A WARNING to all working with PLASMA
  • #16
    This thread contains a great deal of stuff that i would term "nonsense", or perhaps to be more precise, "Dis-info".
    > A shopping cart IS NOT a good "Faraday Cage". Faraday Cages are generally copper sheathed over 100% of the inner area, even with special concerns for the corners and doors to insure total enclosement... Not chromed steel bars with poor conductivity, that cover only about 20% of the total area, the rest being "holes". And not insect screen, either. What is the idea there, that some magical barrier is created that "covers" the holes and keeps RF from radiating through them?
    That is simply not true.
    > The claim that these pulses "cannot be stopped by a Faraday cage" is either out-and-out wrong, or "practically not correct".. Meaning that EMP or Longitudinal waves can indeed be shielded ("shunted to Ground" is what we are actually talking about here), although it IS harder to do so the higher the amplitude. The "practical" aspect is this: The equipment large enough to generate such an "unsheildable" pulse; is too big to physically fit inside most Faraday Cages. There are reported to be "EMP bombs" that could possibly fit, but that is not we are doing here, or even close to it... A spark gap, as we would see in a "Kapanze" or ICE plasma spark, is DOZENS OF ORDERS OF MAGNITUDE weaker. And i assure you all, that a proper Faraday Cage WILL stop them (as will a well-grounded metal box around them). Please provide data to the contrary, if you can.
    > The by-far largest manifestation of what is considered "plasma" in the mainstream is atmospheric Lightening. Trees squarely hit by lightening often live 100 years longer. Where it strikes a lawn, only the grass right at the burning arc point dies, a couple inches away it is fine. People who were just "nicked" by lightening, meaning only a very small current went through them, often live long lives. Those who were less fortunate and died or were maimed, had the explosive cellular disruption and intense shock that stops the heart, and the thermal burning from the current flow to blame for it. There is nothing mysterious about those effects.
    > There is no evidence at all given here that "plasma" is inherently dangerous by some unknown means (with the implied conclusion being "we should not study it"). What IS dangerous, is High Voltage, in ANY APPLICATION, including "boring" and mundane conventional ones.
    There is an old story, about a technician who was crawling through a cable race way in a hospital in Canton, Ohio... And his big belt buckle snagged on a 200 Amp line. They say all they ever found of him, was the twisted and burned belt buckle... meaning he was "vaporized". Whether this "Urban legend" is fully true or not, is not the point... as it COULD happen. THIS is the real, and serious danger of high voltage/ high current electricity that we should always remember. Lol we used that story, that several "bio-med" folks who worked at that hospital personally told me was "true", for years to scare the pants off of newbies
    And to make them think.
    > The correlation given with "Tesla" and his early discoveries with radiated energy makes no sense to me... He was switching HUNDREDS of amps there, to generate what some would describe either as EMP pulses, or Longitudinal waves. This is much, much more than we could possible get from a "spark gap", or plasma ignition in ICE. These two non-related things were simply thrown together, without a correlation. The one has nothing to do with the other, "plasma spark" is a different phenomena... If there is evidence to contrary, again, let's see it.
    As an example, there is a phenomena that is similar to what Tesla described in industry that i am familiar with, caused by the sudden relay switching of large SCR drives used to power giant conveyor systems. These transient pulses can disrupt computer equipment on totally different grounds and mains circuits, over 100 meters away in different building, even. I know, ive seen it happen at more than one mill, and helped my Customers solve it using the test and measurement troubleshooting equipment my employer sold. But this phenomena has nothing at all to do with "plasma".
    Let's go back to "Basics", and view this subject objectively.
    Here are the possible technologies regarding the subject "plasma", that Open Source home experimenters are likely to be able to replicate:
    > Devices that use Spark Gaps.
    > Plasma Spark Ignition for ICE (either for Hydroxy, or gasoline; it has been demonstrated to improve efficiency of burn in both cases).
    > Ed Gray Tube-related studies.
    > And peripherally (just because they radiate a lot of RF but probably do not actually use "plasma" except inside of lamps), exotic Inductance-based techs, such as the work of Dr. Stiffler, the "Joule Thief", and the ~Imhotep~ "CFL" free energy Open Source project. We also see some high RF coming from several pulsed motor techs.
    In each of the above cases, i strongly believe based on experience that proper shielding would allow them to be marketed and mass produced for sale... relatively easily and cheaply too. After all, a device needs a "cover" anyway.. So it is not much more work or expense to make it a proper "RF shielding" one.
    As an example: Piezo-based Thermal Print Heads, and also Stepper drive motor circuits, radiate large amounts of RF noise throughout a wide F spectrum (and they are often seen together in a printing unit.. along with tremendously high static charges coming from the movement of the printing medium and/or ribbon as well). Metal enclosures, well grounded; completely eliminate this blended radiated RF so they can meet strict IEC 34 "CE mark" requirements... Otherwise no "piezo-electric technology print head" printers would ever be sold in Europe (fax machines, thermal array, thermal transfer industrial high speed label printers, large body ink jet, toner-based electrostatic, etc).
    Here are some techs we often hear about, that are related to "Plasma", but we are unlikely to be able to replicate at home:
    > Dr. Kiril Chuckanov's Ball Lightening Chambers. Claimed to get "COP>8" or more with "1 megawatt" output (which is about 400kW of direct electrical power out for 100kW "in", plus "Heat" and "produced Hydrogen" added in for the total COP value). Microwave excitation pulses are used to sustain the "ball lightening as big as a man's head".
    > The Correas' "Abnormal Glow"-based devices. They are keeping their COP figures pretty much "secret" but Dr. Eugene Mallove said he witnessed it at well over "OU", before his murder 6 years ago.
    > Josef Papp's ignition of noble gasses engines, witnessed by many to be continuous OU, including "Cal Tech" University who sponsored tests in the late '60's that included Naval Research Lab personnel being present and opening it for inspection.... until the converted Volvo engine exploded with suspiciously tremendous force and killed someone right after one such "inspection" by Naval personnel.
    More recently, the John Rohner Plasma Noble Gasses motor being developed by his group "PlasmERG Inc." is admitted to be based on Papp's work as well (i hope they keep supposed "Naval Research Lab" people far away from it, lol).
    > The BlackLight Power "Hydrino" reactors. This technology was verified as "Overunity" last year by Rowan University of New Jersey; and now there are commercial ventures to build multi-mega-watt sized units for centralized grid power generation.
    No one need lose any sleep about the shielding of the above "too complex to replicate at home" devices
    Now what i admit may possibly be a valid worry, is our experimenting with spark gap devices at home for reasons of RF. I would say, that to be safe, one should set your spark gap, then shield it with a well-grounded metal "box" around it.
    And your neighbors may thank you for it, as well
    But these are not reasons to ignore these techs, and not study them. If someone has proof of these "inherent unseen dangers"...
    ... Let's see it now.
    And just to be CLEAR, that does not count the well-known dangers of heating caused by microwave frequencies that heat the water molecules present inside of animals and plants. Although this, like High Voltage applications, is a very legitimate worry and people have even died from being within the concentrated beam of RADAR's... You can't get away with equating them to the thread title, as this has nothing to do with "plasma arc".
    ... Again; unless some one has evidence to the contrary?
    • #17
      As always....safety first.
      Perhaps some of the more technically proficient of the group should consider starting a thread that covers all the basic safety issues and remedies they have experienced which are advisable for those who are not so well versed or professionally trained.
      As the motto goes:
      Learn from the mistakes of others as you are guaranteed to not live long enough to make them all yourself.
      • #18
        Well, thats fine and dandy, as long as people realize that any concerted efforts here to paint these important technologies as being somehow "too dangerous to study" will fall utterly flat and
        FAIL.
        • #19
          Every thing in controlled conditions, high frequency and plasma i say would do some GS units dirty electricity) so shielding is needed.
          In Fact i remember Rosco telling me about their plasma spark plugs and how they need to measure GAMMA RAYS! yep...be careful CONTROLLED CONDITIONS. SHIELD PLASMA EXPERIMENTS PLEASE
          • #20
            Originally posted by jibbguy View Post
            Well, thats fine and dandy, as long as people realize that any concerted efforts here to paint these important technologies as being somehow "too dangerous to study" will fall utterly flat and FAIL
            It is not about these things being dangerous, but that common sense and just simple understandings are sometimes not present in a lot of hobbyists/part-time experimenters.
            That's my take on it.
            I am a stone mason by trade and have only worked somewhat with electricity (1st year apprentice equivalent) so a lot of simple things and precautions which a seasoned experimenter or technician will know, I may not......but I like free.
            And so I like to tinker around.
            But good info from experienced people is sometimes scarce and hard to come by.
            That keeps me from doing a lot of what I would like to do.
            IMO The whole idea behind free energy anyways is open source everything as that is the only way to get around the rich corps who hide it from the people....they just want to keep people away from such things.
            And the way to get a wider distribution of people actually doing something is to demystify it and simplify it.
            Basic electronics 101.
            Just like they should do with the legal system and put the bulk of the parasitic legal profession out of their pretend jobs and off looking for real/productive work.
            • #21
              Its a misreading from the detector, its the EMP who cause the Geiger meter to fail when exposed to magnetic pulse radiation of a good magnitude, JNL experienced the same thing with his carbon electrode when making experiment and at the end he found that in reality there was no radioactive radiation at all even if the meter was showing some.You can contact him if you want more info about this phenomena.
              Best Regards,
              EgmQC
              • #22
                Thanks for that EgmQC, i think Rosco can shed more light on it, they really needed to check if this thing was putting out Gamma and others for a reason, he will be back in action on the forum soon.
                Ash
                • #23
                  Hello all and sorry for my noobieness.
                  What do you exactly mean by "plasma" experiments. By Plasma/Spark/Ark you mean Tesla Coils too? Experiments with HV and Flyback transformers? And the BIG-Joule thief experiment included in the plasma category? Since it does output high voltages and the circuit could oscilate at high frequencies even reaching to 1Ghz (microwave) coming off the Fluorescent?
                  Thanks for your pacience.
                  Ben
                  Innovative Technology: Research & Design
                  • #24
                    Ben
                    Plasma mean that you ionize a gas, can be air or waterever, with High voltage to make it a conductor.The plasma appear when the gas become a conductor.
                    Best Regards,
                    EgmQC
                    • #25
                      Best Regards,
                      EgmQC
                      Thanks a lot, I understand this warning now.
                      • #26
                        From Peter Lindemann website:
                        I carefully read through The Lakhovsky Multiple Wave Oscillator Handbook for the answer. What I found is interesting. Every single MWO schematic printed in the book, except for Lakhovsky's patent diagram is a model of or a variation on one of Tesla's electro therapeutics devices!
                        The big problem with this style of MWO is that people who are sensitive to subtle energy, like myself, can't stand to be in the same room with one of them while they are operating because they ar so irritating. Something was not right in all of this, and I wanted to figure it out.
                        There were some other things that also puzzled me. Both Lakhovsky and Tesla had well developed subtle sensitivities. Lakhosky used a pendulum to help him in his design work and Tesla's expanded sensory abilities are mentioned trhoughout his writings and the writings of his biographers. Because of this, I assume that both of their electro-therapeutic device we totally benign to be near, even to very sensitive people, like themselves.
                        It is our job to fill the missing link to make our device safer .
                        BTW, just in case this is related to the type of ion generation. I think anyone use Aaron graytube circuit may end up producing positive ion since I use reverse car coil connetion and the common leg produce positive (tested with neon bulb).
                        Aaron version:
                        Mine
                        Common leg connected to transistor in Aaron version, mine connector to source positive.
                        Anyone can verify Aaron circuit with neon blub? Maybe less dangerous if it is AC. Mine produce DC dominant so it is rather important to connect it right.
                        • #27
                          Personally i use a Gas Discharge Tube instead of Spark Gap , less power lost and easy to control the frequency with a RC network. So no toxic fume from the SG with my tesla coil or other experiment using spark gap.The good thing its it doesn't cost more than a high quality spark gap, GAS DISCHARGE - "KRYPTON" TUBE #0729-10Kr on eBay.ca (item 380180356988 end time 20-Jun-10 01:12:09 EDT)
                          Best Regards,
                          EgmQC
                          Edit: Its what Eric Dollard recommend to use in his "Intro to tesla transformer" for a higher efficiency
                          It would be fantastic to have the use of such tubes! Thanks for posting. Do you know what voltage rating that tube can handle? Is it strictly around 3.3Kv?
                          • #28
                            I bought 2. Thanks a lot for the link. These things are super heavy duty, there is probably another type of gas discharge tube that's a little smaller and easier to work with, but I'm really glad to have these, they are beautiful.
                            The tubes are about 8 inches long. The documentation recommends using 900-3300 vac @ 5-16 ma.
                            Or, it recommends using 1500-7500 vdc @ 15ma.
                            Pretty hefty voltages! All the power supplies they sell for it are ac, but I want to power it with dc and a capacitor to use it as a spark gap.
                            How am I going to power this thing
                            • #29
                              Usually its better to follow the manufacturer specification.The voltage rating is not really important, the tube is only a on/off switch with a sharp rise/fall time, you can trigger another step up transformer with it and be able to produce any voltage you want.
                              Best Regards,
                              EgmQC
                              • #30
                                If you use DC , you need to pulse it, else the electrode will become so hot it will break and the glass tube too. The tube are rated for 100w but not a constant 100w.
                                Best Regards,
                                EgmQC
