Hi guys!
I just got some crazy hho output with the bedini charger (modified of course). Now the modification is the strangest part. I'm no pro, but I like to tinker and try different things. I have a bifilar toroid choke for both the positive and negative, and haven't tried without that but I'm sure the results should be about the same.
So I stumbled on the phenomenon by accident. I was trying to measure amp draw with my cheapie meter. I set it to the 10A setting and changed the probe to the appropriate connector. I then started connecting it in various places and noticed that the fan slowed/quit moving on certain spots, and then I tried hooking the positive end to the positive tube and the negative end to the negative input source.
So my input is 19v @ 90 watts (that's whats listed anyway) and the meter while hooked up shows 1.8 on the screen so I'm assuming 1.8 amps. I re-confirmed the input voltage on my analogue meter to be about 19 volts. As I was trying to connect the probes I heard a strange noise, and lo and behold the hydrogen production went from tiny little bubbles to boiling water! I confirmed (with ringing in my ears) that it is indeed HHO by burning a very large bubble. So is this really high hho output at around 40 watts? By the way, the fan will not turn in this mode. And there is no cap pulser on the back end. Just a straight connection to the tubes.
I'm busy at the moment with other things so I can't make a video yet but any comments welcome. I thought I'd share because anyone with one of those cheapie digital meters can try this.
Now for some extra testing I did... This is the weirdest part. I made the gap on my stainless very small and so i was pulling the tubes out of the water to try to see if the amp draw would go down, but to my surprise it went up. In fact when I pulled it out of the water I heard a loud hiss as if the water was really boiling hard then the gauge went off the scale so I quickly put it back in the water to not burn out the fuse. This is the craziest part. I started seeing white arcing at one point under the water so I chickened out and disconnected the test probe, waited a few seconds and plugged it back in... then the high level production resumed.
By the way, this was all done with regular tap water. I'll have to try with distilled water sometime, but like I said I'm so busy with other stuff.
Thanks for the interest!
Well forget the 'crazy' results lol.
