  • Copper grid faraday cages would seem to be inefficient for rf signals. Perhaps a better way to shield water container seal as well as internal surfaces would be with RF shielding paint...
    Electromagnetic Field Shielding Paints
    kind of expensive, perhaps the stuff they paint on metal radiators would work as well
    • Shielding
      Heavey gauge aluminium foil all around and grounded to coax shield
      Mike
      • The paint works fairly well, although it does not work as good as steel covers:
        My former employer used it to meet I.E.C. 34 regs ("CE Mark") for Radiation, by spraying it onto the inside of plastic cover pieces... and these devices were always a challenge and pretty darned noisy throughout a wide spectrum; having Piezo thermal print heads, Stepper motors, and switching supplies.
        Untwisted bundled-strand steel wire which has plastic insulation that is green with a yellow stripe, is the most widely accepted ground wire used in Medical and many other electronic applications (comes in many gauges). It is what is required for "Medical" in the US . Great care has to be taken when SOLDERING on ring or spade lug connectors... don't ever trust a simple crimp
        Steel covers are probably best of all. Aluminum that is NOT Anodized works but not quite as well (probably slightly better than above conductive paint applied to plastic). If painted with "regular" paint, it is very important to fully remove the paint where ever the cover pieces meet, and of course where the wire joins
        • Phase relationship
          Wouldn't there need to be some consideration to the phase of the 2 signals
          at the antenna since we are wanting a hetrodyne effect of the 2 signals?
          Itzon
          • Originally posted by itzon View Post
            Itzon
            The phasing will move into periods of alignment and misalignment, causing the beat frequencies we want. Phasing cyclically changes with respect to time, and will always "work".
            • Originally posted by Armagdn03 View Post
              This will only happen if you use 2 VCO's that have no reference freq.
              If it is built using a frequency multiplying circuit, the phase angle is always going to be the same at the antennas, and the phase angle is going to be determined by the circuitry that is between the 2 outputs.
              Itzon
              • Phase angles
                Hi itzon. If the frequencies are different the phase angle will be constantly changing between the 2 signals. Since the signals are six times apart then once every six cycles of the higher freq. the phase angle will match up very briefly. For the rest of the time the phase angles will not match. Because they are constantly changing we get all the other freqs we want. A heterodyne signal is simply the plus or minus of two other signals. In this case we are also taking the plus and minus signals and mixing them again with each other and with the original signals to create a another set of freqs which we then add back in again over and over to create a whole realm of freqs all in the same area to weaken the bonds of the H and O. I hope this helps.
                Carroll
                  Itzon
                  Good point.
                  my only guess would be that at these frequencies, and with varied antenna and cell / container geometry, the radiation will not be polarized, and after reflections etc. phasing will vary?
                  as 1/4 wavelength for 120mhz is 0.625 meters
                  and for 720mhz is a mere 0.104 meters or 4.1 inches.
                    Good point.
                    Yeah, I thought of that too. The container geometry(mostly) and medium within are variables that have to be kept in mind.
                    When dealing with RF there are a LOT of details that matter that are not thought of if your not familiar with them.
                    • Hi All
                      You do not have to worry about any phasing of the two EM waves, they will not be in phase as there is a time delay when using one VCO and then two multipliers to give X6 from the base frequency. Also you are correct on the termination of the signal "antennas", these are inside a shielded container to a very close and parallel earth "a type of coax. With this configuration the load to the transmitters is seen as capacitive giving a high impedance, and a series inductor will be needed at the antenna connections along with a bridge inductor to ground so as the transmitters will see a lower impedance, near as possible 50 ohm load.
                      The antennas are positioned in relation to one another less than a multiple of a quarter wave length.
                      The transmitters are a lot easier to ajust if one VCO is used and two multipliers for the higher frequency, as you tune the frequency split is always the same and as so when tuning the antennas you can tune the frequency for the exact resonant frequency of the antennas, this makes life a lot easier.
                      Mike
                        Hi All
                        Mike
                        Time=phase
                        The 2 frequencies are multiples of each other, so to just say that phasing doesn't matter is not even close to a reasonable response.
                        The waveforms could most certainly be in phase. It depends on the freq. multiplying circuit. You know how transistor circuits(in the multiplying stages) phase shift a signal, but I don't know the specifics of your X6 circuit.
                        How does noise canceling work?
                        SIGNALS OUT OF PHASE CANCEL EACH OTHER.
                        It doesn't matter whether the signals are 2, 3, 7, or 50 wavelengths of timing apart. What matters is the time(phase angle) when they intersect.
                        @ Cifta
                        The phase angles will constantly change between the primary and desired multiple only because the phase shifting of the circuitry is not an even 0 or 180 degrees.
                        Itzon
                          Time=phase
                          @ Cifta
                          Itzon
                          You can make the circuit do what you want, you can change the phase shift at the splitter, normal place, it can be 0 or 90 or 180, the rest of the circuit of intermediate amps due to losses, frequency multipliers etc are designed to be linear.
                          Mike
                          • OK. So our water vapor has a charge?
                            • Originally posted by Vickers View Post
                              It has an alternating charge, it is highly vibrated, imagine you are stood between two people, bullies, and you were pushed back and too, how would you feel?
                              Mike
                              • Another way to look at it, you are on a swing and there is a person in front and one behind and each are pushing you at different TIMES, do you think you might fall off? what happens to the pushers as the swing hits them, are they pushed farther back or farther forward?
                                Just trying to help you see what is happening
                                Mike
