HHO Gas Injected Into A Catalytic Converter Yields Extreme Heat! LENR? We Don't Know
  • around page 85 in PDF
    HHHMMM I see this forum will not accept the PDF [perhaps my file inventory is filled a bit too much here]
    It is over here in post number 6
    Lyne Atomic Hydrogen Furnace
    a must read for all..
    thx
    Chet
    BE that change !!
    • Platinum is by far the most effective element used for PEM fuel cell catalysts, and nearly all current PEM fuel cells use platinum particles on porous carbon supports to catalyze both hydrogen oxidation and oxygen reduction. However, due to their high cost, current Pt/C catalysts are not feasible for commercialization. The U.S. Department of Energy estimates that platinum-based catalysts will need to use roughly four times less platinum than is used in current PEM fuel cell designs in order to represent a realistic alternative to internal combustion engines.[5] Consequently, one main goal of catalyst design for PEM fuel cells is to increase the catalytic activity of platinum by a factor of four so that only one-fourth as much of the precious metal is necessary to achieve similar performance.
      Proton exchange membrane fuel cell - Wikipedia, the free encyclopedia
      • Update:
        Got the first part of my gear in and setup on my project table!
        -Altrez
        • "Graphene is hydrophobic – it repels water – but narrow capillaries made from graphene vigorously suck in water allowing its rapid permeation, if the water layer is only one atom thick – that is, as thin as graphene itself."
          Graphene's love affair with water
          So where do the 2 hydrogen atoms go?
          • Hi jdc and all
            Somebody here ?????
            just some progress and experiment
            CAT to LENRapproach 8 wmv - YouTube
            hope this helps
            Laurent
            • Video HHO Being Fed Into Catalytic Converter
              This video shows the process.
              Originally posted by Published on Jan 23, 2014
              Chad at envirosponsble stopped by and liked what he saw and thought his viewers would be interested in this technology as well, This is his video, I uploaded wtih his permission. Thanks For your help in spreading the word.
              H-CAT Video From My Friend Chad's Channel Envirosponsible ! - YouTube
              It seems like the elites knew about the technology even back in the 1950s.
              Good background video to get you up to speed.
              H-CAT? Catalytic Combustion of HHO / Hydroxy Yields Cold Fusion or LENR Effect? + Long Lead In Rant - YouTube
              H-CAT Catalytic Combustion Of HHO Yields Useful Heat Video Demo / Test 1 - YouTube
              The fellow in the video talks about mixing ambient air with the HHO gas.
              Stanley Meyer mentioned it, but he didn't know about using a CC.
              Originally posted by Stanley Meyer
              The velocity of hydrogen is so great that the hydrogen ensuing from a nozzle will not under ordinary circumstances sustain a flame. Therefore, to sustain a flame at a nozzle attached to a hydrogen generator the burning velocity of the hydrogen gas must be reduced.
              Source of quote: Stan Meyer - The Nitrogen Key
              When using a catalytic converter, it looks like you don't need a flame. It will make its own flame.
              Can you imagine what Stanley Meyer could have designed had he known about using a catalytic converter with HHO and ambient air, but in the above image, Stanley is mixing some of the exhaust air back into the reactor.
              I wonder if anybody has done that yet with a catalytic converter.
              It would be interesting to note the results.
              Enjoy.
              Vidbid
              PS: Just imagine if we had Chemalloy technology now, what we could do with it and the CC and HHO, ambient, and exhaust.
              http://www.energeticforum.com/renewa...tml#post193254
              PPS: Good luck on your forced HHO Gas Catalytic Heater, that is, your HCAT Build: H-Cat Ver1.0 Build Update / Catalytic Combustion of HHO is HHOT! - YouTube
              PPPS: Video on HHO Flash Arrestor: HHO flash arrestor for HHO and HOD systems. - YouTube
              VIDBID
              • Professor Yeong Kim predicts sulfur in the H-Cat process
                • The geometry design of the catalytic material honey comb was useful for automobile exhaust system.
                  You can see the size of the red glow from an HHO torch hot or cold applied from outside. The delta H of reactant is short of requirements of chain RX of nitrogen atmosphere and catalyst concentration. Taking resonance into account the chamber volume and shape along with matching resonance.
                  I would expect the final diameter of a long tapered tube to give frequency in GHz but it starts in an audible range.
                  PCI with atomiser gasoline spray - YouTube
                  There does'nt need to be sulfur eventually with pure water.
                  • Be mindful of your health ...
                    Just a note of warning, this reaction creates abundant free radicals so can be very bad for skin, hair and respiration.
                    So please be careful !
                    "There is no subject more captivating, more worthy of study, than nature. To understand this great mechanism, to study the forces which are active, and the laws which govern them, is the highest aim of the intellect of man."
                    • Steelrat
                      Have you studied/tested the efficiency ?
                      thx
                      Chet
                      BE that change !!
                      • Hello RAMSET,
                        no i won't be replicating anything involving Palladium/Rhodium or any of the noble metals in a catalytic reaction with H2 and O.
                        Generating Brown's gas is one thing, playing with these reactions is another.
                        Experimenting safely means experimenting knowledgably, and most of the people doing these experiments are neither chemists nor metallurgists.
                        Union Carbide were doing experiments in this area in the late 40s or early 50s i can't remember. Their lab-book was declassified and is available on the net but i forget the title so will have a hunt for it.
                        All the best.
                        • Union Carbide under ORNL ...
                          Found it :
                          http://web.ornl.gov/info/reports/1952/3445603529607.pdf
                          All the best.
                          • Why is there no mention here that the use of the catalytic-conversion process as an efficient heat source has been known about and used for decades? Handwarmers that employ a palladium filament use lighter fluid as the fuel. The only differences between the use of HHO and lighter fluid is that with the latter, the filament must be pre-heated in a flame for 5-10 seconds - so no 'self'starting'.
                            A catalytic hand warmer is heated by a the catalytic reaction of the hand warmer’s platinum-coated filament burner head coming into contact with fumes from white gas lighter fluid. In order to start the catalytic reaction, just hold a flame to the burner head for roughly five to 10 seconds. The filaments in the burner will begin to glow (sometimes visibly, other times not so much) and produce heat. The burner will continue to generate heat from the catalytic reaction for as long as there’s white gas fumes to fuel it.
                            A link to a video of the 'Zippo' handwarmer. https://www.youtube.com/watch?v=gkIe...c&noredirect=1
                            If this also works for lighter-fluid by pre-heating the filament, is there any chance that it might also work with just water vapor, or even better, a fogger's output? Sucking the fuel into the catalytic converter rather than squirting it in might also perform better.
                            • Very very nice....
                              Steelrat
                              Wonderful contribution very informative ,a must read for all looking at "Whats New" in this field.
                              @Sprocket
                              yes there are industry applications for this process however the state of the art worlds most efficient heater in this case still plugs into your wall.[resistor]
                              At least that is the case so far .......what the steelrat has shared and
                              perhaps a pinch of William Lyne [occult aether physics think he's going/speaking at Aaron's conference] and some of this ,
                              From Conrad at OU.com
                              qoute
                              Some information about Irving Langmuir and his inventions:
                              You might already know all that. The information is not filtered and not conditioned to your specific needs. So, do not blame me if you loose time and if you do not like it.
                              The Moller's Atomic Hydrogen Generator
                              The Moller's Atomic Hydrogen Generator (MAHG) is fully based on the Irving Langmuir discovery. In the MAHG, the hydrogen is merely dissociated and recombined and can therefore be recycled over and over again without consuming more hydrogen than the quantity used to start with.
                              REVEALED
                              You might be interested in this project. In 1926 Dr. Irving Langmuir discovered an anomaly:
                              When hydrogen is passed through an electric arc it is converted from molecular Hydrogen to H1 or atomic hydrogen. Atomic hydrogen has unusual properties.
                              http://www.energeticforum.com/water-...ogen-fuel.html the blow torch was discussed here
                              IRVING LANGMUIR - National Academy of Sciences
                              page 216 list of his papers (which could be obtained from a University library):
                              Atomic Hydrogen Arc Welding (1926) .
                              Irving Langmuir - Engineering Hall of Fame
                              Atomic Hydrogen Blow Torch
                              Lateral Science - Atomic Hydrogen Welding
                              The Case of Dr Irving Langmuir and General Electric - Academia.edu
                              Greetings, Conrad
                              things will change!!
                              thx
                              Chet
                              BE that change !!
                              • The Atomic Hydrogen Process is 100% CLEAN and SAFE.
                                When you add the fact that the hydrogen is not consumed in the “burning” process, and can thus be recycled, it should become very clear to any scientist, humanist, environmentalist, business executive and indeed to every human being that is concerned about the state of our wonderful planet, that no more time should be wasted. The time has come for removing the responsibility of defining the energy policies and structures of the future from the hands of the established energy industries, and place it in the hands of men of science who will work for the preservation of the environment that sustains all life on Earth. Men who will work for the economic development of the third world by means of providing clean, abundant and inexpensive energy technologies.
                                Such initiative will only succeed when massively supported by the visionary captains of industry who will have the courage to dismantle the existing and scandalous energy grid which now envelopes our planet, by investing in the production and marketing of small energy generators for individual households, factories, transport etc.
                                Once such a generator has been acquired by the consumer, his further energy requirements will be covered for FREE, giving him independence in terms of energy as well as increased buying power for any other economic development.
                                Nicholas Moller
