Translation Request
I put that text through Google Translate and came up with:
Aluminum tube only in the place where the resonator, the resonator is not the entire length, and less than half the length of 0.2 mm diameter wire somewhere, so basked videmo. At first when I was a piece of paper between the tube and the resonator Aluminum then sews her and spoil even the turns of the resonator, that is the force that through the paper please! On the load is connected and 200 watts and 2.4 kilowatts, but never achieved the lamp to light up. Only they fitonka blue walking hand embracing especially lamps and more everything. Capacitors 4 microfarad 400 volt two series so that a 800 volt and 2 microfarad. So there is something in this scheme, especially I was not expecting that so Aluminum between the tube and an open cavity so can sew. The resonator is probably about 200 turns. Its diameter is about 1.8 cm, while the tube 5 cm Honestly, I repeated this scheme
The above translation could use some refining.
Berg
Berg
