Hi folks, for those observing this thread, just want to offer some tips, if anyone decides to build something similar to the way this stock pot friction heater is built.
Was all set for testing, when i realized the shaft was wobbling.
The nuts that were holding the shaft to the wood plate that is connected to the top of the steel stock pot, were causing a slight tilt relative to the shaft and this added to the wobble.
Fixed that by using a small cast metal belt pulley and jb welded it to the wood plate and used the set screw to secure it to the 5/8" threaded stainless steel shaft.
Also, for some reason, the wood particle board plate itself, maybe slightly warped and is causing a little bit of that wobble.
Also, reinforced the bottom of the steel stock pot with 3/8" thick mdf board and jb welded it to the inside bottom of rotating drum.
This stiffend up the stock pot greatly and after running a dry test run, it has very slight wobble and seems acceptable at high speed.
Now i should be able to actually get some testing done with the vegetable oil inside, after i get back in a day or so.
Maybe i should have put the shaft all the way through the rotating drum from the start, now it has a 5/16" bolt secured at bottom, which seems to work well for now.
Will report results if it remains stable and sturdy enough to get results, hehe.
peace love light
tyson
peace love light
tyson
