Use for the Tesla Switch
    Hi all,
    I have postes some interesting info over in this thread:
    It appears that the high voltage spikes JB likes to see in these kind of circuits are capable of creating electrets inside capacitors and probably batteries also. That would perfectly explain the strange phenomena reported by some, which is that "radiant conditioned" capacitors can spontaneously recharge themselves and that "radiant charged" batteries continue charging for sometimes hours after the charging circuit has been disconnected.
    Hi Lamare
    I would agree with this and have attached two pdf's I wrote some time ago after noticing dentrite growths on the electrodes of water cells and then subsequently lead acid battery cells.
      Hi all,
      @lamare and Dave,
      It make a lot of sense, at least to me Seems that crystals growth in capacitors and on the surface of battery plates are not just increasing plate surface but much more. Thank you for explanation
      Vtech
      General D.Eisenhower
      http://www.nvtronics.org
      • Frying diodes
        @JB,
        I was not using power diodes....I didn't think I'd ever need them, but my circuit was hooked up incorrectly. When I hooked it up correctly, I started frying diodes. Now, I may have had it at one time hooked up correctly, and I was just switching to the Brandt version, because before I was using my own cooked up version based on your 3 battery switch. When I did this, my diodes started to fry....Any suggestions on the power diode to use? There are many available out there. I'm guessing a 30-50A is fine, fast shutoff time < 100ns, 35V or better, forward drop, not too important. If you do not want to instruct us on the power diode to use, then some specs would be appreciated.
        Maybe it is now hooked up incorrectly. But I checked, rechecked, etc. I did have one diode that was pretty big, put that one in....so it decided to fry a DIFFERENT one. The joys of learning.
        I'd love to have a board. Designing one now. Have all the stuff I need to make it, just the design...part and most of that is done.
        Leroy
        P.S. Sorry to ask...I know you hate that! It will depend on the application, right?
        • Tesla Switch
          Leroy,
          Sorry but work calls, here is my battery test. The battery is out of an alarm box and the battery would not take a charge so I just used it in the test machine. I just left it on the potential switch to see what would happen. At first you can see the surface charge and then it fall down under the 1 amp load which is way to much for this battery, but I did it anyway. so here is what a dead battery did that could not be charged.
          JohnB
          John Bedini
          www.johnbedini.net
          • Tesla Switch
            I have been useing the STPS8H100D diodes
            John B
            Originally posted by ldissing View Post
            @JB,
            Leroy
            John Bedini
            www.johnbedini.net
              John B
              Datasheet here:
              STPS8H100D datasheet pdf datenblatt - STMicroelectronics - HIGH VOLTAGE POWER SCHOTTKY RECTIFIER ::: ALLDATASHEET :::
              http://teslagenx.com
              • SCR PIC controller
                Team, here is a first cut schematic of the SCR PIC controller of the TS. Code will follow shortly. Please look over to find mistakes.
                Bit's
                  John B
                  Thx, JB.
                  Found em...ordered em.
                  • Originally posted by Bit's-n-Bytes View Post
                    Bit's
                    I believe you are missing a connection from the diodes going to the right most batteries from the left upper battery. Did not look at your numbering. Could be wrong...check it out.
                    Leroy
                    • Originally posted by ldissing View Post
                      Leroy
                      It's there (if it is the top line the one your talking about).
                      BTW the diodes used at D2,D6 and D4,D6 are Vishay 30CPU04PbF and the SCR's are F0810BH Fast SCR, 8.0 A 200-800V, 10-25ma (TO-220 case).
                      Bit's
                      Edit; Thanks Leroy
                        Bit's
                        Edit; Thanks Leroy
                        Sorry, I see it now. I'll be more careful in the future.
                        D8 has its input from the positive of the 4th battery, not the negative. Hope I'm right this time.
                        L
                          L
                          Your right, thanks;
                          Bits
                          • Tesla Switch
                            Bit's,
                            I did not hook up my circuit that way with the optos. They are hooked right to the SCR's. they do not hook to the positive of the battery.
                            John B
                            Bit's
                            John Bedini
                            www.johnbedini.net
                              http://www.vishay.com/docs/94013/30cpu04p.pdf
                              F0810BH (STMicroelectronics) - Fast Switching Scr
                              Vtech
                                Bit's,
                                John B
                                Thanks John. I changed the drawing per your design.
                                Bit's
