jelly Aaron.
                        Schweet !
                        • lower shaft
                          Hi All, I made a video put it in zip format tried to load it but after 45min. I gave up. It shows clearly how the top shaft does an orbital motion along with the back and forth all by itself.
                          The real question for me is the way the lower shaft is connected to the translation plate. I tried a bearing in the shaft , solid pin in the shaft , in both case the shaft was free to move on its' own, but when I loaded the output the bottom would stop rotating.
                          So I'm going to try locking it solid or maybe partial slip then engage.
                          Maybe the plate is solid to the upper only I'm not sure?
                          artv
                          • video
                            Hi All, just got the video posted over at ou, if somebody wants to put it here their more than welcome. Here it just keeps saying failed to load maybe not enough room I don't know?
                            artv
                            • you really should put some more effort in making the device,
                              the weight are a little to far of the center,and also to light,
                              the first and the second weight "must" move freely ,
                              and to lever moves in elliptical orbit,
                                see this video on elliipses starts at at 54 seconds
