Originally posted by thedude
Just wanted to say thanks for such a great effort on behalf of so many members here in creating and developing the radiant oscillator circuit.
I decided i would replicate the basic circuit using a 9 volt (12 amp) relay to begin with so i might follow the development of the circuit to its current state of progress.
I'm using a :
-Accel (model 8140C) 12 volt performance coil
- a 9 volt (12 amp) SPDT Relay
- Condenser from a Briggs and Stratton repair kit
- 100 ohm - 1k ohm pot and a 100 ohm resistor (relay)
- 1uf 100volt cap and 1 k ohm resistor on (relay)
- testing batteries are 12 volt 4.5ah
- 1n4007 diode (backend)
- two 3 level 12/20/26 watt (50/75/100 watt equivalent) coil florescent bulbs
Fired up on my first try. Was pleased. It began by drawing 3.5 to 4 amps. I was ready with 3 flat dime sized rare earth magnets stacked up to to tune the relay as suggested. It took me quite awhile to search out an efficient placement on the relay to achieve a reading of around .5 amps. (between 4.5 -6 volts) I also observed that the circuit would seem to draw less as the it ran quite naturally. Not exactly sure why that is. It was suggested that it was due to the warming of the relay. Could possibly be due to the conditioning of the bulbs as they run as well, i might suggest. At first i hooked up one bulb and had ran it for nearly an hour before i decided to hook the second bulb up in parallel with the first. Initially the two bulbs were very uneven in their luminosity. However, it was not more than an hour or so before they were much more evenly illuminated.
As far as charging on the secondary battery i have witnessed an increase from 11.50 to 11.89 volts in relatively short period (about twice as much as i've spent on the primary battery). I'm really impressed with the basic set up already. Just ran a short test run. Need to button down all my loose ends before really testing the charge rate.
Other than that i haven't made any other real major observations. The relay has been warm, however i'm not too concerned. It seems to be a moderate temperature at best. ( might need a ssg fan ! :P)
Plans for setting up a 555 timer to replace the relay as in other replications.
If anyone can see something i'm doing incorrectly please advise.
Thanks again to everyone here. Great community.
Heres a pic of my first set up.
Oh ya and thanks Lidmotor for waking me up to this thread!
I'm using a :
Lidmotor
