Motor Generators
  • Looks like Thane posted another set of videos (4 of them).
    For the record, here is my response to one of them, the last one:
    https://www.youtube.com/watch?v=lzqgLlJIGS8
    https://www.youtube.com/watch?v=EH26U-lnCvs
    https://www.youtube.com/watch?v=zOA57TdSDUI
    https://www.youtube.com/watch?v=f1y176L6e1U&t=1s
    I posted a comment on his last video and he responded with another video:
    https://www.youtube.com/watch?v=YY5Yoz9HpT8
    I responded to that video as well clearly showing that his battery is not charging but discharging. Clearly is stuff doesn't work.
      I have never heard of your successful replication of flywheel energy. Did you get half way through the project and deem it obsolete too?
      These devices are energy multipliers
      No they are not. They are current multipliers and energy storage devices, not energy multipliers.
        where is your setup? Many of Thanes 10-15 tests only claim extended range. Do you have a comparable generator setup which proves Thane is lying thru his teeth, because that is what you just said. There are very few demo's with enough coils to break even and that is impossible.
        Until then we will have to wait for real proof for or against but just talking about video's out of context show a malicious intent. Pride is a big problem for guys like you with a popcorn peanut education. Yes you may heve paid alot for your schooling but no one can force another person to gulp the koolaid of misinfo. Global warming and so forth
        Am I right, you wear a mask everywhere and are worried when your vaccines are not updated? Humm? Yup I am right again and can see right thru you super hero ultra smart guys who got a diploma looks like out of a cracker jacks box. But hey, that's just me, what do you care?
        • Start with the original Thane setup in 2007, I believe new ideas are going to supersede the old.
          • Thank you Turion, I think I will use a 12 inch rotor for now as a prototype because my lathe is the best it can work, otherwise I have to go to a friend and make a bigger one, I'm undecided, for now I know I have 6 very powerful cylindrical N52 rare earth magnets with measurements: height 3cm, width 6cm. Of course it would be better to run the rotor at a lower speed because there would be fewer balancing problems, background noise and vibrations, .... What rotor diameter would you recommend?
            • iPhone,this is the view of a company that tried hard to commercialise Thane.
              • I forgot how
                • Hello guys I've seen something in DC motor designs that give me a question its why in the hell don't they use both poles in the motors they only use one mostly north .if your creating a electro magnet to push against a north pole and leave the south just dangling in mid air ??.granted its a engineering head acke but still loose half the power ? If the main shaft was hollow you could run wires inside .I've heard of a guy that used both poles and doubled the output .
                      I forgot how
                      oil pumping and oil producers have no clue, teaching your dog this material will prove more successful. all oil companies know is dumping huge vats of tar and degreaser spraying plus hydrogen sulfide contamination
                      oil Barron's can never understand a purely intellectual discussion.
                      • using a calculator is important
                        • Hi all, Hi bromikey, good to see you still working at it.
                          I've been relaxing a bit, rejuvenating my connection with spirit/home.
                          I just recently built a thermal mass heater, which is surprisingly effective and efficient.
                          What I am seeing with the thermal mass heater, is a correlation in my mind, with the flywheel amplifiers, that you brought up on the previous page bromikey.
                          At the moment, i think those flywheel devices require a strong impulse drive, to extract gain, which is mentioned by some working on those devices.
                          Whether an electromagnet is used to pulse a flywheel, or a loose belt, or a friction drive wheel, that gives it a kick intermittently, the key is a high magnitude torque impulse.
                          I think their is a solid state analogue for that flywheel gain mechanism.
                          My heater is not pulsed, though it does use high magnitude heating elements.
                          Each heating element uses low power, though has high potential, so it is similar to a high value impulse, for brief moments.
                          So it may take a little longer to heat up the 30 lbs. of thermal mass, which is a medium sized terracotta flower pot, filled with pea gravel.
                          The high magnitude heating elements are removed from 120 vac 30 watt solder pens and they are buried in the top of the pea gravel,
                          The thermal mass, just like the inertial mass, wants to keep moving in the direction it is kicked and I think if enough mass is charged up, at some point it will provide gain.
                          It will become like a freight train and it can maintain a certain load gain, based upon the impulse magnitude and if too much torque load is extracted, it will start to slow down.
                          Or if the air space load, the thermal mass heater is immersed in, is too large, then the thermal mass will move below its stable neutral point, based upon the impulse value, where it will move out of the window of gain.
                          Joe Newman's giant eureka machine, derived gain from the pulsed inertial mass, in addition to the large mass of copper, which allowed a high magnetic impulse, for a low power input.
                          Will be watching this site more often now.
                          peace love light
                          • I agree. same thing happens with a Lennox pulse furnace, efficiency goes to the 90's
                              Talking about misinformation: Thane always talks about infinite efficiency... no need to recharge batteries... and his background story in most of his videos is about climate change and global warming.
                              Clearly none of these are the case when you watch his videos. Who has been drinking the koolaid here then... looks like not just Thane. It appears you are in the same bed with him. Wake up Bro!
                              Haha, and when it comes to my political preferences and opinion about mask/vaccine mandates, I would say it is none of your business. Haha. Now you will have to rack your brain again and figure out what that means.
                              But based on the PM I sent you just recently pointing you in the direction of trying some Qigong to improve your health, you should know where I stand on those. Don't forget this virus came out of communist China where you have no freedom at all, let alone any human rights, and where your organs are harvested for profit (www.stoporganharvesting.org and www.faluninfo.net).
                              Or are you going to say now that I am drinking the koolaid here as well and spreading misinformation? Clearly not having personally witnessed from closeup for almost 20 years how the communists persecute people.
                              Anway Bro, just relax and take it easy.
                                Talking about misinformation: Thane always talks about infinite efficiency... no need to recharge batteries... .
                                Another false statement
