Imhotep's Radiant Oscillator Video
  • #31
    step 1 will be released (uploaded) tonight to you tube. hope you guys like it.
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.”
    Nikola Tesla
    http://www.imhotepslab.com
    • #32
      It's up! Oh Joy! Watching now..
      • #33
        Step 1 is up
        GCmole man beat me to it..lol
        Its up you can view the first part here
        Part 2,3,4 will be up as I complete them
        The CFL bulbs which worked 2nd best was the Walmart brand soft white 18 watt which was the equivalent of the 75 watt.
        The best light output was done by the GE 150 watt equivalent from walmart. I cant recall how many watts they actually say it draws I believe it was 42 watts. That one was pretty easy because it was larger. The smaller the bulb the harder it is to convert. Peter altered that same bulb (the ge 150 watt equivalent) and unfortunately crack the first one, but was successful on the second one, so please be careful and sometimes you may need an extra set of hands to help so you dont crack the bulb Post any questions.
        Nikola Tesla
        • #34
          There is more to this circuit than meets the eye
          Don't be fooled by the deceiving simplicity of it.
          Thanks for posting that Imhotep! For anyone who makes this circuit...there is more to come
          • #35
            First Part Done
            Well,
            Imhotep
            You are making us hungry for the circuit! I wanted to go buy some components, just wanted to know what's the components of the circuit. I want to make it running today.
            Elias
            http://blog.hexaheart.org
            • #36
              because of replication problems with the fan i was told to be very accurate on this release ,i will release the other parts very quickly! you will be shocked .
              hopefully not literally . you all ready have the parts you will see soon.the scematic and parts list and movie are being finalized now ..
              Nikola Tesla
              • #37
                I have modified a fluorecents bulb
                I finished my fluorescent, putting away the pcb, then I connected on my bedini with a wall transformer as inverter and light on but parpading
                Hope for yours, Imoptep circuit works better
                Steve Jobs. Apple CEO
                • #38
                  brightness is good and constant with new circuit .
                  will be released soon!!
                  never thought to try fan pulses on tube .tubes are considered neg resistors tho
                  Nikola Tesla
                  • #39
                    I admire your spirit Imhotep, for sharing such important info for mankind, it takes courage.
                    • #40
                      Went to Walmart and picked up 2 of the GE 150/42w lites.
                      Took one apart and modified as per the video.
                      Ready for step 2 (+_+)
                      Mike Klimesh
                      Live to experiment, Experiment to live (+_+)
                      • #41
                        whats going on
                        • #42
                          Preparation for testing
                          Hi, I'm JANGYD, a new comer in this list.
                          I have all respect for IMHOTEP's efforts,
                          more for his spirits and humanitarian to world. Thanks!
                          Today I bought a few bulbs(7W,20W,50W) to prepare for the test.
                          After opening up cap & removing PCB, I finally found there are
                          4 wires. But I'm in confusion how to connect these 4wires to 2terminals.
                          Do I have to connect these wire like belows?
                          1&2 in neighbor(has some resistance)--->one terminal.
                          3&4 in neghbor(has some resistance & open to 1&2)--->one terminal.
                          Am I correct?
                          Best Regards
                          JANG.Y.D
                          • #43
                            There is no Wallmart in my country, so I had a bulb from china, bad quality low brightness only for test. But tninking about this great IMHOTEP's project, I got two Phillips 20 watts very very brights great quality. I hope works well....
                            • #44
                              I managed to light the florescent light with my ignition coil, and the picture taken seems that the light is so much, but it is not even half as much it appears to be, anyway just an attempt for lighting with high voltage. I was pulsing the ignition coil primary with 4700Hz, 18V, 0.37A. It was lit totally cool.
                              High voltage is really fun, but I wonder that in order to get better efficiencies we may be obliged to stick to one wire lighting or even no wire, with pure aether and less current, like Tesla did back 100 years ago.
                              Lets see what Imhotep's circuit will provide! eager to see! More the Radiant higher the efficiency.
                              Elias
                              • #45
                                Am I correct?
                                Best Regards
                                JANG.Y.D
                                there will be 2 wires coming our of each side of the tube. Take those 2 wires out of the same side and twist them together. Take the other 2 out of the other side and twist them together. Your going to be shooting the energy through the gas, no electrical connection through the tube just straight through the gas. Telsa's concept.
                                **~Imhotep~**
                                Nikola Tesla
