  • Originally posted by tutanka View Post
    All riferiments of contacts Walter inventor of that patent Radio frequency hydrogen and oxygen generator and method - Patent 7378063 are removed That is your mode of share informations??? You are great !!!!
    Hi Tutanka - not sure who your post is addressed to, but here is some contact information: http://www.energeticforum.com/renewable-energy/6431-none-electrolytic-splitting-h2o-10.html#post113246
    What was removed? I am unfamiliar with 'riferiments' is that the same as references? I see Walter's name is still there in your link above as Last, First, Middle names (Wyles, Walter Eugene) and his address.
    Hope that helps
      Hi again Tutanka – As far as I am aware the US Patents which are in the public domain are supposed to be “inviolate”, After all it makes little sense anyone lodging a patent of any sort, if information can be added or removed on a whim by anyone. It makes a mockery of the whole process.
      If you believe this patent is being “Tampered” with in anyway Tatiana I would suggest there is a good legal basis to challenge its validity. However perhaps someone with a bit more legal nous would like to comment?
        Hope that helps
        Yes.. is there because Mike don't have deleted that post .. However if you see back Nvisser have removed these informations.
        • Originally posted by Duncan View Post
          Duncan,
          That patent can be used only for PRIVATE usage and I don't know if Mike want use that for private or commercial usage. However I'm pretty sure that him want use that technology for create hydrogen/oxygen and after mix with nitrogen for produce special mixture. But my question is .. you are sure that Walter patent work as aspected? If yes what is production of hydrogen/oxygen? I don't have notice about an replication of that. As you know are present millions of patents but no more works as aspected.
          • container is shielded and grounded..
            Is my opinion that first to proceed to build any system I need understand the working principle. I have read Walter patent. Him create in fact 4 frequencies, 120,720,600,840 MHz and the container must shielded and grounded..
            That method for me is similar to the UWB technology (ultra wide band). In fact high frequency waves are irradiated inside container and can't go out! Is similar to an RF loop with water entrapment inside. The two dipoles and container formed the antenna creating an Closed Heterodyne Resonance Mechanism. Probably an RF cold plasma is created with waves bombardment and the effect produced is similarry to electron avalanche splitting the water molecules.
            • from..
              These words are extracted from: The Water Fuel Cell :: View topic - Magnetic Resonance ?? good stuff here...
              "There are other patents dealing with high voltage and frequency breaking down water by people other than Meyers. Their explanation of this phenomena was based on molecular collisions or electron avalanche. What ever the case, the high voltage and frequency cause chaos at the molecular level which leaves molecular bonds weakened and vulnerable for a brief period of time. It's during this time when a DC voltage differential across the two electrodes can cause a gas harvest which far exceeds Faradays law. "
              That's right!!
              Electron impact loose molecular bonds.. The same effect appear inside Walter Cell. For reach success with Walter method you don't need only right RF circuit creation but the KEY is resonant cylinder or simply called on patent Heterodyne Container.
              I'm also pretty sure that you can use AM band as Meyer and some other researcher's, using an variable oscillation circuit and an coil as amplifier RF you can reach the same success.
              • Tutanka
                Perhaps thats what is happening here?
                YouTube - FutureEnergyConcepts's Channel
                Chet
                BE that change !!
                • Originally posted by RAMSET View Post
                  Tutanka
                  Chet
                  No! For me that is standard electrolisys.. electron avalanche is similar to an chain reaction.. Surely the reaction happens violent when you apply resonant frequency to the right cell
                  • Meyer words..
                    "The polar pulsating frequency applied is such that the pulsating electric field induces a resonance in the molecule. A cascade effect occurs and the overall energy level of specific water molecules is increased in cascading, incremental steps. The hydrogen and oxygen atomic gases, and other gas components formerly entrapped as dissolved gases in water, are released when the resonant energy exceeds the covalent bonding force of the water molecule." -Meyer
                    • @ All
                      Well just got in and waiting to use the bathroom, so I will use this 5min to explain a little further.
                      The explination in that patent is not fully correct and there are parts missing of which I was the only person that knew. The heterodyning actually takes place within the denser water molecule not in the air, the water molecule absorbs the RF at these frequencies.
                      High voltage is a part and has not been explained yet, but hope to explain more in the US for those whom want a bit of a lecture over a beer
                      Mike
                      • Amazing discussion here!!
                        edge of the seat stuff!
                        I bring something for you Men [and maybe one woman]
                        to view.
                        Could be, should be a "MONSTER"!
                        Sorry for the interupt ,but this doesn't happen every day!
                        post 1445
                        Enjoy
                        Chet
                        BE that change !!
                          @ All
                          Mike
                          Hi Mike, will you be on the West Coast?
                          • I suppose Mike when I think about this in simple terms low frequency waves don’t see water at all and pass through unaffected, high frequency waves however are totally blocked by water, hence the Micro-wave oven does a super job of heating water.
                            We are going to heterodyne inside a fog.
                            Which is neither water nor air; I have no trouble visualizing our waves traveling unhindered through the air portion indeed coexisting quite happily together.
                            Inside a droplet of water it’s obviously a very different story.
                            I have never actually seen one of these foggers are they adjustable? Do they need to be? What is vibrating a rubber membrane?
                            Is it perhaps something after this style we seek Mist Maker Fogger Humidifier Water Pond Fountain 12 LED on eBay (end time 10-Nov-10 14:34:21 GMT) or something similar?
                            I Include for consideration This clip of John Kansus also fracturing water using RF Surly this validates the technique for any doubters following the thread? YouTube - Water as Fuel Unlocked by Frequency Resonance
                            Just a coincidence do you think that like the late Dr Andrija Puharich the man was hunting for a frequency based cancer cure.Here is another clip of John Please take note of his ex job YouTube - Salt Water-Powered Car? Just a coincidence that Andrija, Stan Meyer ,John Kansus and for that matter Mike are all “Au fait” In RF transmission theory ? I think not!! Mike is showing us how it was and is being done !! In light of this and Mikes comment post 206
                            It starts become apparent how important the principle is and how it also crosses over into Rifes field of heterodyning, this principle and theory is incalculably important thank you for broadcasting it Mike.
                            • That ultrasonic humidifier is what we need . You do get them without all the leds. That is a good price though. They ask up to $40 here by us. I got one local for $14 on EBAY. I bought it for a carburetor car but never got around to use it.
                              • Watch!
                                We are not looking for a fogger but rather a humidifier as nvisser mentions. A fogger creates a mist which have very little velocity and in the type of construction that is described by both Mike and the patent, we can clearly see that the water molecules is passing the interference area in the top of the unit. A simple fogger would require that the interference area is placed in the bottom of the unit. Do watch this video where a ultrasonic humidifier is described. And keep up the good work.
                                Deconstructed: How Ultrasound Humidifiers Work. Discovery Ch - Science EP.
                                - Behold the truth -
