  • in the Ancient Technology documentary the name of Sir William Petrie was Mentioned:
    so did a little research and found the following: STAR FIRE - The Gold of the Gods - Part 3
    goddess Hathor (to whom the whole complex was dedicated).
    All around were pillars and stelae denoting the Egyptian Kings through the ages, and certain Pharaohs such as Tuthmosis III (founder of the Rosicrucian movement in Egypt) were depicted many times on standing-stones and wall reliefs.
    The adjoining Cave of Hathor was carved into the natural rock, with flat inner walls that had been carefully smoothed. In the centre (from about 1820 BC) stood a large upright pillar of Pharaoh Amenemhet III, the son-in-law of Esau. Also portrayed were his senior chamberlain and his seal-bearer.
    Deep within the cave Petrie found a limestone designed with spirals, diagonal squares and basketwork. There were magical wands of an unidentified hard material, and in the portico were two conical stones of about six inches and nine inches, respectively, in height.
    Isis is also identified with Hathor (Ishtar) the Cow. . . . "The cow weepeth for thee with her voice."
    the Feminine Principle
    Signs and symbols -Confucius.
    • You can also try matching other coordinates given to you in the doc...sure you'll find other matches ...also notice that all 4 coordinates fall on black squares
      a fractal construct
      from the doc:
      here is some observations:
      which give you:
      • In case you have not made the connection
        Here is a quotation by Walter describing some early experiments:
        In September, 1927, I demonstrated this principle of dual polarity control by
        arranging two pairs of solenoids - one pair with more windings than the other - in
        such a manner that the dual polarity of Nature was simulated.
        -----------------an interesting obeservation
        If memory serves well when Moses broke the 10 (7 + 3 ) Commandments because
        Golden calf - Wikipedia, the free encyclopedia
        According to the Hebrew Bible, the golden calf
        Bull worship was common in many cultures.
        In our Discussion The Symbol of Bull would represent the Male Principle and its Opposite the Cow (female Principle Ishtar )
        and as mentioned previously:
        You have Spiritual Gold (Moses ;1 man ) close to Material Gold ( Tribe + Gold )
        Oh and I forgot you also have a mountain Mount Sinai
        the same applies for the Al-Aqsa Mosque - Wikipedia, the free encyclopedia
        Al-Aqsa Mosque third holiest site in Sunni Islam and is located in the Old City of Jerusalem. The site on which the silver domed mosque sits, along with the Dome of the Rock, also referred to as al-Haram ash-Sharif or "Noble Sanctuary,"[2] is the Temple Mount, the holiest site in Judaism, the place where the Temple is generally accepted to have stood. Muslims believe that Muhammad was transported from the Sacred Mosque in Mecca to al-Aqsa during the Night Journey. Islamic tradition holds that Muhammad led prayers towards this site until the seventeenth month after the emigration, when God directed him to turn towards the Ka'aba.
        Strange light over Al-Aqsa Mosque Dome of the Rock Jerusalem| Some calling this UFO - YouTube
        UFO like the cathedrals...interesting
        • found the following: STAR FIRE - The Gold of the Gods - Part 3
          The age-old tradition relates that in the secret repository of the builders had placed "instruments of iron, and arms which rust not, and glass which might be bended and yet not broken, and strange spells". But what did the first explorers find, having tunneled their way into the sealed chamber? The only furniture was a lidless, hollowed stone coffer, and it contained not a body but a layer of a mysterious powdery substance. This has been superficially determined to be grains of feldsparand mica, which are both minerals of the aluminium silicate group.
          from a previous post
          Though primarily composed of quartz and feldspars, granite also frequently contains small amounts of hornblende, micas, and other minerals. Moreover, the proportion of plagioclase to alkali feldspar may differ in granite samples, which is often utilized as the starting point for granite classifications. Alkalic, or alkali, granites, for instance, are those in which the alkali feldspar content significantly exceeds the plagioclase. These types of rocks characteristically contain pyroxenes and sodic-amphiboles. In the United States, samples of alkalic granite can be found in New England, but they also occur notably in Norway and Nigeria.
          • Excellent find occy30
            The secrets hidden in the pyramids of Egypt (Harun Yahya) - YouTube
            in it its mentioned the use of whithe limestone as insulating coating for the pyramid same properties as mica...which reminded me of the following news posted a while back:
            from http://www.energeticforum.com/renewa...-crystals.html
            Solar power without solar cells: A hidden magnetic effect of light could make it possible
            Light has electric and magnetic components. Until now, scientists thought the effects of the magnetic field were so weak that they could be ignored. What Rand and his colleagues found is that at the right intensity, when light is traveling through a material that does not conduct electricity, the light field can generate magnetic effects that are 100 million times stronger than previously expected. Under these circumstances, the magnetic effects develop strength equivalent to a strong electric effect. from the article
            this you need to remember when building your Crystal Cell
            • The researchers found a way to make said Stephen Rand, a professor in the departments of Electrical Engineering and Computer Science, Physics and Applied Physics.
              In the process, they overturned a century-old tenet of physics.
              ...applicable to you too remember...you being a crystal
              let's not forget:
              . This electric effect had previously been detected only in crystalline materials that possessed a certain symmetry.
              also: The secrets hidden in the pyramids. A real eye opener! , page 1
              • Originally posted by occy30 View Post
                Thought you guys would like this video from NASA:
                Science off the Sphere: Knitting Needle Experiment - YouTube
                If you observe the movement of the water droplets around the stick it follows a caduceus path
                now what if the stick was replaced with a cone what would the "static electricity" do:
                don't forget to add the optical battery effect
                • Originally posted by blackchisel97 View Post
                  I found this site while looking for something else - Vedic Physics
                  Vtech
                  thank you blackchisel97, very instructive
                  The Samrat Yantra, at Jaipur, designed by Jai Singh, measuring at its base 147' and 90' high calculates time within one second of accuracy every day.
                  147 = HM 3
                  90 = HM 9
                  The ninety steps of the Yantra have to do with the ninety hymns of the Rg Veda with are represented by the ninety harmonic system of measurement of Vedic physics the science of all oneness If you note the progressive triangular incline of the picture above and the steps of the Yantra and a sideways view of the chart of the 90 Vedic metrics Pictured next to it.
                  • from: http://en.wikipedia.org/wiki/Jantar_Mantar_(Jaipur)
                    The observatory consists of fourteen major geometric devices for measuring time, predicting eclipses, tracking stars' location as the earth orbits around the sun, ascertaining the declinations of planets, and determining the celestial altitudes and related ephemerides. Each is a fixed and 'focused' tool. The Samrat Yantra, the largest instrument, is 90 feet (27 m) high, its shadow carefully plotted to tell the time of day. Its face is angled at 27 degrees, the latitude of Jaipur. The Hindu chhatri (small cupola) on top is used as a platform for announcing eclipses and the arrival of monsoons.
                    27 Degrees = HM 9
                    90 feet = 27 m = HM 9
                    being a triangle with a 90 degrees angle and 27 degrees angle then the third angle is 63 degrees
                    90 degrees = 27 degrees = 63 degrees = H.M 9 (the sum of all 3 angles is equal 180 degrees = HM 9 )
                    add to it a 27 degrees latitude ...Fractal indeed
                    • a bit of info.... think principle of correspondence
                      Heat-based recording speeds hard drives | TG Daily
                      A new method of recording information to hard drives could increase their speed by hundreds of times."Instead of using a magnetic field to record information on a magnetic medium, we harnessed much stronger internal forces and recorded information using only heat," says University of York physicist Thomas Ostler.
                      "This revolutionary method allows the recording of Terabytes (thousands of Gigabytes) of information per second, hundreds of times faster than present hard drive technology. As there is no need for a magnetic field, there is also less energy consumption."
                      The discovery is all the more of a surprise given that, until now, it's always been believed that heat would simply destroy the magnetic order.
                      Modern magnetic recording technology is based on the fact that the north pole of a magnet is attracted to the south pole of another, and that two like poles repulse.
                      it's always been assumed that to do this, it's necessary to apply an xternal magnetic field.
                      The stronger the applied field, the faster the recording of a magnetic bit of information.
                      However, the new research shows that the positions of both the north and south poles of a magnet can be inverted by an ultrashort heat pulse.
                      The pulse manages this by harnessing the power of much stronger internal forces of magnetic media. In the material the team used - an alloy of gadolinium and iron - the two types of atom are magnetized in opposite directions.
                      The laser light heats the material up so fast that, at first, only the iron atoms lose their magnetization, and align theimselves with the gadolinium. When the material cools, the iron atoms reverse their magnetism again.
                      Eliminating the need for an electromagnet makes it a much more efficient technique.
                      • It is an interesting pattern when you research all the Great Men Of Science throughout history some patterns emerges as you notice their scientific interest , and search for understanding, where it has led them...the following are quotes made by one of them:
                        Paracelsus: ; I'm sure you will recognize many subjects mentioned and discussed that go along the same line of thought
                        Although Alchemy has now fallen into contempt, and is even considered a thing of the past, the physician should not be influenced by such judgments.
                        But is not He who created it for the sake of the sick body more than the remedy? And is not He who cures the soul, which is more than the body, greater?
                        Dreams are not without meaning wherever thay may come from-from fantasy, from the elements, or from other inspiration.
                        Dreams must be heeded and accepted. For a great many of them come true.
                        For it is we who must pray for our daily bread, and if He grants it to us, it is only through our labour, our skill and preparation.
                        For one country is different from another; its earth is different, as are its stones, wines, bread, meat, and everything that grows and thrives in a specific region.
                        From time immemorial artistic insights have been revealed to artists in their sleep and in dreams, so that at all times they ardently desired them.
                        However, anyone to whom this happens should not leave his room upon awakening, should speak to no-one, but remain alone and sober until everything comes back to him, and he recalls the dream.
                        If we want to make a statement about a man's nature on the basis of his physiognomy, we must take everything into account; it is in his distress that a man is tested, for then his nature is revealed.
                        Many have said of Alchemy, that it is for the making of gold and silver. For me such is not the aim, but to consider only what virtue and power may lie in medicines.
                        Medicine is not only a science; it is also an art. It does not consist of compounding pills and plasters; it deals with the very processes of life, which must be understood before they may be guided.
                        Paracelsus
                        Medicine rests upon four pillars - philosophy, astronomy, alchemy, and ethics.
                        Paracelsus
                        Nature also forges man, now a gold man, now a silver man, now a fig man, now a bean man.
                        Paracelsus
                        Often the remedy is deemed the highest good because it helps so many.
                        Paracelsus
                        Once a disease has entered the body, all parts which are healthy must fight it: not one alone, but all. Because a disease might mean their common death. Nature knows this; and Nature attacks the disease with whatever help she can muster.
                        Paracelsus
                        Poison is in everything, and no thing is without poison. The dosage makes it either a poison or a remedy.
                        Paracelsus
                        The dose makes the poison.
                        Paracelsus
                        The dreams which reveal the supernatural are promises and messages that God sends us directly: they are nothing but His angels, His ministering spirits , who usually appear to us when we are in a great predicament.
                        Paracelsus
                        The interpretation of dreams is a great art.
                        Paracelsus
                        The physician must give heed to the region in which the patient lives, that is to say, to its type and peculiarities.
                        Paracelsus
                        This is alchemy, and this is the office of Vulcan; he is the apothecary and chemist of the medicine.
                        Paracelsus
                        This process is alchemy: its founder is the smith Vulcan.
                        Paracelsus
                        Thoughts create a new heaven, a new firmament, a new source of energy, from which new arts flow.
                        Paracelsus
                        We do not know it because we are fooling away our time with outward and perishing things, and are asleep in regard to that which is real within ourself.
                        Paracelsus
                        What sense would it make or what would it benefit a physician if he discovered the origin of the diseases but could not cure or alleviate them?
                        Paracelsus
                        What the eyes perceive in herbs or stones or trees is not yet a remedy; the eyes see only the dross.
                        Paracelsus
                        use the 7 principles for deeper understanding
                          147 = HM 3
                          90 = HM 9
                          you may not have noticed it but the female and male principle are expressed in the 2 windows
                          The same Applies to the shape of an Egg
                          The South Pole of an Egg (ie the smaller tip) is smaller than the North Pole (ie: the bigger tip )
                          Red Ice Radio - Bob Frissell - Hour 1 - Transitioning Into The 4th Dimension
                          • from the same book:
                            It is noteworthy that the orbital speed of planets is in inverse proportion to
                            the square root of their distance from the Sun. Since the intensity of light
                            diminishes in inverse proportion to the square of its distance, we can add
                            further that the orbital speed of planets is in proportion to the square of the
                            square of the intensity of sunlight falling on them. Like cells, men, and
                            apparently every other living creature, their speed depends upon the stimulus
                            they receive
                            . see the previous info posted from physorg
                            THE THEORY OF CELESTIAL INFLUENCE:Man, The Universe, and the Cosmic Mysteryby: RODNEY COLLIN
                            PHILOSOPHICALLY, MAN CAN SUPPOSE AN ABSOLUTE. SUCH AN Absolute would include all possible dimensions both of time and space. That is to say:It would include not only the whole universe which man can perceive or imagine,but all other such universes which may lie beyond the power of his perception.It would include not only the present moment of all such universes, but also their past and their future, whatever past and future may mean on their scale.It would include not only everything actualised in all the past, present and future of all universes, but also everything that potentially could be actualised in them.It would include not only all possibilities for all existing universes, but also all potential universes, even though they do not exist, nor ever have.Such a conception is philosophical for us. Logically, it must be like that, but our mind is unable to come to grips with the formula or make any sense of it.
                            from: The Heart, Mind and Spirit by Professor Mohamed Omar Salem
                            Discussion
                            It has long been thought that conscious awareness originates in the brain
                            alone. Recent scientific studies suggest that consciousness emerges from the
                            brain and body acting together (Popper & Eccles, 2000). As has been shown, a
                            growing body of evidence now suggests that the heart plays a particularly
                            significant role in this process
                            . The above findings indicate that, the heart is far
                            more than a simple pump. In fact,The involvement of the heart with intuitive
                            functions is another interesting piece of information. However, as persons with
                            transplanted hearts can function normally, the heart can be considered here as a
                            medium or tool, for an underlying more sophisticated integrating system that has
                            the capacity to carry the personal identity of the individual. These new visions
                            might give better understanding to the concept of mind as a multi-component unit
                            that is not only interacting with the physical environment through demonstrable
                            means, but also has the capacity to communicate with the cosmic universe
                            through non-physical pathways (Lorimer, 2001). This gives rise to the concept of
                            the spirit as the non-physical element, or the field, of the mind that can
                            communicate with the cosmos outside the constraints of space and time. The
                            evidence for such communication comes from the reported phenomena of extra-
                            sensory perception (telepathy, precognition, and clairvoyance), psycho-kinesis,
                            psychic healing and religious experiences (Radin, 1997 & Henry, 2005).
                            Possibly further advancement in quantum physics may one day give us
                            further insight into how we can formulate this new model of the heart, mind and
                            spirit.
                            • it is getting a bit persistent as this thought keeps coming back ;alright here goes nothing:
                              next month i Turn HM 9 and She turns HM 6...........on March 15th ( her harmonic day )....
                              ps: the 15th is not my birthday....for clarification
                              The heart and intuition
                              Bob Frissell - Nothing in this Book is True - YouTube
                              • Gap Band: You dropped a bomb on me. (lyrics) - YouTube
                                You were the girl that changed my world
                                You were the girl for me
                                You lit the fuse I stand accused
                                You were the first for me
                                But you turned me out baby
                                You dropped a bomb on me, baby
                                But you turned me on baby.
                                You were my thrills, you were my pills
                                You turn me out, you turn me on, you turned me loose
                                Then you turned me wrong
                                Just like Adam and Eve.
                                Said you'd set me free, you took me to the sky
                                I'd never been so high
                                You were my pills, you were my thrills
                                You were my hope baby, you were my smoke
                                You dropped a bomb on me, hey baby
                                But you turned me out, baby
                                But you turned me on, baby
                                We were in motion, felt like lotion
                                You were the first explosion,
                                Turned out to be corrosion
                                You were the first for me.
                                I won't forget what you done to me, baby.
                                I, II, III won't forget it
                                You turned me out, you turned me on
                                And then you dropped me to the ground
                                You turned me out, then you turned me on
