  • BTW: if you keep seeing
    that is your call ( see Louis Rota ) to : ( and stop beating around the bush )
    ps: Thank you S for letting me know we are the 11th ( just remembered it )
    in the flow of synchronicity .... the act of noticing ( not obsessing ) is quite important .... it is your sub conscious ( over soul ) .... pointing it out to you ( imho )
    Signs and symbols -Confucius.
    • Words from a Wise Man :
      Thomas Henry Moray :
      a good friend of mine emailed me the following recently : ( believe it was mentioned briefly earlier in our discussion )
      Can Earthing Help Adrenal Fatigue? | Food Renegade
      For most of human history, we have spent our lives connected to the earth.. We do everything in an un-grounded state. In short, we are rarely, if ever grounded anymore.
      ps: it is good to let children run bare feet in a natural setting
      did you ever wonder why , whenever you go the beach ..... you dig your feet in the sand ( sand = silicate )
      • All is Analogy
        Periodontitis is a micro climate that reflects the macro climate of the entire body
        note : period and periodontis
        Earth on acid: The present and future of global acidification
        Climate change and extreme weather events grab the headlines, but there is another, lesser known, global change underway on land, in the seas, and in the air: acidification.
        As Above so Below, from Within so Without
        New form of brain plasticity: Research shows how social isolation disrupts myelin production
        The research sheds new light on brain plasticity, the brain's ability to adapt to environmental changes. It reveals that neurons aren't the only brain structures that undergo changes in response to an individual's environment and experience, according to one of the paper's lead authors, Karen Dietz, PhD, research scientist in the Department of Pharmacology and Toxicology in the UB School of Medicine and Biomedical Sciences.
        • Originally posted by Michael C View Post
          Thomas Moray's Swedish stone... I've been wondering about that too. He also took something from a raiway car at the same time he found his stone. What could he possibly need from a raiway car?! The only 'different' hard-to-find material to be found there, at that time and place, would be beryllium, which was used in the AGA lights inside the car for interior lumination. The AGA lights had a small glow net from cotton fibre soaked in a beryllium dilution. The cotton fibre would immediately burn away from the hot acetylene gas flame but the beryllium remained in the shape of the net and glowed from the heat. And the stone? The area where he found it isn't so very peciuliar geologically. It was in a mining district where iron, copper, led, tin and gold can be found but that's not reason enough, in case Mr Moray wouldn't create some mysticism around how his machines worked of course. My theory is that the Swedish stone is nothing but stone, a stone Sweden otherwise has some fame for, Granite. Granite is volcanic basalt mixed with water. A water-stone. It has diodical properties in relation to earth energy. Any dowser can find out how.
          Michael C,
          found the following as you mentioned Granite :
          Thomas Henry Moray: Speech at Valley State College, Northridge CA
          Through the years of research with Radiant Energy, my attention has been drawn to some of the phenomena of radio-active substances and kindred efforts of research. All our research has been in one main field, that is, rates of vibration, which has led us to many interesting experiments and accomplishments. Not the least of these has been the breeding of lighter as well as the heavier materials by the bombardment of various isotopes with high speed particles. A somewhat similar example may be had in the work being done by a different method in Breeder Reactors that produce more fuel than they consume which makes it feasible to 'burn the rocks,' that is, to utilize the vast supply of thorium ( Atomic Number: 90 ) contained, not in rich ores, but in rocks such as granite.
          see also Black Granite / pyramid
          Phillip S. CALLAHAN -- Paramagnetism & Agriculture
          Paramagnetism --
          Rediscovering nature's secret force of growth: How to farm properly as god intended
          His use of the word granite ( used in all the Ancient Structures we discussed ) implies that he not only knew that good soil is made from eroded stone but also which kind of stone was best suited to a viable agriculture.
          This word is similar to prepared granite except that the pyramid sign (Septih), for the Dog Star, is replaced by the symbol for a wing (many feathers), a much stronger levitation force than one feather . In other words black granite ( see black pyramid in Alaska http://www.energeticforum.com/psychi...tml#post207477 ) is a paramagnetic battery for the force. Every Egyptian word for different types of para-magnetic stone, eg. aner-en-rut (sandstone)
          The induced radioactivity communicated to an inactive substance may be much more intense than that of the radioactive substance from which it emanated. When, in an enclosed vessel, containing some emanation from a radioactive body (thorium for example), a metal plate charged with negative electricity at a high potential is introduced, all the particles emitted by the thorium concentrate themselves upon it and this plate becomes ten thousand times more active, surface for surface, then the thorium itself. These facts are not, any more than the preceding ones, explainable by the electric current theory.
          bismuth, plunged into a solution of bromide or radium and carefully washed immediately, remains radioactive for at least three years. This radioactivity would seem even to persist after energetic chemical treatment or metallic plating.
          Palmer Craig: Hall Effect Device (Battery, rectifier, amplifier)
          Bismuth
          Bismuth is relatively brittle for a metal. It has the interesting physical property of being less dense as a solid than it is as a liquid. The only other common substances which expand when they freeze are antimony metal and water.
          The most common bismuth minerals are bismuthinite and bismite. Generally, these and other bismuth minerals occur in minute quantities within ores of other metals, such as gold, silver, lead, zinc, and tungsten.
          Bismuth is usually an indicator of high-temperature mineral deposits, forming in veins with quartz and various metallic minerals, or at the contact of granite intrusions with other rocks such as limestone.
          bismuth is also an element used in the construction of a Moe Joe Cell: Official Website of The Moe-Joe Cell Spherical 316 Non-Magnetic Stainless Steel Joe Cell
          Q - How much hydrogen gas does the Moe-Joe cell produce?
          A - Initially, the Moe-Joe cell was not conceived as a hydrogen producer. It was created because it concentrates orgone energy, which can be used for combustion in internal combustion engines and also for healing. However, since some people have thought of using it as a HHO producer, it has shown some considerable results. (See Brett's 3000GT results on the Testimonials page)
          hope you remember that we discussed all these elements
          Limestone Quartz Magnetite and Residual Paranormal Hauntings Study by Long Island Paranormal Investigators - Ghost Haunted Demonic Investigation Ghost Hunter New York NY
          Analogy is perhaps the most powerful conceptual tool for understanding new phenomena or opening new areas of investigation
          Thomas H. MORAY
          Yull Brown : Brown's Gas vs Radioactivity
          The late former New York Assemblyman Dan Haley ( and numerous others ) witnessed a demonstration of Brown's Gas : stoichometric H-H-O from electrolyzed water. vs radioactive material in which the emissions were reduced to 0.04% within a few minutes:
          Always use caution when experimenting
          the element :
          Black Granite
          Bismuth plate
          Granite box
          HHO Flame / just the gas( Wonder if pre treated Granite with HHO flame for agriculture )
          optional :
          magnetite / aluminum / Left Chiral Quartz / limestone
          --------------------------this i did not know
          From 1936 to 1938 tests were made at various times with scores of people present of a Radiant Energy radio. This radio, on several occasions, received broadcasts direct from Little America from Admiral Byrd and his party in the Antartic. These broadcasts came in over a loud speaker clear and distinct on occasions when regular radio broadcasting stations reported that interference was so severe they could not receive Admiral Byrd's broadcasts from Little America because of weather conditions.
          Hollow Earth Theory and Admiral Byrd’s Diary
            Paramagnetism --
            Surprisingly thin and uniform films were, however, obtained by dipping mica sheets into molten bismuth and using the metallic film which adhered to the mica. If the surface of the mica be slightly roughened with hydrofluoric acid, and care be used in withdrawing the mica from the molten metal, a very thin and uniform film can be obtained by this very simple and rapid method.
            the element :
            Black Granite
            Bismuth plate
            Granite box
            optional :
            The Granite Plugs of the Great Pyramid
            Since
            Bismuth - Wikipedia, the free encyclopedia
            Bismuthine and bismuthides
            Unlike earlier members of group 15 elements such as nitrogen, phosphorus, and arsenic, and similar to the previous group 15 element antimony and has a period = 6,
            Thorium - Wikipedia, the free encyclopedia
            Element : 90
            Period : 7
            named after Thor, the Norse god of thunder
            + H H O
            • alert alert earth bound disaster imminent less than 5 weeks away. - YouTube
              interesting info about the Mayan Calendar having "an accuracy of 13 sec today" ( quoting the author of the vid )
              Mayan Numbers Symbols
              13 - Ascension. Rules all other numbers.
              ps: the newspaper 's date is 09 / 21 / 10
              All Truth is Half Truth
              Interstellar dust and the sun
              The space between stars is not empty. It contains copious but diffuse amounts of gas and dust; in fact about 5-10% of the total mass of our Milky Way galaxy is in interstellar gas. About 1% of the mass of this interstellar material, quite a lot in astronomical terms, is in the form of tiny dust grains made predominantly of silicates (sand too is made of silicates), though some grains are also composed of carbon and other elements. Dust grains are important. They block visible light while emitting infrared light
              Writing in the latest issues of the Astrophysical Journal, the scientists report on the results of their theoretical models of the behavior of interstellar dust grains as the Sun moves through space. They build on in-situ observations of the heliosphere taken when the Voyager 1 and Voyager 2 spacecraft on their outward journey encountered the edges of the heliosphere, results that constrain its size and shape. Assuming typical grains made of olivine silicates, the team finds that the small grains (less than the wavelength of ultraviolet light) stay far away from the Sun, that gravity helps the large grains collect near the Sun, but that intermediate-sized grains - about the size of the wavelength of optical light - can actually pile up in diffuse structures at the edges of the heliosphere. The new results, besides providing important new information on dust grains in the solar system, suggest that radiation from these intermediate-sized grain structures could contaminate the images of the sky used to measure the cosmic backgrounds.
              • Bismuth - Wikipedia, the free encyclopedia
                Thorium - Wikipedia, the free encyclopedia in Granite ( also present in it Quartz )
                Element : 90
                Period : 7
                + H H O
                If a metal (rendered artificially radioactive) or granite is brought to a white heat, it loses its radioactivity, which spreads itself over the bodies in its neighborhood ( the other bismut plates ) bismuth, plunged into a solution of bromide or radium and carefully washed immediately, remains radioactive for at least three years. This radioactivity would seem even to persist after energetic chemical treatment or metallic plating.
                Tesla Patent 396,121 - Thermo-Magnetic Motor
                TESLA PATENT 396,121 THERMO-MAGNETIC MOTOR.
                • two vids very amazing vids ( the second one just skip to number 13 )
                  the following one is spot on
                  10 signs of a spiritual awakening - YouTube
                  Thoth's Time Temple - Giza Alignment Code Time-Shift - YouTube
                  The Emerald Tablets of Thoth - Secret of Secrets
                  Four is it in qualities,
                  shining in each of the planes of existence,
                  but thirteen in one ,
                  the mystical number.
                  Based on the qualities of man are the Brothers:
                  each shall direct the unfoldment of being,
                  each shall channels be of the Great One.
                  • Tesla had an Amazing Mind :
                    check this out :
                    Tesla Patent 685,012 - Means for Increasing the Intensity of Electrical Oscillations
                    685 012
                    The best and most convenient manner of carrying out the invention of which I am now aware is to surround the freely-vibrating circuit or conductor, which is to be maintained at a low temperature, with a suitable cooling medium, which may be any kind of freezing mixture or agent, such as liquid air, and in order to derive the fullest benefit from the improvement the circuit should be primarily constructed so as to have the greatest possible self-induction and the smallest practicable resistance, and other rules of construction which are now recognized should be observed. For example, when in a system of transmission of energy for any purpose through the natural media the transmitting and receiving conductors are connected to earth and to an insulated terminal, respectively, the lengths of these conductors should be one-quarter of the wave length of the disturbance propagated through them.
                    Coils in the form of a flat spiral, such as those described, are eminently suited for the production of free oscillations; but obviously conductors or circuits of any other form may be used, if desired.
                    from: http://www.energeticforum.com/psychi...tml#post204771
                    I was a bit surprised to see the following
                    grenz|wissenschaft-aktuell: Astrophysiker entwickeln den fast perfekten Signalverstärker
                    google translated:
                    Pasadena (USA) - NASA scientists have developed a new type of amplifier for electrical signals. The device can be used for a variety of applications, for example, to study distant stars, galaxies and black holes but also to explore the quantum world and the development of quantum computers.
                    "This amplifier our abilities of different things being measured to redefine" the team leader Jonas Zmudzinas Jet Propulsion Laboratory (JPL) and professor explained at the California Institute of Technology (Caltech), that its development to date in the journal "Nature Physics" has described.
                    An amplifier is a GERAT that increases the strength of weak signals. This amplifier play a fundamental role in general in a variety of scientific measurements and electronics. "For many applications, the current amplifier are perfectly adequate," says Peter Day by JPL. "For a variety of scientific applications, the technologies are available, however, a significant limitation dar."
                    One of the basic features of the new amplifier is the fact that it includes superconducting materials, which allow for certain low temperature to an electric current to flow without resistance, whereby weak signals can be amplified in an ideal manner.
                    as it is an SBB Coil used in Orgone devices we have discussed way back
                    Wyniki Szukania w Grafice Google dla http://www.educate-yourself.org/dc/IM2011coils%20321.jpg
                    Tesla said that in those SHAPES is encoded key to Universe, meaning to every force in nature.
                    6 and 9 are pancake coil in opposite directions
                    3 is a center tapped coil
                    also known as SBB coils, one of my favorite coil
                    thanks boguslaw for the info, did not know that
                    How to make an SBB coil
                    and the one twisted, is i think a Mobius Sbb coil, check out this post : http://www.energeticforum.com/144488-post36.html
                    coil info
                    ------------------------------ the weird thing is that it was posted in
                    Crop Circle at Chalk Pit, nr Wootton Rivers, Wiltshire. Reported 2nd August* 2012.
                    ---------------------- btw
                    one of your favorite Apparatus made by Tesla :
                    Magnifying transmitter - Wikipedia, the free encyclopedia
                    The magnifying transmitter is an advanced version of Tesla coil transmitter. It is a high power harmonic oscillator that Nikola Tesla intended for the wireless transmission of electrical energy. In his autobiography, Tesla stated that "...I feel certain that of all my inventions, the Magnifying Transmitter will prove most important and valuable to future generations."[1] The magnifying transmitter is an air-core, multiple-resonant transformer that can generate very high voltages.
                    TESLA PATENT 1,119,732 APPARATUS FOR TRANSMITTING ELECTRICAL ENERGY.
                    Harmonic Math : 3 9 7 5 = 393 = HM 6
                    • Did you guys ever check out the dates of Patent filing
                      Tesla Patent 685,953 - Method of Intensifying and Utilizing Effects Transmitted Through Natural Media
                      Application filed June 24, 1899
                      Tesla Patent 1,119,732 - Apparatus for Transmitting Electrical Energy
                      Application filed January 18, 1902
                      Tesla Patent 685,957 - Apparatus for the Utilization of Radiant Energy
                      Application filed March 21, 1901
                      and my personal favorite :
                      Tesla Patent 1,061,142 - Fluid Propulsion
                      1,061,142. Specification of Letters Patent. Patented May 6, 1913.
                      Application filed October 21, 1909
                      Tesla Patent 1,329,559 - Valvular Conduit
                      1,329,559. Specification of Letters Patent. Patented Feb. 3, 1920.
                      Application filed February 21, 1916
                      .:: Kenneth Bager - Fragment Eight (The Sound of Swing) ::. - YouTube
                      Let me show you a Patent that has Numbers on it ..... "Master" Tesla Wrote himslef
                      I suck at complex math ..... but i know Simple Math ( ie Harmonic Math )
                      Tesla Patent 1,655,113 - Method of Aerial Transportation
                      apologies if i cut short the formulations .... you can find them in the Patent :
                      Taking, in a special case,, then
                      1/sin a = 1/0.866 = 1.1547
                      and
                      h1-h2 = 26,700xlog. 1.1547 = 3,840 feet.
                      Angle 60 deg = HM 6
                      1.1547 = 1 1 5 4 7 = 2 9 7 = 9 9 = HM 9
                      3,840 feet = 3 8 4 0 = 3 1 2 = 3 3 = HM 6
                      the force increasing as the angle diminishes up to a maximum for a = 45
                      My invention meets the present necessity in a simple manner without radical departure in construction and sacrifice of valuable features, incidentally securing advantages which should prove very beneficial in the further development of the art. Broadly expressed, it consists in a novel method of transporting bodies through the air according to which the machine is raised and lowered solely by the propeller and sustained in lateral flight by planes. To accomplish this a light and powerful prime mover is necessary and as particularly suited for the purpose I employ, preferably, a turbine of the kind described in my U. S. Patent No. 1,061,206, of May 6, 1913
                      Tesla Patent 787,412 - Art of Transmitting Electrical Energy through the Natural Mediums
                      ART OF TRANSMITTING ELECTRICAL ENERGY THROUGH THE NATURAL MEDIUM.
                      he was definitely surfing synchronicity
                      • I have no clue what it means , never mentioned it before ..... ( something about one site linking to another )
                        if you look at the bottom of the page there is a refback ( i think S , you were thinking of it when you mentioned it earlier )
                        The Brain is an Advanced Fractal Antenna - Page 10 This thread Refback 11-11-2011 05:23 PM
                        I like to think of it as a weird mystic synchronicity signature
                        • info update : ( remember epigenetics )
                          Study suggests humans are slowly but surely losing intellectual and emotional abilities
                          Human intelligence and behavior require optimal functioning of a large number of genes, which requires enormous evolutionary pressures to maintain. A provocative hypothesis published in a recent set of Science and Society pieces published in the Cell Press journal Trends in Genetics suggests that we are losing our intellectual and emotional capabilities ( Kali Yuga ) because the intricate web of genes endowing us with our brain power is particularly susceptible to mutations and that these mutations are not being selected against in our modern society.
                          -------------------- now remember you being made of water
                          Choreographing light: New algorithm controls light patterns called 'caustics', organizes them into coherent images
                          searchers at EPFL's Computer Graphics and Geometry Laboratory found a way to control "caustics", the patterns that appear when light hits a water surface or any transparent material. Thanks to an elaborate algorithm, they can shape a transparent object so that it reflects an organized and coherent image.
                          There's no magic here; the only thing at work is the relief on the plaque's surface and a natural optical phenomenon known as a "caustic," which researchers in EPFL's Computer Graphics and Geometry Laboratory have succeeded in bending to their will. Their research was presented recently at the Advances in Architectural Geometry Conference in Paris.
                          you got to love science
                          Neuroscientists suggest perception of harmonicity, not beating underlies perception of dissonance
                          the perception of harmonicity in humans is more to blame for a dislike of dissonance in musical tones than is beating.
                          For many years scientists have debated the issue of whether the dislike of dissonant tones by most people in western cultures is due to a physical phenomenon, or a simple preference for more harmonically pleasing sounds. Those arguing for the former suggest that the rattling noise that occurs when two tones are close in frequency (beating), which results in roughness in the ears, is naturally aversive and thus the answer is that it's a physical condition. Those that argue for the second point out that there are incidences in music, such as rock, where people have learned to enjoy roughness, and thus an aversion to dissonant tones is more likely the result of something in harmonies that are preferred.
                          now let these three constructs resonate together
                          Thomas H. MORAY
                          Interview with Nikola Tesla from 1899 - freedomtek.org
                          JOURNALIST: For you, science or poetry is the same?
                          TESLA: These are the two eyes of one person. William Blake was taught that the Universe was born from the imagination, that it maintains and it will exist as long as there is a last man on the Earth. With it was a wheel to which astronomers can collect the stars of all galaxies. It is the creative energy identical to the light energy.
                          Meditation produces enduring changes in emotional processing in the brain, study shows + Epigenetics
                          A new study has found that participating in an 8-week meditation training program can have measurable effects on how the brain functions even when someone is not actively meditating. In their report in the November issue of Frontiers in Human Neuroscience, investigators at Massachusetts General Hospital (MGH), Boston University (BU), and several other research centers also found differences in those effects based on the specific type of meditation practiced.
                          ps : happy solar eclipse for those who can see it
                          • was checking out Transmutation in Alchemy
                            when I recalled the following scientist
                            from: http://www.energeticforum.com/187288-post1389.html
                            Adept Alchemy (Robert A. Nelson): Transmutations of Carbon
                            George Ohsawa & Michio Kushi
                            Inspired by the pioneering work of Dr. Kervran, Dr. George Ohsawa sought to transmute sodium into potassium in vitro. The method revealed itself to him in a symbolic dream (same as Dr Vogel ) . Thus inspired, Dr. Ohsawa and Michio Kushi, et al., constructed an experimental electric discharge tube with copper (Yin) and iron (Yang) electrodes and a valve through which to draw a vacuum or admit oxygen (Fig. 3.1). The first transmutation with this equipment was achieved on June 21, 1964. After applying 60 watts of electricity for 30 minutes to heat sodium to a plasma, a molar equivalent of oxygen was introduced. Viewed with a spectroscope, the orange band of sodium gave way to the blue of potassium, according to the formula:
                            Na23 + O16 = K39
                            Analysis of the reaction product confirmed the result and revealed an unexpected extra: a trace of gold was produced by the combination of Na, O, and K with the Cu and Fe electrodes. Several different metals were tested as electrode materials. Neon and argon atmospheres were found to enhance the yield of potassium and other elements. External heating of the reaction tube also served to ionize the sodium.
                            I wonder if he used quartz containers
                            Classification Yin / Yang
                            Tendency Expansion / Contraction
                            Position Outward / Inward
                            Structure Space / Time
                            Color Purple / Red
                            Temperature Cold / Hot
                            Weight Light / Heavy
                            Catalyst Water / Fire
                            Atomic Electron / Proton
                            Elements K, O, P, Ca, N / H, As, Cl, Na, C
                            "Within the first octave, the greatest attraction is between carbon and oxygen, which represent Yin and Yang respectively. It is the fugate interaction of these two that form the other elements. Carbon is often replaced by boron. In terms of Yin and Yang, these are like brothers in that they react in similar ways in forming new elements."
                            Since George Ohsawa and Michio Kushi conducted their initial experiments in the 1970s, several other researchers have reported the same results and more, thanks to modern analytical equipment, computers, and communication.
                            • ps: for fun
                              Home Page
                              for old time sake ...... a little 3 6 9 play on an Alchemical treaty
                              The Six Keys of Eudoxus (Alchemy)
                              The First Key
                              3. This Stone has a bright glittering: it contains a Spirit of a sublime original; it is the Sea of the Wise, in which they angle for their mysterious Fish.
                              6. Hence, Hermes says, What is born of the Crow is the beginning of this Art. Consider that it is by separation of the black, foul, and stinking fume of the Blackest Black that our astral, white, and resplendent Stone is formed, which contains in its veins the blood of the Pelican. It is at this First Purification of the Stone, and at this shining whiteness, that the work of the First Key is ended.
                              The Second Key
                              3. Without the sublimation of the Stone, the conversion of the Elements and the extraction of the Principles is impossible; and this conversion, which makes Water of Earth, Air of Water, and Fire of Air, is the only way whereby our Mercury can be prepared.
                              The Third Key
                              3. This is the Intention, and the essential point of the Operations of this Key, which terminate at the generation of a new substance infinitely nobler than the First.
                              6. This advice opens the eyes of those, who, to make an exact purification of the Elements and of the Principles, persuade themselves that they must only take the subtile and cast away the heavy. But Hermes says that power of it is not integral until it be turned into earth; neither ought the sons of science to be ignorant that the Fire and the Sulphur are hidden in the centre of the Earth, and that they must wash it exactly with its spirit, to extract out of it the Fixed Salt, which is the Blood of our Stone. This is the essential Mystery of the operation, which is not accomplished till after a convenient digestion and a slow distillation.
                              12. It is therefore necessary to dissolve the body entirely to extract all its humidity which contains the precious ferment, the sulphur, that balm of Nature, and wonderful unguent, without which you ought not to hope ever to see in your vessel this blackness so desired by all the philosophers. Reduce then the whole compound into water, and make a perfect union of the volatile with the fixed; it is a precept of Senior's, which deserves attention, that the highest fume should be reduced to the lowest; for the divine water is the thing descending from heaven, the reducer of the soul to its body, which it at length revives.
                              15. The second is the compound of Art; it is the Wise man who makes it by the secret union of the fixed with the volatile, perfectly conjoined with all prudence, which cannot be acquired but by the lights of a profound philosophy.
                              18. The water which ascends by distillation carries up with it a part of this fiery salt, so that the affusion of the water on the body, reiterated many times, impregnates, fattens, and fertilizes our Mercury, and makes it fit to be fixed, which is the end of the second Work.
                              21. Others have taught that the White Mercury is the bath of the Moon, and that the Red Mercury is the bath of the Sun. But there are none who have been willing to show distinctly to the Sons of Science by what means they may get these two mercuries. If you apprehend me well, you have the point already cleared up to you.
                              24. Behold a great Mystery which I reveal to you without an enigma; this is the secret of the two mercuries which contain the two tinctures. Keep them separately, and do not confound their species, for fear they should beget a monstrous Lineage.
                              27. Hermes says, that there is so much sympathy between the purified bodies and the spirits, that they never quit one another when they are united together: because this union resembles that of the soul with the glorified body; after which Faith tells us, there shall be no more separation or death; because the spirits desire to be in the cleansed bodies, and having them, they enliven and dwell in them.
                              ...... continued
                              • The Fourth Key ( 13 )
                                The Fourth Key of the Art is the entrance to the Second Work (and a reiteration in part and development of the foregoing): it is this which reduces our Water into Earth; there is but this only Water in the world, which by a bare boiling can be converted into Earth, because the Mercury of the Wise carries in its centre its own Sulphur, which coagulates it. The terrification of the Spirit is the only operation of this work. Boil them with patience; if you have proceeded well, you will not be a long time without perceiving the marks of this coagulation; and if they appear not in their time, they will never appear; because it is an undoubted sign that you have failed in some essential thing in the former operations; for to corporify the Spirit, which is our Mercury, you must have well dissolved the body in which the Sulphur which coagulates the Mercury is enclosed. But Hermes assumes that our mercurial water shall obtain all the virtues which the philosophers attribute to it if it be turned into earth. An earth admirable is it for fertility -- the Land of Promise of the Wise, who, knowing how to make the dew of Heaven fall upon it, cause it to produce fruits of an inestimable price. Cultivate then diligently this precious earth, moisten it often with its own humidity, dry it as often, and you will no less augment its virtue than its weight and its fertility.
                                ps 4 + 2 = 6
                                continued
