Analysis of the WITTS Generator
  • #16
    Hi Laurent,
    In the meantime Miroslav answered my questions on his test setup of the 2nd video, see here in the other thread:
    So it seems the precise winding on the half toroid core is a must; he used laminated core and he also wrote that the distance between the core and the magnet to be minimal. This latter surprises me a little, for I though a special ratio in the diameter of the core + magnet is also required, now it seems not.
    An important drawing is shown (post #7) in the middle: the center line of the magnet and that of the core should match!
    Regarding the coil windings, it seems that the turns should come to the very edge of the core and there can be no unwound core area left at the edges.
    I understand your points of views you wrote above on this setup after you did the tests. Miroslav is willing to answer questions.
    Greetings, Gyula
    • #17
      Led
      LED
      Run Simulation
      VIDBID
      VIDBID
      • #18
        Parallel-series Resonance
        Parallel-series Resonance.
        VIDBID
        VIDBID
        • #19
          Parallel-series Resonance Motor Generator
          So-called Parallel-series Resonance Motor Generator.
          Is something like this happening in the WITTS generator?
          VIDBID
          VIDBID
          • #20
            Video of WITTS Motor Generator Replication
            Please take a moment to check out this video.
            YouTube Video: Analysis of the WITTS Generator - YouTube
            VIDBID
            VIDBID
            • #21
              Parallel Series Resonant Circuit
              INPUT: 160VAC
              LOAD: 100W
              C = 10uF
              Lp = 703.62mH
              Ls = 703.62mH
              Run Simulation
              VIDBID
              VIDBID
              • #22
                I have been working on the ACMM 381.970
                Hi, i have been working on that device to, i call it the ACMMJB
                Testing ACMMJB v2 TPU ECD Plus Joule Thief, Special Effect With Iron Wire - YouTube
                Im in progress of doing more different tests.
                Greets JB
                Thanks, GSM.
                Well said. Now if I could only understand it. Well, I'll try. LOL
                What if I fed only half a wave into each group of the two groups? See the document. What if I took the cemf from the primary coils and used it to charge caps in a snubber circuit. I guess I could feed that charge back to the battery, but I'm getting ahead of myself. I've got an idea for a solid-state circuit. I hope to include it in the next update of Analysis of the WITTS Generator
                http://youtube.com/johnnblade
                • #23
                  Hi Vidbid,
                  I'm new here, very interesting thread.
                  Where did you find the video of this austrian fellow? Is it possible to contact him?
                  Thank you
                  Gizeh
                  • #24
                    Originally posted by Gizeh View Post
                    Hi Vidbid,
                    Thank you
                    Gizeh
                    Thanks, Gizeh.
                    You would be simply astonished if I told you.
                    Sorry, it's not possible to contact him.
                    He wishes to anonymous, and we must respect that.
                    VIDBID
                    VIDBID
                    • #25
                      Negative Power?
                      Interesting Readings.
                      Run Simulation
                      VIDBID
                      VIDBID
                      • #26
                        Flywheels
                        Gen-E-SysII
                        backgauges.com - Page 2
                        To Quote: 4. Would the "energy" DEVELOP progressively with Velocity or just poof into existence all of a sudden?
                        What do we get if we DEVELOP and ADD ADDITIONAL "ENERGY" exceeding the very real losses at every such conversion we currently accept as just the way it is?
                        End Quote.
                        Notice in Bedini's work the flywheel - Spinning mass. It is in his free energy generator. In is in his "Watson Machine". It is in his Ferris wheel. It is used in the Kromrey converter.
                        Another quote from backgauges:
                        SIMPLE PROCESS - OVER EFFICIENT DESIGN
                        Small electrical input to a motor, converting electrical to mechanical power,
                        Use the mechanical power to place solid matter in motion at velocity to develop KE equal to converted input power,
                        Use mechanical advantage to multiply/develop torque at reduced rpm,
                        Use the increased torque to place an additional greater volume of solid matter in motion thereby developing more KE, greater Inertia & momentum,
                        Use another mechanical advantage to again multiply/develop more torque at reduced rpm, and use a mechanical disconnect from previous rotating matter.
                        Use the increased torque to again place an additional greater volume of solid matter in motion thereby developing even more KE, greater Inertia & momentum,
                        Use a final mechanical advantage to adjust/match rpm for output to an electrical power generator/alternator.
                        Understand, comprehend this process alone yields more HORSEPOWER output than input without burning one drop of extra fuel, that is FREE ENERGY.
                        End quote.
                        • #27
                          thank you for the answer,Vidbid. I understand.......
                          Gizeh
                          • #28
                            Video
                            Gizeh
                            Gizeh,
                            For you, I'll tell you where you can see the video.
                            #185 Brother Richard Maclone on Baptism; Tonight: Hoverboards, Antigravity, and Another 3kw Replication - World Improvement Through The Spirit Ministries
                            at 43 minutes, 33 seconds.
                            VIDBID
                            VIDBID
                            • #29
                              Witts and QEG
                              Please review the Schematic of the QEG in the download from hopegirl it appears that Witts and QEG are similar.
                              http://hopegirl2012.files.wordpress....al-3-25-14.pdf
                              • #30
                                I could see it.
                                I think this is the PDF URL that you're looking for:
                                Code:
                                http://hopegirl2012.files.wordpress.com/2014/03/qeg-user-manual-3-25-14.pdf
                                Transformer Dot Convention: The voltages at the dots is the same polarity. If the voltage on the primary dot is positive, the voltage on the secondary dot will be positive; note that in this case there is current into the primary dot, but out of the secondary dot.
                                Source: https://answers.yahoo.com/question/i...6184434AAeQIF6
                                VIDBID
                                VIDBID
