Is Wind Energy Headed toward CWAT (Compact Wind Acceleration Turbines)?
  • Is Wind Energy Headed toward CWAT (Compact Wind Acceleration Turbines)?
    Here's a post from jibbguy I just read:
    Originally posted by jibbguy View Post
    As stated before, "suppression" is not always only about exotic , "free energy" devices and technologies; but could also be about "game changing" conventional alternative energy techs (such as highly efficient solar pv as mentioned in the "thread-starting" document that governed which Patent Applications were to be "secretized" by the US government).
    This is an interesting development (though perhaps a sad one):
    The "FloDesign Wind Turbine" was a revolutionary design, that claimed 3 times better efficiency and lower cost than the large "prop-job" wind turbines usually seen (...a market dominated by General Electric corporation in the U.S. ). It would also allow for de-centralized energy production... and destroy most of the negative points about wind power that the energy corporations use in their propaganda against it... such as: it is easy to "exclude" birds from, can operate in both higher and lower wind conditions, is nearly silent, is close to the ground so the "natural beauty" of the area is not "polluted" (lol that one always makes me laugh), and it would be a lot cheaper per megawatt to build and install. It could also be easily incorporated into the sides or roofs of large buildings.
    FloDesign :: Aerospace Technologies Everywhere
    Recently I checked back there, as i have done several times over the last 3 years since it was first reported on in a few science online magazines, to see the "Progress". Mention of the wind turbine has disappeared from the site (replaced by a variety of "Homeland Security" products including "non-lethal weapons").
    The short animated video that did a good job of describing and demonstrating the technology is gone too.
    Wind FloDesign Wind Turbines based on Jet Engine Technology display 3-4 times Higher Efficiency
    In case the last available photo of it disappears too, here it is
    I believe many of you read the previous posts about it and remember this one.
    Is it a "good" example of suppression? Hard to say for sure, i have yet to hear back from them from my email asking about it. Was it sold off, and "shelved", by G.E. or another corp? It was reported to have been awarded funding by several high-power entities, and the U.S Department of Energy. It was not something plausibly likely to be just "dropped" because they got bored with it
    Note that in the above article, it reports that the entities that signed on to fund the project included "Goldman Sachs".
    In the removed video, it described an interesting vortex effect in the "exhaust" turbulence after the turbine blades that was the reason it was so efficient. Rather "Schauberger-like" ; but with air as medium not water.
    EDIT: I went back and found the other article on this subject, on this same thread from over 2 years ago... and the video is still on that one. And i now remember something odd about it since re-reading that post: It was the only time that i know of, where a post was removed (or otherwise "disappeared"), without my action on our "Free Energy Facebook Group" (...since i am the only admin of it). Since after that time, the group got "reset" when FB "re-did" the Groups, and a lot of the older posts got wiped; and i had forgot about that strange happening from before the "re-set".
    Wind Turbine Concept Inspired by Jet Engines
    Seems CWATs are not so 'secretized' after all, if we can trust Wikipedia:
    CWATs are a class of wind turbine that uses structures to accelerate wind before it enters the wind-generating element.[1] The concept of these structures has been around for decades [2] but has not gained wide acceptance in the marketplace. In 2008, two companies targeting the mid-wind (100 kW-1 MW) marketplace have received funding from venture capital. The first company to receive funding is Optiwind, which received its series A funding in April 2008, and the second company is FloDesign Wind Turbine Corp, which also received its series A funding in April 2008. Optiwind [3] is funded through Charles River Ventures and FloDesign is funded through Kleiner Perkins.[4] Other CWATs under development include the WindTamer from AristaPower, WindCube, Innowind (conceptual offshore application) and Enflo turbines.
    CWATs are a new acronym that encompasses the class of machines formerly known as DAWTs (diffuser augmented wind turbines). The technologies mentioned above all use diffuser augmentation that is substantially similar to previous designs as the primary means of acceleration. DAWTs were heavily researched by K. Foreman and Oman of Grumman Aerospace in the 1970s and 1980s and Igra in Israel in the 1970s. At the end of a decade of wind tunnel research and design funded by Grumman, NASA, and the DOE, it was determined that the DAWT system's economics were not sufficient to justify commercialization. In the 1990s the Grumman technology was licensed to a New Zealand company, Vortec Wind. The attempt to commercialize the Vortec 7 in New Zealand from 1998 to 2002 proved it to be economically untenable when compared to the dominant HAWT (horizontal axis wind turbine) technology.
    Ultimately, any wind turbine design must be measured against economic realities. It must positively answer the question, "is the cost to install and operate the system lower than the cost of other alternatives, including the local electric grid?" Historically, CWAT/DAWT designs have failed to overcome this hurdle as compared to more conventional HAWT designs, however, there is reason to believe that this equation may be shifting towards these new designs. The two primary drivers of this equation have been the amount of augmentation and the structural implications of these additional design elements.
    For the highest claimed velocity increase in a DAWT of 1.6 x freestream
    Power ratio DAWT to HAWT = (1/2.75)(16ms/10ms)3 = 1.48 increase
    Not significant enough to offset the associated costs. The problem with optiwind is even more severe since the system only covers a fraction of the swept area available to a HAWT of the stack height.
    The challenge has always been, and remains, installing, operating, and maintaining these structures for a cost that is less than the incremental value gained by their presence. Recent developments in material science, installation methodology and overall system integration have led to the far more realistic view that we are very close to this advent and the dawn of a new, highly sustainable class of wind turbine if the issues elucidated above can be dealt with which still remains highly questionable for the DAWT geometry.
    Among the recent DAWT designs that appear to have a definitive positive power, if not cost, comparison to HAWTs is the Enflo turbine. Based on its rotor:exit ratio and the published power performance this turbine appears to have a confirmed 2 times increase in power output over a HAWT of the diameter of the exit area. It is still unlikely that this machine can scale to larger ratings but based on published data the Enflo appears to be the best performing DAWT/CWAT yet built.
    BTW: One thing jibbguy didn't mention on that Suppression Document and YouTube post was that FloDesign, itself, and by it's own admission is... get this! ...a world-renowned expert in suppression technology
    ...mixer/ejector suppression, that is:
    ..Yes CWATS/DAWTS are the future?!""
    ...they are also part of the past and present tech development. This device (in link below) is arguably the first wind-turbine (ducted), as opposed to wind-mill. And French. Visually speaking, this design has survived, although with various iterations from a multitude of developers over 150 years. The performance is also listed ~ roughly 20-30% Cp when referenced against the shroud and done in 1868! Some SWT's today can't beat that and the ones that do aren't beating it by much.
    There is a lesson to be learned or a talking point. The machine depicted in the linked pdf flourished because of market demand, initially in water pumping and later electrical generation. The demand for SWT's and mid-scale size machines, and water turbines today (US) is practically non-existent, although demand still exists in rural, off-grid settings, wherever that may be.
    Here's a quick rundown on the litter box of SWT's that are gone within the last year and a half:
    -SouthWest Wind Power, (20 years) and kaput. interestingly enough this company began and flourished without subsidies during its formative years, subsidies just didn't exist then, and none of the designers cared. Go figure that!
    -Proven Energy, (15-25 years). When blades fly off in a hurricane and generators blow-up, it's never a good thing.
    -Windspire (VAWTS). Saw that one coming. PR machines are of little value.
    Several other VAWTS startups and older are also defunct. Poor performers
    overall. If the machine cant beat a 150 year old design, why bother.
    -Ventera- in limbo, defunct? not 100% sure, but not much going on there - but a very capable and performing SWT. Their design team built SWWP.
    -Elena Energie - closed the doors. Ducted turbine mfg. - French
    -Windtamer/Skywolf/Arista Power - pictures and prototypes only. Machine never worked at all, not even close to ideal performance of a ducted turbine! After 50 installations, customers demanded their money back. Not all ducted turbine are created equal. Don't assume a circle with a prop inside it is going to perform as expected.
    -OptiWind-done. See remarks above
    I am sure there are others in the process or already gone but don't care to publicize it. That would leave a handful of cos in SWT and mid-scale (ducted or conventional design) on the playing field.
    What biz model can support new markets or low demand for CWATS/DAWTS?
    Freemium hardware. What's to lose.
      So, frequent thread starter, your point is what... that it is was not suppressed, because water pump windmills existed 150 years ago and others are being developed today?
      Later i got and reported on an email from them that was not mentioned in your repeating of my post (a couple weeks after the last time i had contacted them), that said they are in "stealth mode" while they build more prototypes, and that's why it was all removed from their site and nothing has been seen since... for over 2 years.
      Interesting business model, eh? For a corporation that has moved to making "non-lethal weapons" for the Department of Homeland Security, after getting funding from Goldman Sachs, that seems like a rather bizarre way of reaching market.
      .... but we could probably exclude the possibility of a harmless 1,000 year old technology being held "secret for national security".
