Is every present some confusion about Meyer on the method used for run the famous water car.
As you know HHO is only an changed of state of liquid water , have some names (Brown gas, etc..) but in fact is water at burnable state, when burn return to original state (reverse formula).
Electrolisys is simple way for obtain HHO but you need an great amount of energy and using electrolyte like NaoH/KoH you obtain some dangerous vapours in output.
You can obtain simply that without use electrolisys but an simple DBD reactor with 9-10% of salt as catalyst.
Catalyst NOT electrolyte, is important understand that!
An DBD reactor use high voltage AC and similarry is comparable to the Meyer injector tube, the only secret is that you need in input water at vapour state (with salt dissolved inside) and an variable high voltage source.
HHO is used from Meyer in association with exaust gas for create an powerful gas fuel mixture comparable with gasoline for run the water car.
In fact Meyer use two DBD reactor in serie (you can found simple the design on internet), the process start inside water tank creating water vapour (STEAM RESONATOR) that is sended trought the RESONANT CAVITY UNIT creating water gas, the second DBD reactor (Gas Processor) process air/exaust gas mixed with water gas.
The main problem of Meyer was that sometime car stopped to work because don't have constant fuel gas production, that because technology was limited. In fact Meyer don't have an high energy source necessary for ionize nitrogen and obtain an great amount of NH3, for that reason mix little amount of NH3 with water gas and use injector/plug in combustion chambre.
For solve that problem is needed change an little the configuration changing the second DBD reactor with an e-beam reactor for obtain in real time the fuel mixture in output and create an good source of water vapour (mixed with nitrogen).
In all case Meyer (and others inventors) inside water add salt as catalyst.
Here you can understand why..
dissolve
dissolve
