Use for the Tesla Switch
  • ewizard
    Hi ALL
    Guys, the sacred ratio or the golden mean 1.618 is the ratio that gives the RV the harmonics, does any one know how you would build a various type of SIZED cone based ON THE GOLDEN SECTION? For example, how can a cone that's 4 X 4 have the golden mean dimensions and a cone that's one meter high can have the same golden section? I guess like the Pyramids can?, but cones, hmm.Apparently Boeing wind tunnel tested their designs to show that it likes the golden section and are based on it, any one know any thing about this how to build different sized cones on the golden section?apparently this book might have some clues.
    The power of limits: proportional ... - Google Books
    Ash
    If you haven't seen Dan Winter's info you might try wading through some of it
    here
    I've seen Dan in person before some guy tried to squash him with a lawsuit and ended up driving Dan out of the U.S. His work with sacred geometry and the Golden Mean is extensive.
  • nvisser
    That will mean that we have to extract that 10A from the 1 bank while it is still in recharge mode because we hit it so hard. That comes down to timing again.
    Jb said somewhere that the magic lies in the devices (transistors) and not the timing.
    I tried to charge up 15000uf caps first and then discharge them onto the second bank, but you loose more on the discharge bank then you win on the charge bank. May be timing will help here but the JB circuits mosly used 50 duty cycle. He did mention that you can go down to 10%.
    What looks impotatant is how regularly we pulse it and he talked about every half to one second depending on the battery.
    Everybody starts to thing now in the direction of Ion flows and dead times which certainly sounds like it is where the magic lies.
    He calls that solar charger that hits the batteries with high current, the TS charger.
    So I dont know why he said we must see how much voltage we can move before the current starts to flow
  • Mark
    Hello Everyone
    I have very little to offer as help here but have an idea I'd like to share, I don't know if its even plauseable or not. The one thing I have noticed on JB's 10 coiler, his solar kick and even his original unit from 1984 is that he is hitting the charge batteries hard. I wonder if you could hit the charge batteries HARDER causing them to stay in recharge mode long enough to extract energy form them to either hit the other bank of batteries with or to run a load. His solar kick unit hits the batteries with 10 amps!
    Good luck you guys your doing awesome work!
    Mark
  • ashtweth
    Building the golden section in various cone sizes?
    EDIT SORRY GUYS WAS MEANT AS A NEW THREAD.
    SORRY ABOUT THAT
    Ash
  • Matthew Jones
    JohnStone wrote...
    The effect in the gunn diode is an anomaly in the material where the resistance does not behaves - in terms of math - monotonic. That means that the current increases more or less with the voltage like a normal diode or a zehner diode or linearly like a resistor. The anomaly of the gunn diode is a gift for fast and simple oscillators but this is not where the energy comes from - it's all in the non scalar world - just a friendly kink.
    Nobodies talking about a Gunn diode. The article I linked to shows a wave forms for different kinds of resistance. It explains the reasons for these resistance as they pertian to the Gunn Diode. The wave form is what I was refering to.
    Bedini said earlier in this thread that an MJL21194 can be switched to produce a negative resistance effect, SWITCHED!!!. He said it was like the experiment JL Naudin shows HERE. JB said it was a real effect that could be captured but that Naudin had not figure out how. Later he came off with the reason he could not tell us was do to company secret.
    So here is some facts about the effect. They are not as one would expect.
    The transistor turns on it spike positive on the scope. When it turns off it spikes negative.
    This wave form has a potential if done fast enough. An average of 82ms
    The potential cannot be measured with a meter. It must be measured with a scope set at AC.
    Diodes do not effect this potential. When the signal goes across a diode bridge the signal remains intact. It does not decline or increase.
    The signal will only decline as it enters a battery. In other words it is not measurable when entering the the charge battery.
    The potential does not effect the load.
    If this were regular energy it would not act the way this acts. So the explanation for the Gunn diode effect is nullifeid, Simply by seeing the signal remain intact through a full wave bridge rectifier. It also shows potential in a an open loop system.
    I thought I would just chime in again before the subject got changed altogether.
