  • MonsieurM
    You and Quartz are so similar
    An Error Occurred Setting Your User Cookie
    Triboelectric effect - Wikipedia, the free encyclopedia
    The triboelectric effect (also known as triboelectric charging) is a type of contact electrification in which certain materials become electrically charged after they come into contact with another different material through friction.( KAMASUTRA ) Rubbing glass with fur, or a comb through the hair, can build up triboelectricity. Most everyday static electricity is triboelectric. The polarity and strength of the charges produced differ according to the materials, surface roughness, temperature, strain, and other properties.
    Thus, it is not very predictable, and only broad generalizations can be made. Amber, for example, can acquire an electric charge by contact and separation (or friction) with a material like wool. This property, first recorded by Thales of Miletus, suggested the word "electricity" (from William Gilbert's initial coinage, "electra"), from the Greek word for amber, ēlektron. Other examples of materials that can acquire a significant charge when rubbed together include glass rubbed with silk, and hard rubber rubbed with fur.
    see electro therapy and Tesla / Dr Vogel And all the infos posted in this thread on Quartz ( a lot ) )
  • MonsieurM
    Body capacitance - Wikipedia, the free encyclopedia
    Body capacitance is a physical property of the human body that makes it act as a capacitor. Like any other electrically-conductive object, a human body can store electric charge if insulated. The actual amount of capacitance varies with the surroundings; it would be low when standing on top of a pole with nothing nearby, but high when leaning against an insulated, but grounded large metal surface, such as a household refrigerator, or a metal wall in a factory.
    Synthetic fabrics and friction can charge a human body to about 3 kV. Low potentials may not have any notable effect, but some electronic devices can be damaged by modest voltages of 100 volts. Electronics factories are very careful to prevent people from becoming charged up. A whole branch of the electronics industry deals with preventing static charge build-up and protecting products against electrostatic discharge.
    Notably, a combination of footwear with some sole materials, low humidity, and a dry carpet (synthetic fiber in particular) can cause footsteps to charge a person's body capacitance to as much as a few tens of kilovolts with respect to the earth. The human and surroundings then constitute a highly-charged capacitor. A close approach to any conductive object connected to earth (ground) can create a shock, even a visible spark.
    Body capacitance was a significant nuisance when tuning the earliest radios; touching a tuning knob would couple the body capacitance into the tuning circuit, slightly changing its resonant frequency. However, body capacitance is very useful in the Theremin, a musical instrument in which it causes slight frequency shifts of the instrument's internal oscillators. One of them changes pitch, and the other causes loudness (volume) to change smoothly between silence and full amount.
    Capacitance of a human body in normal surroundings is typically in the tens to low hundreds of picofarads. That's small, by typical electronic standards. While humans are much larger than typical electronic components, they are also mostly separated by significant distance from other conductive objects. Although the occasional static shock can be startling and even unpleasant, the amount of stored energy is relatively low, and won't harm a healthy person. The Human Body Model for capacitance, as defined by the Electrostatic Discharge Association (ESDA) is a 100pF capacitor in series with a 1.5kΩ resistor[1]
    "On the Dissipation of the Electrical Energy of the Hertz Resonator"
    These waves are propagated at right angles from the charged surfaces when their charges are alternated, and dissipation occurs, even if the surfaces are covered with thick and excellent insulation.
    When a glass plate is placed near a condenser the charge of which is alternated, the plate emits a sound. This sound is due to the rhythmical impact of the air against the plate. I have also found that the ringing of a condenser, first noted by Sir William Thomson, is due to the presence of the air between or near the charged surfaces.
    Taking the above views, I believe, that in the experiments of Prof. Bjerknes which lead him to undoubtedly correct conclusions, the air is a factor fully as important, if not more so, than the resistance of the metals.
    Thomas Henry Moray: Speech at Valley State College, Northridge CA
    All energies of the plasma of the Universe have resilient rigidity and density, which is subject to displacement and strain. When a resilient substance is subject to strain and then set free, one of two things will happen, The substance will slowly recover from the strain and gradually obtain its natural state or the elastic recoil will carry it past its position of equilibrium and cause it to execute a series of oscillations. Something of the same sort will also occur when an electrified capacitor is discharged through special high frequency valves.
  • MonsieurM
    the interesting observation is the use of the expression : OM G when your hair stands up
    just realized something ... linkage time
    Why does your hair stand on end when it is full of static electricity
    Your hair has picked up extra electrons. This causes your hair to repel against each other(Like charges repel remember!). Because you hair is so tightly packed, the furthest any hair can get from another hair is to stand straight up.
    a few word from Mr Tesla on this :
    "High Frequency Oscillators for Electro-therapeutic and Other Purposes" by Nikola Tesla
    November 17, 1898
    One of the early observed and remarkable features of the high frequency currents, and one which was chiefly of interest to the physician, was their apparent harmlessness which made it possible to pass relatively great amounts of electrical energy through the body of a person without causing pain or serious discomfort. This peculiarity which, together with other mostly unlooked-for properties of these currents I had the honor to bring to the attention of scientific men first in an article in a technical journal in February, 1891, and in subsequent contributions to scientific societies, made it at once evident that these currents would lend themselves particularly to electro-therapeutic uses.
    With regard to the electrical actions in general, and by analogy, it was reasonable to infer that the physiological effects, however complex, might be resolved in three classes.[B][I] First the statical, that is, such as are chiefly dependent on the magnitude of electrical potential ; second, the dynamical, that is, those principally dependent on the quality of electrical movement or current's strength through the body, and third, effects of a distinct nature due to electrical waves or oscillations, that is, impulses in which the electrical energy is alternately passing in more or less rapid succession through the static and dynamic forms.
    A Pulse ..... similar to the way you perceive the world or the way a Woman gives Birth ( think breathing / contractions )
    OM EGA
    Two very Feminine Designs
    EGA IS ALSO LINKED TO EGO WHICH IS LINKED TO NOS
    ego - Wiktionary
    OU RA NOS
    Esperanto
    [edit]
    Etymology
    ega - Wiktionary
    -eg- +‎ -a
    [edit]
    Adjective
    ega (plural egaj, accusative singular egan, accusative plural egajn)
    great
    ega
    neither
    [edit]
    Ladin
    [edit]
    Alternative forms
    aga (Brach)
    [edit]
    Noun
  • MonsieurM
    good to read you
    excellent image you found :
    as for the tree image ..... much can be seen like clouds in the sky
    The Emerald Tablets of Thoth Tablet
    All eyes do not see with the same vision,
    for to one an object appears of
    one form and color
    and to a different eye of another.
    So also the infinite fire,
    changing from color to color,
    is never the same from day to day.
  • Michael C
    Chinese Farmer Discovers a Knotty Vegetable Man
  • Michael C
    His use of the word granite ( used in all the Ancient Structures we discussed ) implies that he not only knew that good soil is made from eroded stone but also which kind of stone was best suited to a viable agriculture.
    I recently read about a man who had a big garden (open for visitors) and had given 'source' a thought. Wherefrom did the soil come? In this region, from the inland ice that grinded the granite rock to dust. So he thought that instead of buying fertilizer, plant school soil mixes etc, he bought rock, like stone meal and macadam, and mixed it with compost. Because that was the origin of the natural soil here, and that was what to maintain. The stone material were bought from a local quarry, sometimes he was simply given the stone because he asked for so relatively small quantities.
    And from then, his beautiful garden grew like never before.
    I have been worried about modern chemical agriculture and the impoverishment of the soil, but now I see that the effects are easily reversed. If I had a farm, I wish I had one, then I would spread macadam on my acres and then plow it down with the straw. Quite the opposite to what is usually done. If my neighbours didn't pick up the rocks from my acre and threw them at me, as I suppose there's a small risc that they would, then I'd expect the finest harvest of all times next season
    Nature is a wonderful place, delightful and pleasant to communicate with.
    Excuse the poor quality of the pictures, I had no tripod or anything to support the camera.
    Can you see the face of the tree spirit? The spirit want's us to know it's there and just as real as what else we might imagine.
  • MonsieurM
    A Fascinating Read
    "When Woman is Boss"
    WHEN WOMAN IS BOSS
    An interview with Nikola Tesla by John B. Kennedy
    Colliers, January 30, 1926
    The life of the bee will be the life of our race, says Nikola Tesla, world-famed scientist.
    A NEW sex order is coming--with the female as superior. You will communicate instantly by simple vest-pocket equipment. Aircraft will travel the skies, unmanned, driven and guided by radio. Enormous power will be transmitted great distances without wires. Earthquakes will become more and more frequent. Temperate zones will turn frigid or torrid. And some of these awe-inspiring developments, says Tesla, are not so very far off.
    The Queen is the Center of Life
    "BUT the female mind has demonstrated a capacity for all the mental acquirements and achievements of men, and as generations ensue that capacity will be expanded; the average woman will be as well educated as the average man, and then better educated, for the dormant faculties of her brain will be stimulated to an activity that will be all the more intense and powerful because of centuries of repose. Woman will ignore precedent and startle civilization with their progress.
    "The acquisition of new fields of endeavor by women, their gradual usurpation of leadership, will dull and finally dissipate feminine sensibilities, will choke the maternal instinct, so that marriage and motherhood may become abhorrent and human civilization draw closer and closer to the perfect civilization of the bee."
    The significance of this lies in the principle dominating the economy of the bee--the most highly organized and intelligently coordinated system of any form of nonrational animal life--the all-governing supremacy of the instinct for immortality which makes divinity out of motherhood.
    The center of all bee life is the queen. She dominates the hive, not through hereditary right, for any egg may be hatched into a reigning queen, but because she is the womb of this insect race.
    ps: (don't necessarily agree with all that he wrote ..... All Truth is Half Truth )
    "How Cosmic Forces Shape Our Destinies" by Nikola Tesla
    HOW COSMIC FORCES SHAPE OUR DESTINIES
    ("Did the War Cause the Italian Earthquake")
    by Nikola Tesla
    Every living being is an engine geared to the wheelwork of the universe
    3. It is not true, as Descartes taught, that the brain is an accumulator. There is no permanent record in the brain, there is no stored knowledge. Knowledge is something akin to an echo that needs a disturbance to be called into being.
  • MonsieurM
    a few linkage 13
    How to say mother in arabic? - Yahoo! Answers
    there are any form
    mama ماما
    mema ميما
    omi
    OM EGA
    Scripture
    The Revelation of St John the Divine Chapter 1:8
    I am Alpha and Omega, the beginning and the ending, saith the Lord, which is, and which was, and which is to come, the Almighty.
    Why Do Men Have Nipples? | LifesLittleMysteries.com
    Brace yourselves for a low blow, tough guy. Nipples remind us that gender is anything but clear-cut, especially in utero. Whatever your sex, everyone starts off as a woman in the womb ( OMEGA ) .
    For the first several weeks a developing embryo follows a "female blueprint," from reproductive organs to nipples. Only after about 60 days does the hormone testosterone ( ALPHA ) kick in (for those of us with a Y chromosome), changing the genetic activity of cells in the genitals and brain. But by then those mammary papillae aren't going anywhere.
    The Eagles-Journey of the Sorcerer ( Long Version) - YouTube
    Anita Ward - Ring my bell Lyrics (Requested) - YouTube
    Tibetan singing bowls - YouTube
    O rgas M
    Om - Wikipedia, the free encyclopedia
    The Modern Expression OMG let's play with it
    O r G as M
    Oh My God
    OM Gum
    Om Gam Ganapataye Namaha - YouTube also called Remover of Obstacles .... go with the flow ( 108 repetitions )
  • MonsieurM
    . while the
    If you want to live your soul,
    find a friend like Shams and stay near.
    Rumi
    ps: at the top of the sephirot is a word : AIN
    it also means SOURCE a word used to describe a spring in arabic
    ain - Wiktionary
    Adverb
    ain
    always
    still
    [edit]
    Malay
    ain
    [edit]
    Etymology
    From Arabic عين (ʕayn), from Proto-Semitic *ʿayn-, from Proto-Afro-Asiatic *ʿayVn-.
    [edit]
    Alternative forms
    عين
    [edit]
    Pronunciation
    (Johor-Selangor) IPA: /aen/
    (Riau-Lingga) IPA: /aɪn/
    Rhymes: -aen, -en
    [edit]
    Noun
    ain (Jawi spelling عين)
    (anatomy) eye (organ)
    [edit]
    Synonyms
    (organ): mata / مات
    [edit]
    Manx
    [edit]
    Pronoun
    ain
    1st person plural of ec
    at us
    (idiomatically) our
    [edit]
    Northern Sami
    [edit]
    Adverb
    ain
    still
    [edit]
    Scots
    [edit]
    Alternative forms
    ayn
    awn (obsolete), awin (obsolete)
    [edit]
    Etymology
    From Middle English aȝen, from Old English āgen, ǣġen (ownain
    Belonging to, or on behalf of, a specified person (especially oneself); own.
    see also : NOS
    Example: Ma ain dear sister
    ps: mirror image of NOS is SON ......SON OF RA
    NOS / SUN / SON
    NOS : ROOTS
    SON : BRANCHES
    TREE OF KNOWLEDGE
    SUN DISK ( mandala ) OF RA
    Tree of Life
  • MonsieurM
    OURANOS has a more majestic intonation to it
    Is the "nos" in "nostalgia" of the same origin as the "nos" in "nosotros"? - spanish etymology nosotros | Ask MetaFilter
    I wasn't sure about the "nos" part. The OED says it comes from the ancient Greek "nostos":
    "ancient Greek νόστος return home, in Hellenistic Greek as plural Νόστοι also the title of a lost poem of the Epic Cycle dealing with the return of the Greeks from the Trojan War < an ablaut variant of the base of νεῖσθαι to return home (cognate with Sanskrit nas- to consort together, astam home, Old English nesan to escape, be saved, survive, Gothic -nisan (in ganisan to be saved, healed), and perhaps Tocharian B nes- to be) + -τος, suffix forming nouns."
    The Sanskrit "nas" ("to consort together") sounds like it could be related to "nosotros," but I'm not sure about the primary Greek origin they mention here.
    OU RA NOS
    OU : Etymology
    From Latin ovum. Compare Daco-Romanian ou.
    [edit]
    Noun
    ou
    egg
    RA : Ra 1] or Re was the ancient Egyptian solar deity
    NOS : AARK
    From: http://www.energeticforum.com/renewa...netism-21.html
    Yin and Yang in Chinese Mythology
    The Pangu* legend
    In the beginning ( NOS ) there was nothing in the universe except a formless chaos. The chaos began to coalesce into a cosmic egg for eighteen thousand years. Within it, the perfectly opposed principles of yin and yang became balanced and Pangu ( RA ), emerged from the egg ( OU ).
    Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature (fractal nature), for in it there is a spirituality and conjunction of elements, and an earth ( clay ) which is golden ( homo luminous ) in its tincture. Hermes Trismegistus
    NOS / SUN / SON
    NOS : ROOTS
    SON : BRANCHES
    TREE OF KNOWLEDGE
  • MonsieurM
    from: http://www.energeticforum.com/psychi...tml#post214590
    Originally posted by Danny B View Post
    There is currently a lot of research using a caduceus coil to treat seeds for better germination. I suspect that the clarifier generates the same scalar beam.
    Using magnetic energy to treat seeds goes back probably 12,000 years. There is an excellent book on the subject.
    "Seed of Knowledge, Stone of Plenty" by John Burke
    I have no idea in what aspect matter is "deficient". So, I don't know what "quality" of matter is affected/improved by the Bedini clarifier. There are hints that this device can be used to do a very special "treatment" of matter to get some exciting results. I have NO idea what they might be.
    Reportedly, one can also use electricity to completely change the genetic code. It's a fascinating possibility.
    English - urzeitcode.com
    thank you for the info Danny B
    see also :
    http://www.energeticforum.com/agricu...o-culture.html
    A recent book, Seed of Knowledge, The authors show that these structures were overwhelmingly sited at locations where the local geology magnified naturally-occurring electromagnetic fluctuations in the earth's crust and, further, that pyramidal and corbel- roofed stone structures erected at these locations enhanced this effect.
    from: http://www.energeticforum.com/214187-post3503.html
    Limestone Quartz Magnetite and Residual Paranormal Hauntings Study by Long Island Paranormal Investigators - Ghost Haunted Demonic Investigation Ghost Hunter New York NY
    Phillip S. CALLAHAN -- Paramagnetism & Agriculture
    Paramagnetism --
    Rediscovering nature's secret force of growth: How to farm properly as god intended
    This word is similar to prepared granite except that the pyramid sign (Septih), for the Dog Star, is replaced by the symbol for a wing (many feathers), a much stronger levitation force than one feather . In other words black granite ( see black pyramid in Alaska http://www.energeticforum.com/psychi...tml#post207477 ) is a paramagnetic battery for the force. Every Egyptian word for different types of para-magnetic stone, eg. aner-en-rut (sandstone)
    The findings add to a growing body of research suggesting that sound meant more to our ancestors than archaeologists once realized. We live in a sound-saturated society, full of iPods, thunderous special effects in movies, and thousand-watt car stereos. New discoveries in the young field of acoustic archaeology hint that just as we create elaborate sonic environments with our electronics, the ancients may have sculpted their soundscapes as well. Like many artistic endeavors, their efforts may have been rooted in an attempt to reach the divine.
    A Fractal Resonance
    Santos Bonacci - Truth Frequency Radio - 11-03-12 - Syncretism & Our Binary Star - YouTube
  • MonsieurM
    you know .... now that we are familiar with Some Symbols and their various ( fractal ) Meanings .... you won't have too much difficulties recognizing / interpreting the following :
    note the 4 pillars at the top of the painting
    Maṇḍala (मण्डल) is a Sanskrit word meaning "circle."
    The Ayahuasca Vision Paintings of Pablo Amaringo | Alternative
    HC: Pablo was drinking Ayahuasca for many yearsexpressed allegorically or in mythological terms.
    My Mandala ( I just resonate strongly to it )
    it's called Jarilo God of Spring ( have been using it for so long without knowing its name )
    Jarilo God of Spring Fluorescent Backdrop. Clubbing Wear DJ T-shirts PsyWear and PsyArt - CLUB-T-SHIRTS.COM
  • MonsieurM
    forgot to mention earlier :
    to return home or going back to Roots Which coincidently in Arabic , Roots mean:
    AARK
    The Root of the Root of Your Self
    Shamsi Tabrizi,
    has put the eternal cup before you.
    Glory be to God, what a rare wine!
    So come, return to the root of the root of your Self.
    Rumi
    and AARK ...... when "transmutated" ...... becomes :
    Circumsolatious: Noah's Ark, the Zodiac, the 0/9 Number System & the Preservation of Knowledge
    Next we move to the etymology of the word 'Ark'.
    the Noah symbology is also to be found ( Sydera )
    Nilmata Purana
    Nilmata Purana
    39. Then, after the destruction of this world, the lord Mahadeva himself, in the form of water, stays all around this world.
    40-41. At that time, the goddess Sati assumes the form of a boat and the future Manu, through magical power, places all the seeds in that (boat). Having assumed the form of a fish, Visnu - the father of the world - drags off that boat by means of (His) horn.
    Then there is the Sanskrit word Manu to consider. The root nu has already been discussed above as meaning 'ship', 'time' as well as the numbers 9 and 0. The root ma means 'measure' as well as 'mother'. So Manu could be translated as 'Mother Ship'. The Sanskrit work Anu, means 'fine, minute, atomic', 'an atom of matter' or 'an atom of time.' Anu in this light, can be seen as a microcosm of Manu (as is 'Man'). Ma is the Sanskrit root of English words: 'mom', 'mother', 'matter', 'math', 'matrix', 'matriarch', 'mark', 'material', 'manifest', 'many,' 'manual,' 'month', 'map,' 'mass', 'man', 'mantle', 'magi', and 'magic'; and Sanskrit words mas, masa, mahi, mata, maya, mana, mani, maha, mandala, and manipura.4 [see definitions in endnotes]
    You also have MANU SCRIPT
    feel free to try these words in NUM:
    Sun Angel Creations - Law of Attraction Secrets - NumberQuest Numerology - NQ-Multi Numerology Calculator - Calculate Pythagorean, Chaldean, Kabbalah and Gematria Numerology Numbers! :: 123 Free Numerology Reports! :: Unlimited Free Numerology Name,
    Sun today &mdash; solar flares online
  • MonsieurM
    Mandala - Wikipedia, the free encyclopedia
    Maṇḍala (मण्डल) is a Sanskrit word meaning "circle." In the Buddhist and Hindu religious traditions sacred art often takes a mandala form. The basic form of most Hindu and Buddhist mandalas is a square with four gates containing a circle with a center point. Each gate is in the shape of a T.[1][2] Mandalas often exhibit radial balance.[3]
    These mandalas, concentric diagrams, have spiritual and ritual significance in both Buddhism and Hinduism.[4][5] The term is of Hindu origin and appears in the Rig Veda as the name of the sections of the work, but is also used in other Indian religions, particularly Buddhism. In the Tibetan branch of Vajrayana Buddhism, mandalas have been developed into sandpainting. They are also a key part of anuttarayoga tantra meditation practices.
    In various spiritual traditions, mandalas may be employed for focusing attention of aspirants and adepts, as a spiritual teaching tool, for establishing a sacred space, and as an aid to meditation and trance induction
    According to the psychologist David Fontana, its symbolic nature can help one "to access progressively deeper levels of the unconscious, ultimately assisting the meditator to experience a mystical sense of oneness with the ultimate unity from which the cosmos in all its manifold forms arises."[6] The psychoanalyst Carl Jung saw the mandala as "a representation of the unconscious self,"[citation needed] and believed his paintings of mandalas enabled him to identify emotional disorders and work towards wholeness in personality.[7]
    Study shows people capable of reading and solving math equations subconsciously
    , people are capable of reading sentences and solving math problems without consciously thinking about them. The team describes their experiments and results in testing such abilities in their paper published in the Proceedings of the National Academy of Sciences.
    ps: we call it here the flow
    Mayan Numbers Symbols
    6 - Flow. Movement.
    Mount Meru - Wikipedia, the free encyclopedia
    Mount Meru (Sanskrit: मेरु), also called Sumeru i.e. the "Excellent Meru" and Mahameru i.e. "Great Meru", is a sacred mountain in Hindu, Jain as well as Buddhist cosmology and is considered to be the center of all the physical, metaphysical and spiritual universes. It is also the abode of Lord Brahma and the Demi-Gods (Dev).
    The mountain is said to be 84,000 Yojan high (which is around 1,082,000 km (672,000 mi), or 85 times the Earths's diameter). Many famous Hindu and similar Jain temples have been built as symbolic representations of this mountain. The highest point (the finial bud) on the pyatthat, a Burmese-style multi-tiered roof, represents Mount Meru.
    Mt. Meru, Part 2 - The real gold of Khufu | Social, Physics | INTERFERENCE
    Thus we find that God is associated in ancient Hindu mythology with the infinite and irrational golden ratio at the center of a Fibonacci spiral symbolized as a mountain, pyramid, spiraling vortex and by Venus in the night sky. Further reading on the subject describes Mt. Meru as home to all of the gods, closely resembling the Biblical concept of a heaven paved with gold.
    see also : Mt. Meru, Part 1 - The crypt of Rosslyn chapel | Social | INTERFERENCE
  • MonsieurM
    alright some new cool info :
    Hormone affects distance men keep from unknown women they find attractive
    Men in committed relationships choose to keep a greater distance between themselves and an unknown woman they find attractive when given the hormone oxytocin, according to new research in the November 14 issue of The Journal of Neuroscience. The findings suggest oxytocin may help promote fidelity within monogamous relationships.
    from: http://www.energeticforum.com/206207-post2955.html
    La petite mort, French for "the little death", is an idiom and metaphor for orgasm.
    and http://www.energeticforum.com/197649-post2196.html
    "This shows that oxytocin quite likely is very involved in emotional response," Korenberg says.
    Researchers find that listening abilities depend on rhythms in the brain
    Naturally, our brain activity waxes and wanes. When listening, this "oscillation" synchronizes to the sounds we are hearing. Researchers at the Max Planck Institute have found that this influences the way we listen. Hearing abilities also "oscillate" and depend on the exact timing of one's brain rhythms. This discovery that sound, brain, and behaviour are so intimately coupled will help us to learn more about listening abilities in hearing loss.
    think repeated Mantras / Mandalas : Deva Premal - Mantras For Precarious Times - YouTube
    + ( re post because )
    Neuroscientists suggest perception of harmonicity, not beating underlies perception of dissonance
    the perception of harmonicity in humans is more to blame for a dislike of dissonance in musical tones than is beating.
    Those that argue for the second point out that there are incidences in music, such as rock, where people have learned to enjoy roughness, and thus an aversion to dissonant tones is more likely the result of something in harmonies that are preferred.
