Laserjo Set Up
Hello Laserjo,
First, many thanks for coming back here to post your results, I have done dozens of Diagrams for people I never heard off ever, again...but is Ok, am glad We still have Members like You that do come back...
If all the ones I have rendered so many, several diagrams, have done what you have done, not wasted so much time in BLA,BLA,BLA...and get TO BUILD...and so fast response, like You...We would be very ahead of where we all are standing right now.
Many Thanks, and am glad about your test results.
Below, is a Diagram of what I understood you did as connections...based on your explanation above plus the Main Picture you have posted below Diagram.
[IMG]
[/IMG]
[IMG]
[/IMG]
The only thing you forgot to mention in your above text description...were the Two Bottom, Rear Black wires joint together and back to Battery Negative. ..but no sweat, I found them on picture...
Great work Laserjo, and many thanks.
I have some tips on adjusting properly the Output Brushes on this type of windings...so We get even more Energy on the Output...be next.
[IMG]
[/IMG][IMG]
[/IMG]The only thing you forgot to mention in your above text description...were the Two Bottom, Rear Black wires joint together and back to Battery Negative. ..but no sweat, I found them on picture...
So will this affect the performance of the device? I will have all 8 brushes independent and not grounded to case. If I must rewind with smaller wire I WILL cause I've struggled with this for some time. Not as much as you, I know. But I want to use this to keep my solar banks charged. Then build the Imperial to propel a small EV. Then maybe a scooter or who knows after that.
...You could run it...and it would be fun cause you get some weird output off ground...and very sharp and high currents...and the interesting thing is...you could add it (ground body signal) to either Positive or Negative Output wires, and it will read V & A and lite up incandescent bulbs...or else.
