Amp Draw
Hello Dave,
Let me ask a silly question...Are you applying an Electrical load to Machine Output when running the Dyno test?...I mean, as simple as some CFL's, let's say five of 23 watts connected in parallel?
I strongly believe that would help to lower the Machine running Amps inside armature coils...
My Machines if you do not provide an "Output Gate Relief"...the currents will keep bouncing back at your Input...and as more mechanical load you apply to the shaft when making the Dyno Testing (which lowers RPM considerably)...the Higher the currents you will get there my dear friend...and they have to go "somewhere"...so they are kicking back at your Input Meter...
Now, I do not believe that is a real Amp draw from battery...let me ask you something...Do you have a Battery Load Tester?...the ones that come with a huge resistor inside...NAPA have them...if you do, make a reading before and after Dyno Test on Battery...to see if it lost any Amperage under Motor load...
Oh!...And You are sooo "upset" to keep playing with your three batteries!!...
Yeah right!
Thanks I got the schematics.
In the meantime, I will be FORCED to play with this motor on the 3BGS.
Yeah right!
[/IMG]
