In one plaise it say that resonator makes hot. In other, that all worjing how he write. In plaise there wires from lamp going he say that wires going back for self runnig... Then disconent clip from capasitor he say that it is ground wire and without ground wire system not work and lamp not light.
Translation Request
Bronepoezd
Originally posted by SunofFather View PostIn one plaise it say that resonator makes hot. In other, that all worjing how he write. In plaise there wires from lamp going he say that wires going back for self runnig... Then disconent clip from capasitor he say that it is ground wire and without ground wire system not work and lamp not light.Hi SunofFather,Originally posted by SunofFather View PostThe real author of this video is Bronepoezd, not icaco.
Thanks for that translation.
And.. Thanks for that name. Bronepoezd
There's a video on YouTube with that name.
By the way, the original video is at
Поверка эффекта. - YouTube
It looks like we need another translation.
It also looks like he did an update at
Проверка эффекта 2. - YouTube
And.. there looks like there is another update.
Проверка эффекта 3. - YouTube
And yet another Проверка эффекта 3. - YouTube
Russia
Why is it that , for the most, the majority of people working on this technology are Russians. It seems that they are the only ones who are working on this technology, and promoting it?
Very few people in the West are working on this technology. Why is that?
Russian SRD
Russian Series Resonance Device
Bronepoezd Self-Looping Device
I found more discussion on this device.
Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Also: Опыт 12 08 12 - YouTube
Sort of a precursor device of the device in the first video referred to in this thread.
Originally posted by SERG V. View PostOnly for Experimenters
Гость УСТАНОВКА 2 kwatts on 220V
Гость УСТАНОВКА - YouTube
Author achieved 2kWatt output power with 100watts input.
Use Nanoperm stripes 2cm = about 1 inch wide.
Master ТДКС oscillator (HV-TV transformer with built in HV diode(s)) must be very stable and thermally compensated. Any industrial ШИИ (PCM) will be good here. Also you can use master oscillator based on microcontrollers and high speed mosfet drivers. For isolation use GDT gate drive transformers. Optics is too slow here. Schematics can be found on internet.
This circuit need very fine tuning and very sensitive is to pulse-with and Cкважность parameters.
Cкважность is our Russian term and means pulse period-to-pulse duration ratio or relative pulse duration.
S=1/D
D= duty cycle.
Use Aviation aluminium for tube. Diamtere 5 cm - 2inches. Bifilar was wounded in counter-plan. 1/2 half righ direction - other 1/2 left. About 80 windings each. Output power also depend from distance between Nanoperm windings. Tune it between 1-2.5 mm and keep the distance step constant.
Use good Earth grounding. Heavy cooper bars deep in wet soil and check earth conductor with compass !!
Удачи !!
Translation Found
Found Translation:
Source: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Author (not ikako chubinidze) achieved 2kWatt output power with 100watts input.
Use Nanoperm stripes 2cm = about 0.78 inch wide.
S=1/D
D= duty cycle.
Use Aviation aluminium for tube. Diamtere 5 cm - 2inches. Bifilar was wounded in counter-plan. 1/2 half righ direction - other 1/2 left on whole lenght. Output power also depend from distance between Nanoperm windings. Tune it between 1-2.5 mm and keep the distance step constant. Use good Earth grounding. Heavy cooper bars deep in wet soil and check earth conductor with compass !!
Удачи !!
ps: It seems to me there only couple of CE people doing experiments. Other fishing in "troubled waters".
Possible HV Secondary Coil Configuration
Comments are welcome.
What do you think the term "Counter Bifilar" means.
Berg
Counter bifiliar means, that you wound, wound to one side clock wice and after center isolate and wound caonter clock wise. Like in this picture. http://img560.imageshack.us/img560/1644/ax56.jpg
L4
Thank you, SunofFather!Originally posted by SunofFather View PostCounter bifiliar means, that you wound, wound to one side clock wice and after center isolate and wound caonter clock wise. Like in this picture. http://img560.imageshack.us/img560/1644/ax56.jpg
Your contribution to this discussion is most welcome and considered an extremely useful source of information.
If I understand you correctly, the L4 coil, which is what we're talking about here, is made up of two coils, one coil is wound in a clockwise (CW) direction, and the other coil is wound is a counterclockwise (CCW) direction.
I wondering why is the term bifilar being used?
This is my understanding of a bifilar coil:
and
"normal" bifilar coil:
Berg
A Possible Design for L4
L4
Based on my understanding of what a bifilar coil is, I'm putting forward that the following design is a possible design for L4.
Where I refer to it, I'm using the designation L4 for the secondary HV coil assembly, the same as the L4 used in the diagram below.
Comments welcomed.
Berg
Nanoperm
I think I can understand why you would want to use Nanoperm.Originally posted by SunofFather View PostNot nanoperm stripres, but nanoperm tape. In russian is лента, thats means tape.
Looking for source for Nanoperm tape.
1. NANOPERM cores, NANOPERM toroidal cores
2. a23 pace-nanoperm
3. Magnetec Nanocrystalline Cores: Company Overview - YouTube
4. Ferromagnetism
5. MAGNETEC GmbH: FAQ
Berg
Magnetic Permeability
Only Metglas out-performs Nanoperm.
Source: Permeability (electromagnetism) - Wikipedia, the free encyclopedia
What about Magnetite? http://www.energeticforum.com/renewa...ite-cores.html
Inconclusive.. You can make cores out of Magnetite (Magnitite Cores 2 - YouTube), but it's relative permeability isn't all that high, as compared to Metglas, from what I can tell. Well, I wasn't able to find a value.
What about Mu-metal? Source: Mumetal Nikel Permalloy Magnetic Shielding Foil Sheet MU Metal 0 1T N | eBay
Berg
