  • quiz Time What is the Name of The Highway known for UFO's :ie Extraterrestrial Highway :
    Highway 3 7 5
    ooops forgot ......... Area 51
    Signs and symbols -Confucius.
    • the cycle of time has some interesting effects on us humans when you look at it closely:
      What is puberty?
      Puberty is the time in life when a young person starts to become sexually mature.
      In girls, puberty usually starts around 11 years of age, but it may start as early as 6 or 7 years of age. In boys, puberty begins around 12 years as age, but may start as early as 9 years of age. Puberty is a process that goes on for several years. Most girls are physically mature by about 14 years of age. Boys mature at about 15 or 16.
      let's resonate it with :
      • talking about Left / Female Pole
        Something you should know .... is that most of the elements ( amino acid / dna / rna etc.... ) has left Chiral
        Untitled Document
        Additionally, because of the geometry of the way carbon works as the backbone of organic molecules, it is possible to create molecules that are right- or left-handed. This ability is called chirality. It should be noted that not all organic molecules are chiral: some can be symmetrical. The chiral molecule, however, has properties that are crucial to the working of the chemistry of life. As far as life on Earth is concerned, all normal chiral molecules associated with life processes are left-handed.
        In terms of basic chemistry, left- and right- chiral molecules are identical, but their behavior can be vastly different. This is because the chemistry of life depends on the ability of molecules to form atomic bonds at several points simultaneously, to create new compounds. The molecules, however, are three-dimensional structures and to make the bonds work they must be turned round and fitted, much as a jigsaw puzzle would be put together. The consequence is that molecules must be the correct shape, in order to form the required bonding, as well as being chemically correct.
        Players of the computer jigsaw puzzle game, Tetris, will appreciate the problem. Some pieces are handed - they are chiral - and however they are turned around and manipulated, they will not fit into the available slots. In fact Tetris would soon become incredibly and boringly easy, if the chiral pieces were not present.
        So, in terms of bio-chemistry, you can see that it is impossible for the "wrong-handed" molecule to be used in a particular process, even if it is chemically correct. This characteristic of some organic molecules is key in the processes of life, particularly in replication, such as in the behavior of DNA.
        Let us now return to the humble carbon atom and think about its role when considering life elsewhere, off planet Earth. The unique characteristics of carbon give it a versatility and functionality like no other atom in the periodic table. These are why carbon is the basis of life here. Additionally, carbon is only beaten in abundance by hydrogen, helium and oxygen, at least within the Solar System. It is ten times more abundant than silicon and a million times more abundant than boron, which have also been suggested as alternative base elements for living molecules.
        • a re post: http://www.energeticforum.com/psychi...ntenna-10.html
          alpha_and_beta quartz
          both alpha quartz and dna are coaxial helices
          structured water :from http://www.energeticforum.com/renewa...tml#post166832
          For example sound in water medium would need to be at 72.36Hz to achieve the same wavelength as radiowaves at 13.56MHz.
          It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
          Luc MONTAGNIER DNA Teleportation
          A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
          According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
          Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
          note: looks to me that a zone of activation was created then the dna transfer was accomplished
          and also the weak electromagnetic field of 7Hz used is actually close to Schumann resonances:
          let's not forget the use of quartz test tube (maybe )
          The Schumann resonances (SR) are a set of spectrum peaks in the extremely low frequency (ELF) portion of the Earth's electromagnetic field spectrum. Schumann resonances are global electromagnetic resonances, excited by lightning discharges in the cavity formed by the Earth's surface and the ionosphere....
          ....as distinct peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8, 27.3 and 33.8 Hz.
          The dark end of the street COMMITMENTS - YouTube
          Dark End of the Street Lyrics
          [ from The Commitments Soundtrack ]
          At the dark end of the street
          that is where we always meet
          hiding in shadows where we don't belong
          living in darkness, to hide alone
          You and me, at the dark end of the street
          You and me
          I know a time has gonna take it's toll
          we have to pay for the love we stole
          It's a sin and we know it's wrong
          Oh, our love keeps going on strong
          Steal away to the dark end of the street
          You and me
          They gonna find us, they gonna find us
          They gonna find us love someday
          You and me
          When the daylight all goes around
          And by chance we're both down the town
          Please meet, just walk, walk on by
          Oh, darling, please don't you cry
          You and me
          The Commitments Lyrics
          " Treat Her Right "
          I wanna tell you a story
          (Background repeat)
          Every man oughta know
          (Background repeat)
          If you want a little loving
          (Background repeat)
          You gotta start real slow
          (Background repeat)
          She's gonna love you tonight now
          (Background repeat)
          If you just treat her right
          (Background repeat)
          Oh squeeze her real gentle
          (Background repeat)
          Gotta make her feel good
          (Background repeat)
          Tell her that you love her
          (Background repeat)
          Like you know you should
          (Background repeat)
          And she'll be glad every night
          (Background repeat)
          That you treated her right
          (Background repeat)
          If you practice my method
          (Background repeat)
          Just as hard as you can
          (Background repeat)
          Your gonna get a reputation
          (Background repeat)
          As a lovin' man
          (Background repeat)
          And you'll be glad every night
          (Background repeat)
          (Background repeat)
          HEY HEY HEY HEY! (X12)
          (Background repeats main verse with lead calling back) Yeah I wanna tell you a little story
          Yeah start real slow
          I know she's gonna love me
          Ooooo yeah
          Real gentle, real gentle
          She knows I love her
          I know I should
          (Join in with Background)
          She'll be glad every night
          That you treated her right.
          Rodrigo y Gabriela - Diablo Rojo (HQ) - YouTube
          las estrellas y la luna ellas me dicen donde voy
          Cozy Cole - Topsy Pt.2 - YouTube
          shock the Monkey
          • Now Fellow Monkeys
            Let us have a look at Sun Wukong - Wikipedia, the free encyclopedia
            Sun Wukonghe Monkey King is a main character in the classical Chinese epic novel Journey to the West
            more later
            ps: the sun rises in the East
            Sun Wukong possesses an immense amount of strength; he is able to lift his 13,500 jīn (8,100 kg or 17,881 lbs) staff with ease. He is also superbly fast, able to travel 108,000 li (54,000 kilometers or 33,554 mi) in one somersault. Sun knows 72 transformations, which allows him to transform into various animals and objects; he has trouble, however, transforming into other people, because he is unable to complete the transformation of his tail. He is a skilled fighter, capable of holding his own against the best generals of heaven. Each of his hairs possesses magical properties, and is capable of transforming either into a clone of the Monkey King himself, or various weapons, animals, and other objects. He also knows spells that can command wind, part water, conjure protective circles against demons, and freeze humans, demons, and gods alike.[
            Forest Gump_ Duane Eddy - Rebel Rouser - YouTube
            Preston Epps - Bongo rock - YouTube
            and please don't be this kind of Monkey ( for mature audience only )
            Chimp Rapes a Frog - YouTube
            always makes me laugh ................ sorry ..... it's nature
            if any one of you is of the female gender .... just picture the head of a Male that rubbed you the wrong way on the Monkey .... you'll have a good Laugh
            add this music to it and it is a blast
            OUT OF LIMITS - THE MARKETTS - (ORIGINAL VERSION) 1962 - YouTube
            • Let us Monkey around a bit more:
              Three wise monkeys - Wikipedia, the free encyclopedia
              The three wise monkeys (Japanese: 三猿, san'en or sanzaru, or 三匹の猿, sanbiki no saru, literally "three monkeys"), sometimes called the three mystic apes,[1] are a pictorial maxim. Together they embody the proverbial principle to "see no evil, hear no evil, speak no evil". The three monkeys are Mizaru, covering his eyes, who sees no evil; Kikazaru, covering his ears, who hears no evil; and Iwazaru, covering his mouth, who speaks no evil. Sometimes there is a fourth monkey depicted with the three others; the last one, Shizaru, symbolizes the principle of "do no evil". He may be shown crossing his arms.
              There are various meanings ascribed to the monkeys and the proverb including associations with being of good mind, speech and action. In the Western world the phrase is often used to refer to those who deal with impropriety by looking the other way, refusing to acknowledge it, or feigning ignorance.[citation needed]
              In English, the monkeys' names are often given as Mizaru,[2] Mikazaru,[3] and Mazaru,[4] but the last two names were corrupted from the Japanese originals.[5][6]
              enjoy the following ..... feel the Vibe
              Booker T & the M G 's - Green Onions (Original / HQ audio) - YouTube
              • here is a surprising find
                Crop Circles los eventos del 2012 - YouTube
                • Last edited by Michael C; 05-21-2012, 12:04 PM.
                  • Originally posted by Michael C View Post
                    nice find Michael C .............. 9 rocks * 2 .............any more info ............. gps ......... area
                    would be much appreciated
                    • I believe it would be 57.775072,14.837186 according to Google maps.
                      It's called a 'domarring' ('Judge's circle') because later generations didn't know what it was and thought it might be some sort of juridical court place. It's a bronze age earth energy generator or magnifier working at the same principals as Stonehenge et cetera, sending a beam of energy out from between stone '4 and 5' if compared to the 9-pointed star.
                      When I, this time, saw your pictures of the 9-pointed star I recognized the diagram of the 9 stone circle and how it works.
                      The place is called Bride's grove outside Flisby, Sweden. Those stone circles and similar grave hills and other stone constructions are still numerous and widely spread. I just googled the word 'domarring' and found this picture on wikipedia.
                      Fileomarring Bruadungen.jpg - Wikimedia Commons
                      It's quite similar to a side projection to an eye really, a beam coming from the retina and passing out through the pupil. The stones in the circle has different potential in popular terms of '+ and -' , which can be detected from the energy vortex surrounding each stone and connecting stones with same potential. Where two stones next to each other has the same potential, there's the pupil. The neutral focal point stone, perhaps the one seen just outside the circle in the back, collects, focuses and 'shoots' the energy beam through the pupil. But the stone's in the circle can serve as focal points too. Then there's two beams leaving the circle, one + and one -.
                      • let us then put them together to resonate
                        now we could suppose the enneagram is this old
                        thank you for this tremendous contribution Michael C
                        http://en.wikipedia.org/wiki/Stone_circle_(Iron_Age)
                        The circles are usually round, or elongated ellipses. The stones may be very large and they are usually between 9 and 12 24 stones. Excavations have shown burnt coal in the centre of the circles and they are nowadays considered to be incineration graves.
                          let's imagine the stones as catalyser for astral body projection ... if you have the correct stones linked then a different vibe is created which may project you somewhere else .... sun and stars position also may play a role
                          Stargate SG-1 for the Bronze Age
                          ps: the light out of the pupils .... you should be able to direct it to your third eye
                          • which leads me to think that the burial idea came afterward as the knowledge got lost .... or some never came back from their astral travel ..... thinking out loud ....
                            • 'Not to be confused with bronze age and Stonehenge' says the quotes, well I'm not so sure, not regarding their function at least. Of course the arcaeologists doesn't recognize anything but cult symbolism but there are forces to discover too. Graves were (and are) positioned in those beams from stone circles and 'ships' (elliptical stone rings) and it's possible to detect a vortex from the top of the grave like in this classic photo:
                              Normally the vortex are directed from the top to the grave, but the grave energy can be 'opened' very easily. The fact being it a grave doesn't seem to be in any particular meaning for the energy fields, the grave is a battery with different cells/layers and someone once thought it would be nice to put his/her auntie or uncle to rest in this energy field I suppose. These constructions are as intriguing as the Giza pyramids, and I believe they use much the same energies although in different development levels.
                              The coal layer are part of an insulating layer, making it possible to equally energize the ground area within the circle.
                                'Not to be confused with bronze age and Stonehenge' says the quotes, well I'm not so sure, not regarding their function at least. Of course the archaeologists doesn't recognize anything but cult symbolism but there are forces to discover too. Graves were (and are) positioned in those beams from stone circles and 'ships' (elliptical stone rings) and it's possible to detect a vortex from the top of the grave like in this classic photo:
                                can't blame them for their focus on physical proof when the forces we are dealing with are ethereal .... but unfortunate for them because a new field would open before their eyes if they only merged both science and spiritual
                                The Alpha and the Omega
