Analysis of the WITTS Generator
  • #31
    QEG Simplified
    So.. Interesting.
    VIDBID
    VIDBID
    • #32
      Tesla's Patent #511916
      VIDBID
      VIDBID
      • #33
        Core
        Are there only four coils on the core?
        VIDBID
        VIDBID
        • #34
          QEG is looking a lot like the WITTS Generator
          Yep. It looks pretty close.
          VIDBID
          VIDBID
          • #35
            After reading QEG manual, it looks like it's the construction plans I asked for.
            However, I have more questions.
            If the Resonator aka generator doesn't have any magnets and isn't connected to input power, where does it get its power to start operating?
            Where does the starting power come from?
            It should have a starting input, shouldn't it?
            This is what the QEG construction plans say:
            Set-up and Testing
            Starting with the wiring setup as show in the schematic, disconnect the primary coils from the series capacitor string on one end (disconnect capacitors). This will prevent resonance momentarily.
            Connect the input power to the variac. We started with a full 240 volt series wired system, but parallel 120 volt wiring can be used.
            Test mechanical assembly by spinning up the motor/rotor/belt and observing operation. Adjust variac voltage from zero to about 3/4 through its range. The active rpm range is under 2500 rpm, so we don't need to spin very fast. Assure there is no stact rub (rotor scrubbing on stator), or other mechanical issues that need to be corrected for smooth operation.
            When proper mechanical operation is assured, re-connect the series capacitor bank. The initial configuration of 12 (twelve) 2.5 uF, 2000 volt capacitors gives us .208uF, that will withstand up to 24,000 volts. This initial value should be in the range to produce resonance.
            As the machine spins up to resonance, the sound will change, and the rotor speed will lock into the resonant frequency. At this point any further increase of the motor speed control will change the speed only slightly, but the additional mechanical power (horsepower) will drive the core deeper into resonance, thereby increasing the power output. With the single control, the voltage and current (power) can be increased or decreased.
            As previously mentioned, the exciter coil is used to provide a conduction path through the quantum field (zero point) into the generator core. This has the effect of polarizing the core, which increases power output over time. After the QEG is first built, the spark gap on the exciter coil should be adjusted (with power off) to between .005" and .010". Start the generator and let it spark for 2-3 seconds, and repeat this 4 or 5 times. Do this whenever starting the generator for the first few weeks of operation.
            VIDBID
            VIDBID
            • #36
              This is from QEG OPEN SOURCED | HOPEGIRL BLOG
              "First we use a starting power source, such as an outlet or a crank to power the 1 horsepower motor."
              I guess you could also include a battery.
              • #37
                How Are The Coils Energized?
                Thanks, p75213.
                I appreciate the link and your post.
                No doubt that the motor is needed to turn the rotor of the resonator (my term for the generator).
                My question refers to how are the coils initially energized if the resonator (generator) contains no magnets, and if no initial input current is being feed to the coils, how do they (the coils) energize so that a magnetic field can build up in the core?
                These are the relevant passages I found there:
                How the QEG works:
                First we use a starting power source, such as an outlet or a crank to power the 1 horsepower motor. This motor spins the rotor in the generator core. The unique oscillator circuitry configuration in the generator core causes resonance to occur. Once the core achieves this resonance it can produce up to 10KW of power, which can then be run through an inverter to power the motor that spins the rotor. You can then unplug the motor from the original power source and the generator will power itself.
                So that's the key:
                I don't see this "unique oscillator circuitry" in the schematic.
                In looking at the schematic for the resonator (generator), I don't see where there is a starting current to energize the coils. According to Tim Thrapp, the resonator (generator) has "no magnets" in its construction. The rotor is just a slab of laminated silicon electrical steel. Simply spinning the rotor with the coils de-energized shouldn't produce any current. Where does the power come from to energize the coils? Unless the coils are initially energized by the mains power on start up, I don't see it happening.
                I'm just speculating here, but it would seem to me that:
                The output coils L1 and L2 are initially energized by this "unique oscillator circuitry" which I believe is just a switch connected to the mains. With the motor turning the rotor of the resonator (generator), once L1 and L2 are energized and in resonance by the mains AC current, then the circuit for the vibrating coils L3 and L4 is closed, and L3 and L4 go into resonance. Once the resonator (generator) is in resonance, then the starting power from the mains to L1 and L2 is disconnected.
                Then L1 Connector and Neutral Connector is connected to the variac to power the DC motor through a diode bridge.
                Let me know what you all think about it.
                VIDBID
                VIDBID
                • #38
                  A Friend got a Generator for waterpower. It was a normal Motor without Magents, and when it starts running, it had rest magnetism inside the Iron core.
                  It did take a while of running until the Generator did deliver the full Power but mainly it magnetizes allways itself with this rest from the core.
                  Not sure if it works at this Device too, maybe it works faster with this additional power here.
                  • #39
                    Re: Qeg
                    After reviewing the document, I'm left wondering how the average Joe is going to negotiate the 120/220VAC ; 400hz output.
                    Can't sell THAT back to the grid.
                    Construction of the resonator is one thing. Adapting for practical output use will likely cost another several hundred in PF correction, rectification, storage batteries and/or inverters.
                    Reducing the output windings to fewer turns and a thicker 8AWG might get things closer to 12-24VAC which could be rectified to a useful DC current would simplify the end-user's life a bit, but the resonant design would need to be rethought.
                    Hmm.
                    Resonance to all !
                    • #40
                      Quote:Vidbid
                      "My question refers to how are the coils initially energized if the resonator (generator) contains no magnets, and if no initial input current is being feed to the coils, how do they (the coils) energize so that a magnetic field can build up in the core?"
                      Most metals will pick up alignment with earths north and south poles .Generators without permanent magnets sometimes have to be polarized. See link below.
                      Think about Ed Leedskalnin PMH the magnetic flux has to be held in circular path until broken, note that the stator is a type of torus.
                      how to polarize a generator - Ask.com YouTube Search
                      • #41
                        Inverter
                        Hmm.
                        Hi Beamgate.
                        Good point.
                        It looks like the way that they are addressing that issue is to use an inverter to convert the electricity to the proper 120VAC waveform.
                        How the QEG works:
                        Source: Removing The Shackles: QEG OPEN SOURCE PLANS!!!!
                        VIDBID
                        VIDBID
                        • #42
                          Most metals will pick up alignment with earths north and south poles. Generators without permanent magnets sometimes have to be polarized.
                          See link below.
                          Hi ZeroMassInertia,
                          Good point. Since this resonator (my term for this generator) doesn't have any magnets (according to Tim Thrapp), how are the coils initially energized (or polarized if I'm using the term correctly)?
                          However, since the coils are resonating, I'm not sure if polarization is apropos if were talking about resonating coils, but I do believe we need an initial AC signal (electrical energy) to get the L1 and L2 coils resonating.
                          VIDBID
                          VIDBID
                          • #43
                            Hi Joit,
                            Thanks. I think one key difference is we're not just talking about polarizing a generator (which is why I refer to it as a resonator), but getting the L1 and L2 coils to resonate. That's why I think we need some sort of way to accomplish AC signal injection (the so-called unique oscillator circuitry) into the L1 and L2 coils in order to bring them into resonance (in addition to the mechanical action of the rotor of the resonator.)
                            VIDBID
                            VIDBID
                            • #44
                              More Digging
                              In doing some more digging, I found:
                              So, I'm trying to figure out what this means:
                              In the QEG, there is no internal common exciter coil. In addition, to look at the circuit diagram, it is not apparent where the input power comes from to start resonance, and this is key; the QEG exciter coil is external to the generator, and the excitation signal is conducted through the quantum field (zero point) into the generator core, to start oscillation.
                              Apparent or not, an input power is needed to start resonance.
                              This just raises more questions.
                              No doubt. The schematic shows an external exciter (tank) circuit.
                              But where does the power come from to start resonance?
                              It's not apparent.
                              So why not just build a circuit to supply the start power to L1 and L2 ?
                              VIDBID
                              PS: Reference: https://www.google.com/patents/US390...ed=0CDUQ6AEwAA
                              VIDBID
                              • #45
                                As already explained :rest magnetism
                                H.P.Torres explained , you could also connect a voltage to the coil parallel to the cap.
                                And the tank circuit will amplify this to the limits.
                                I wonder, there should be many motors , which consist of 4-pole stators, only for a basic setup for getting resonance.
                                The windings should be between the stator poles , not on the poles themselves.
                                And the rotor should consist of a laminated iron bar.
                                The two coils of the resonant circuit are wound opposite; look at the dots.
                                Eventually we must rewind one of them.
                                If turning the rotor does not result in an huge voltage for a given rpm, we could stop there , because requirements not met.
                                So looking for that pre-built 4-pole stator ... any ideas?
