Thanks JORDAN14 you are encourage me to start biuld and testing. Thanks my friend and i hope continue see more updates from you
Greeting!
I done separation of my product, for this purpose I made a separator in industrial style, not sure does it have advantages but they will be probably model as final solution for machine.
The separation was done in more temperature range, first was separated petrol and gasoline after i measure the weight of main fraction in different temperature. On my surprise fraction cough between 80C and 180C have very uniformly weight about 786-790 gram, the heavy fraction start above 210C with weight 820 grams.
Min wile i done the research about my catalyst ant temperatures of catalyst tower. If someone want we can discus about separation diesel and reflux tower temperature.
Greetings!
I start to work actively on my machine, there is a lot work before next test which with god help should be successful.
On design of reflux tower should be put extra attention and to be sure whats ideal temperature for your reflux material as if is not right one will stop all bigger molecules and with that it will be impossible to made anything stronger then kerosene, for my reflux material ideal temperature is 365/370 Celsius degree.
New update
I have definitely production of some acid, First I thought that oxidation is from reflux material as it have iron in self but now when i de-assemble reactor and look pipe that should be used to back vacs in reactor it have traces of corrosion but this part was newer used only evaporated foams could reach there. Before next burning I will paint all metal surface that can corrode to eliminate as mach is possible various factors.Last edited by Jordan14; 06-25-2022, 11:28 AM.
