I don't know .. probably not with the currect configuration.
Fuel cell and atomic hydrogen
You can send liquids in vapour form but you need vacuum. Vapour's refractive index is an issue as well. Maybe it's possible to dissociate H2O into hydrogen and oxygen... but I have a strong belief that another system is needed in combination with this because of the different surface area of water droplets.. compared to gas molecules. We can try using high frequency piezoelectric transducer but vacuum helps loosen up the molecular bonds.Last edited by tachyon; 11-30-2012, 11:37 PM.The pure in heart will see the light.
Alberto Tavanti reading, the disciple of Ighina recently deceased,
I had this idea based on the law of reflection and absorption:
it is a double spiral of optical fiber across which enters the beam of light of two laser pointers opposites;
the light is trapped in a spiral shape that second Ighina should create matter and have anti-gravity effects, the center of the spiral.
The cooling of the optical fiber can be done with a rubber tube in which water circulatesLast edited by Franco malgarini; 09-05-2016, 01:38 PM.
The same heat of formation will be that of dissociation...
not a single joule from anywhere other than your power source...
You are not understanding that nor reactions are never 100% efficient..
To be able to determine if your ideas work, you need science.
Without proper measuring equipment and technics and numbers you won't get anywhere, you can't compare an elephant with a rat and say one is bigger than the other if you don't know the numbers and the precision of your measurement.
Platinum is not magic, it only ionizes the hydrogen if the triple reaction phase is there since the ion can be transported due to difference in electronegativity... oxygen wants electrons...
try to think more and construct your stuff, if people ask you if you tried, answer it, instead of suggest make others try your crazy ideas before you.
Best Regards
Hello Sebosfato
Unfortunately I do not have a preparation as an engineer or a physicist,
I have no time because I work, I have no lab, I have no money to patent: what shall I do? I have ideas to be developed, but the research institutions do not take into account;
then write in the forum hoping that someone will do the experiments, which are then simple ....Last edited by Franco malgarini; 09-05-2016, 01:38 PM.
CO2,H2O,H2,CH4,etc..
Exist an simple way for reach an Energetic Closed Loop starting from gasoline/diesel and process the exhaust gas for transform in a new gasseous fuel. In part is the tecnology used from Stanley Meyer but I have found an very low cost method using as convertion energy JUST the heat produced from engine.. As a fundamental concept in physics, the law of conservation of energy provides an explanation for how energy is conserved and converted within a system. Generally, one form of energy can be converted into another form of energy.Last edited by tutanka; 12-02-2012, 02:02 AM.
what would happen if we were to enclose the superlight:
Dr. John V. Milewski - Presents, The Wonderful World of Advanced Materials.
