Symmetric versus Asymmetric Electromagnetic Systems
  • #61
    Symmetric Generators brief Review...
    A Generator contains (basically and briefly) three circuits.
    1- The Stator Field: Stator meaning, it always maintains a steady static, magnetic field polarity. They could be Rotary, where the electrical feeding is done through continuous slip rings contacts. Or Stators could be "non movable", more likely structurally set in the outside of the embodiment.
    2-The Generating Fields: They are located opposite facing the Stator Fields, wherever they would be, In or Out.
    3-The Exciter Fields: They are in charge to keep feeding "linear" current to Stators via the slip rings, rectified by a couple of diodes, in order to always get DC on them. And most of times they are double opposite coils not to "interrupt" the sequence in either position of the magnetic poles. They are located in between the Generating Fields, facing the Stator Fields.
    First thing wrong In Symmetric generators:The generating fields are connected in a multi-filar heavy gauge wire (14-16) depending on output spec's, BUT always interconnected between them in an array that could be parallel or series. This connections derive in a negative performance, because the fields that are not being induced in that "momentum" that stator is NOT passing by, receive current from the ones being induced, therefore they magnetize against rotation, create drag and magnetic friction, besides reducing output because their electrical consumption. Here is the main reason why, the more we add "Loads" the more this generators oppose to our "Prime Mover"...
    If we look at all Nikola Tesla Generators and in general all his Electro-Dynamic Machines. He ALWAYS states to use Independently connected coils sets in Pairs or Groups of Pairs (why in pairs?...well to satisfy the positioning of the Static Fields at the 180 degrees timing ). He uses dual or more -according to set-up- output slip rings for each group of generating fields. Further on, this way to interconnect the Generating Fields allows to "exchange" coil components with a Motor Assembly in a timely sequenced fashion that He also, nicely displays in every angle of rotation to fulfill the whole 360 degrees...
    Now, We will NEVER be able to make this happen, to accomplish this extremely important "exchange of components" in ANY Symmetrical Arrangement, simple as that, Ladies and Gentlemen!!
    Second thing I see wrong with Symmetry in Generator arrangement is to "Linearly Feed" the Stator Fields at all times, when they could be easily Pulsed, therefore, obtaining the Natural Response from our Nature to energize the Generating Coils while we give a "brake" an Idle to our Stator Feeding process. This Opposite Nature response, instead of creating drag, it could assist rotation, if, set up in a convenient and preconceived fashion.
    Now, the arrangement of a typical Alternator in any given vehicle is even worst, related to the way the Stator displays its magnetic field at the whole 360 degrees based on the Spider design, and "On" at ALL Times...but I guess it does not matter...if we are using a heavy muscle big HP Gas Engine...Right?
    Well, this fact adds enormous drag on our engines, creating our "Idling RPM's" at very high rates...but it doesn't matter either...we just add more Gas to it and problem solved...
    Thank You and regards to all
    • #62
      Original Maxwell Equations
      Aether Flow -- The True Electric Current?
      www.zpenergy.com/downloads/Orig_maxwell_equations.pdf
      • #63
        Electric field longitudinal wave is flowing and it's the same as sound except it is aether which is the medium, not matter (mass). Then charge must be condensed aether and it slowdown the flow. Or something like that, but surely electricity is a sound-like flow.
        • #64
          The problem is, is that there has to be ccw flow as well as cw flow, they will not flow parallel with each other, they are two separate monopoles that when separated will only flow with like angular direction. When combined they form the magnetic field as we see it, when separated they are cold and hot electricity.
          If you do not allow for one side in your build it will hinder and oppose flow through the system.
          Its like a stream flowing that forks in to a Y if both can flow everything is fluid motion but if one side is dammed it will back up and oppose both flows.
          • #65
            The same is true for mechanical systems as well as electromagnetic systems.
            • #66
              End of Wardenclyffe Tower...
              "...It is not a dream, it is a simple feat of scientific electrical engineering, only expensive-blind, faint-hearted, doubting world!...Humanity is not yet sufficiently advanced to be willingly led by the discoverer's keen searching sense.But who knows?
              Perhaps it is better in this present world of ours that a revolutionary idea or invention instead of being helped and patted, be hampered and ill-treated in its adolescence-by want of means, by selfish interest, pedantry, stupidity and ignorance; that will be attacked and stifled; that it pass through bitter trials and tribulations, through the strife of commercial existence. So do we get our light. So all that was great in the past was ridiculed, condemned, combated, suppressed- only to emerge all the more powerfully, all the more triumphantly from the struggle..."
              Nikola Tesla (At the end of his dream for Wardenclyffe)
              • #67
                Is sad that Tesla's dream was crushed by the industial complex that he enabled to vastly increase their empires.
                Being very bitter in this quote is understandable and is cruel fate that he did not implement PURE Radiant devices before his well known, still used AC motors/generators.
                Zero
                • #68
                  Yes, agree..ZPE
                  Zero
                  Hello ZPE,
                  It is indeed sad...however, Tesla's legacy to our world will re create the Asymmetrical School of Engineering back again, and this time stronger than before, applying all the state of the art tech available now days.
                  Of this statement above I love the final paragraph, which is the one we belong now to take into effect and make it a reality.
                  After all this black and gray clouds are over and gone..it will come the "Judgement Days"...passing for all the required ridiculization, condemned and combated to exhaustion on our side.
                  • #69
                    Hey UFO
                    Great posts UFO. Without the mechanical background, I knew but never really understood why (never thought about it much I guess), why the counter-force against our input developed in an alternator. So its because the coils that are not getting a voltage drop across them are still conducting the induced current (opposing)because they are in connected in series or parallel.
                    It hard to believe it is that simple. Keep them isolated.
                    So we have to use pairs of seperate coils. How many pairs are you using?, are the opposite coils same length?, do they feed into a common capacitor bank?
                    Maybe I'm totally off here?
                    Thanks so much UFO
                    Thug
                    • #70
                      No, You do NOT have it totally off...
                      Originally posted by thugugly View Post
                      Hey UFO
                      Thanks so much UFO
                      Thug
                      Hello Thug,
                      You are ok...and yes it was so simple...that many are just going to laugh out loud... when this is over and done...
                      Coils in Pairs are all same length, that keeps a magnetic field "balance"...
                      I am using different embodiments...from three to sixty...poles, so as many you could fit there...degrees are very important, where "not necessarily" have to be 90-180...
                      If you feed coils to any component that will create a closed loop...without any "one way" blockage, they will get through feed back the counter effect...by self magnetization...
                      An Alternator, or a Vehicle Alternator (as I know it)...maintains a constant linear current applied to its rotary stator (spider types, Upper and Lower poles N-S through their teeth)...So this type of Generator is a completely Symmetrical "Full Time" Counter Effect...at all times it is offering resistance to rotation...
                      It is not only to keep them isolated (that is a major part though)...but also Asymmetrically disposed and performing...
                      You will see it all very clear my friend, very soon...in beautiful 3D transparencies...State of the Art beauty and disclosure...of the real truth.
                      • #71
                        Indeed. Very good Ufopolitics. We have to realize true nature of Lenz law, then everything is easy... even magnetic motors are possible but there always has to be small "kicking" process to sustain ... Wesley Gary neutral line...
                        Just a few thoughts....
                        • #72
                          Dear Boguslaw...
                          Thanks Boguslaw,
                          Yes indeed, We all need to realize the true nature of Lenz law...However, mainly we have to learn between "False Lenz Laws Manifestations" when they are basically and merely originated by an specific model natural behavior...locked up in time...
                          Regards friend
                          • #73
                            Hi Ufo,
                            Any idea when your next video will be completed? Have you made any progress in building an asymmetrical motor?
                            • #74
                              Hi Wonza
                              Originally posted by wonza View Post
                              Hi Ufo,
                              I will launch a "Technical Info" video on the 4th of July...
                              And yes, I have built several different types of Asymmetrical Motors configurations, the list is long, You guys will have your hands full very soon...I can only see you...
                              They are ALL Successful by now Wonza...They all are COP over 1...and then some...it will be "Up to You guys" how much above the "impossible" COP>1 You want to go...
                              Trust me...no BS
                              Happy Independence Day!!
                              I will see U then
                              • #75
                                Hello ZPE,
                                Hey Ufo,
                                I wish to 100% understand Tesla's legacy of Asymmetrical Motors other than independant circuits for the coil pairs.
                                IMHO I honestly see the inbalance between the pairs of coils is what Tesla alludes to in Patent # 524,426.
                                I know you do not agree with my analogy but maybe is the same thing in a different terminology.
                                Still looking forward to your YouTube clip to confirm or squash my theories
                                Zero
