plasma ignition
To see better what is closer to real application, not a vacuum gap but
a pressure chamber like what Rosco and a few others made for some of
their tests. I haven't used these myself, I just did the testing on real
engines along side the bench tests.
Magnetic fluid conditioning allows the fuel to atomize better because the molecular clusters are broken apart. But if the magnetic field is too strong,
the clusters will recombine but in long organized chains defeating the
purpose. The strength has to be tuned per application. They're all on
this page: Magnetizer Read my post here for more info: Magnetic Fuel Saver
It may have been Revizal who got a gas engine to run on diesel with the
plasma ignition - been a while but it is all in the first water sparkplug thread.
MSD will not eliminate the vacuum effect of water/hho recombining. The
recombining is irrelevant when the water or hho is a supplement to
gas/propane, etc... those will give you the thermal combustive energy and
you get some enhancement with the water.
It is when you're trying to use only water or hho. You have to get
thermal combustive energy by mixing nitrogen with it in the proper way.
That's the key or you waste your time.
